Question about Samsung HT-DB600 System
Preciso de um controle remoto parao sansung HT-DB600 system
3 Suggested Answers
  • 32 Answers
SOURCE: HT DB600 I NEED TO KNOW THE CORRECT PLUGS THAT GO
APPLY CABLE CONNECTION ELIMINATIONS TECHNIQUE.
First, make sure the speakers, woofers are connected to the surround unit receptacle area located at rear end of device. Second, make sure the power cable is connected to the surround device at rear end and plugged into external power outlet like an extension cord. Third, the remaining connection ports on the surriound unit are for transfering signals back and forth to TV or DVD, VCR, DVR, player devices. Usually the surround unit may be capable of connections to more than once recorder device causing the prevailence of several remaining ports receptables located at rear of unit. However, first, attempt to acheive connection to display unit like a TV set. if that were successful, the last remaining port wirings would be expected to allow for DVD, VCR, DVR, Media devcie connections. The surround device may not have been acquired with several cable wires to connected to every available home appliance. However, the surround device ports are several at rear area of unit to support several home media player connectivity. If several home player device are required to be connected to the surround system, the cable wiring may have to be acquired from retails to complete the signal sharign and splitting process. Refer to the user guide on step by step instruction on achieving connectivity. Also provided on the user guide are details contributing toward acquirign accessories for the device or performing manufacturers diagnostics.
Posted on Jan 22, 2011
SOURCE: Where Can I find HT-DB600
Actually, you don't need the adapters. All you need are conductive posts of the same diameter as the plug openings.
I just chopped up some large paper clips and attached them to the end of a piece of speaker wire, then inserted the paper clip 'posts' into the adapter openings, and attached the other end of wire to the speakers (forming a kind of bridge).
And viola! Worked perfectly! It takes a little effort, but is much less time consuming then hunting down antiquated proprietary plugs and costs nothing!
Posted on Jan 30, 2011
Polar wind
control remoto DSB-070LH/091LH
preciso de um comando para ar Daewoo
Jul 07, 2013 | Heating & Cooling
Hi i have a Daewoo DSB 180LH air conditioner but the previous tenants have lost the remote control, what can i do?
Hi Cladia,
I had exactly the same problem! Fixed it by buying a Universal All In One Air Conditioner Remote. Tried a couple which didn't work, but finally found one which did - the Chunghop K-1028E. I purchased it online for $20 inc delivery to Australia.
Good Luck!
Regards,
Will.
Feb 28, 2011 | Daewoo DWA-146R Air Conditioner
Como baixar fotos do celular para o PC
Ola, para baixar as fotos sao preciso duas coisas, um cabo de data e o software do celular.Qualquer duvida pergunte para o meu email.
Obrigado
Jan 11, 2011 | Computers & Internet
Preciso saber quais funções tem
Ola, eu aprendi mexendo mesmo. Estava cursando alemão e ele me ajudou bastante, esse eh o terceiro tradutor que comprei, e o que melhor atendeu minhas necessidades. O unico complicado eh que ele nao vem com o manual, mas alguns dias de uso e voce ja fica craque.
Dec 18, 2010 | Royal 29549X Dictionary
The remote does not work even after changing the batteries.
Se o remoto caiu ou esta com a caixa quebrada deve haver algum problema de contato com a bateria. Ligue um receptor de radio AM sem sintonizar nenhuma emissora. Em lugar vazio no dial. Aproxime o Remoto do radio e pressione algumas teclas. Um ruido devera ser ouvido no radio. Se isto acontece o remoto esta oscilando e o defeito estar no Led emissor infravermelho. Aproxime o remoto de uma camera de celular e mire o LED infravermelho na mesma. Um ponto branco devera ser visualizado. Se isto nao acontece o led nao esta emitindo.
Dec 13, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Eu nao tenho cd de instalacao para web cam veo stingray 330vb38c
www.freetranslation.com .... su problemo en englis por favor .... gracias
Aug 12, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Samsung HT-DB600 System Logo
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
