Question about Samsung Star GT-S5233 Cell Phone
I am tryng to use a USB cable for chargeing but on my lap screen a message such as
Using an ordinary USB Cable/ port to charge my Samsung Star GT - S5233S mobile
    Novelist:
  • 250 Answers
CHANGE YOUR USB CABLE.
Posted on Feb 15, 2012
5 Suggested Answers
SOURCE: plz submit samsung star gt-s5233s themes
you can download cool themes at mobile9.com. try it :)
Posted on May 08, 2010
SOURCE: samsung star s5233s
my phone is not showing net work signal ? whats problem sir
Posted on Nov 17, 2010
SOURCE: i have SAMSUNG STAR Nxt
First Download the .jar(JAVA Application) File in your PC then
open the notepad copy past this link in notepad ,put the application name in this link below where i write APPLICATIONNAME
<html><body><a href="APPLICATIONNAME.jar">install APPLICATIONNAME.jar</a></body></html>
and save this file as APPLICATIONNAME.html (.html)
now,send this link and application file in ur mobile by datacable or blutooth and run the html file in ur mobile then click on the install APPLICATIONNAME then application will install in ur mobile
Posted on Dec 04, 2010
SOURCE: i want Samsung Star NXT
Hi, all Samsung cell phones uses the same PC studio. You can download the PC studio from the link below."
http://www.software112.com/products/samsung-pc-studio.html
Take care.
Posted on Feb 14, 2011
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
When i started using usb cable wire to charge my phone it started not to work on the charger..
try the charger pin the usb port is not able to charge the cellphone it uses to connect the device to computer
Feb 05, 2013 | Samsung Corby 2 GT S3850
USB PORT NOT WORKING HOW MANY WAYS CAN I CHARGE MY SAMSUNG SCH R450
check your connectivity cable might not compatible or replace it.
Sep 09, 2012 | Samsung Usb Data Cable For Sch-r450...
My samsung galaxy s3 is not charging
Try changing the USB cable using the same charger, most of the USB cables that comes in the box has 2 pins only, better to change it to one standard USB. If the charging still not going, try to replace the batt with another, then you'll know if it is the batt or the port. The same happened to me. Just replaced the USB cable and charging went back to normal.
Aug 07, 2012 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Samsung star gt- s5233w does i need to use card reader to charge it?
The phone comes with 2 options:
1. you can use an AC charger to charge it.
2. you can also use the USB. Connect the usb cable to your computer/laptop and then to your phone to charge it.
Jan 05, 2012 | Samsung Star GT-S5233 Cell Phone
While charging mobile restarts again and again
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 29, 2010 | Samsung Star GT-S5233 Cell Phone
MESSAGE STATES THAT BATTERY IS LOW, AND KEEPS SHUTTING OFF. BATTERY SHOWN ON SCREEN AS DEAD.
plug it in to your computer via the usb cable for a few hours, the car and home chargers are not recommended for the initial charge as there only a trickle charge...if it still hasn't charged up using the usb cable, there is probably a problem with the usb port(charging port)
let me know how you make out after charging it via the usb cable that was supplied with the unit.
bill
Aug 20, 2010 | Tomtom ONE GPS Receiver
Samsung Star GT-S5233 Cell Phone Logo
94 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
