Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
CRT fluid for Philips 60PL92000D
How to change fluid and where to buy the fluid?
    Top Expert:
  • Philips Master
  • 12,223 Answers
  • DEAR sIR:
    Turn on the TV set, bring up the convergence menu and make sure the three colors--red, green and blue--converge and overlap at the cross in the center of the screen. This is needed to help converge the TV later. Turn off and unplug the TV.
  • 2
    Remove the front screen by popping off the bezel and pulling the three combined screens out. Place wide cellophane tape around the frame to prevent the three screens from separating. Lay the screen someplace where it won't be bent or scratched.
  • 3
    Remove the circuit board from the bottom of the CRT neck. It may be held in place by one screw or glued in place with silicon. Pull it out without twisting it.
  • 4
    Disconnect the large red wire from the high voltage transformer by grasping it with a large side cutter and rocking it from side to side to lift up the fastener. Disconnect the two bundles of wires from the main circuit board and leave them hanging from the CRT.
  • 5
    Remove the ground connectors by releasing their tabs with a narrow screwdriver.
  • 6
    Remove the CRT assembly from the TV by removing its four flat-bladed screws and pulling it out of the TV. Lay the CRT down with its filler plug facing up in a location far away from the TV's circuit boards.
    sincerely. God bless you
    ernesto cuaddra
    managua, nicaragua
  • Posted on Feb 15, 2012
    2 Suggested Answers
    Ecollier2012
    • 3459 Answers
    SOURCE: red and blue faded
    Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
    What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
    Posted on Jan 26, 2009
    Why is my screen red when it should be black?
    Search Results
      Philips Magnavox 8p6031c Crt Lens Fluid Repair Questions ...
      www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/page-11
      Recent Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & answers. Free expert ... Philips flat screen tv, Red flashing light. Light.
      Popular Philips Magnavox 8p6031c Crt Lens Fluid Repair ...
      www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/popular
      Popular Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & fixes. ... My son accidentally spilled water on our Philips tv and when i turned it on ... I need a screen replacement of philips tv 60" ... Why the tv come on but a min after the red blinking come on an it turn off by it self what the problem?
      Magnavox Projection TV problem... ' Techlore
      www.techlore.com/forum/thread/.../magnavox-projection-tv-problem
    Jan 13, 2016 | Philips Magnavox 8p6031c Crt Lens Fluid...
    How hard is it to change the cooling fluid in phillips projection tv.
    The CRT coolant change is all mechanical which involves removing the crt and disassembling the coolant chamber so it can be cleaned then reassembled and filled with coolant the phillips CRT coolant kit from www.tvrepairworld.com has the coolant and the instructions for the repair on cd
    Jul 31, 2011 | Philips 60PP9352 60" Rear Projection...
    Red and blue faded
    Jan 18, 2009 | Philips Magnavox 9P6034C 60" Rear...
    WHAT DO I BUY TO CHANGE THE FLUID IN THE PROJECTION LENSES
    The steps for changing the fluid on rear projection televisions are generally the same.
    You will need new fluid (Can be purchased from http://www.mcmelectronics.com/product/20-4275 MCM Electronics)
    Denatured alcohol (basically, rubbing alcohol)
    Something to scrub the inside with (I prefer good ol' pipe cleaners, available at any craft store)
    You'll have to remove the CRT, and take off the lense assembly. NOT THE SEALED ONE
    The fill hole for the fluid is usually just a big flat phillips head screw. Remove it.
    Drain out the old fluid
    Using the alcohol and pipe cleaners, try and remove as much buildup as possible.
    Clean thoroughly and let dry.
    Refill with new fluid, replace the plug and clean the CRT.
    Reassemble the whole deal, being extremely careful not to disturb the yokes (this will put the red/green/blue pictures out of alignment, causing more work) and fire it up. You should be good to go!
    Hope that helps!
    Jan 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
    Need to fix the color and screen
    Problem #2 CRT Fluid is Cloudy
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    2c07611.pngSolution #2
    Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
    Philips 55P8341 red pic
    yes change the coolant, if that doesnt correct the problem you will need a blue CRT
    Jun 04, 2008 | Philips 55P8341 55" Rear Projection...
    PHILIPS 55PP8620
    Good Day;
    It sounds like the CRT COOLANT needs replacement, it is a fluid that trys too keep the picture tubes cool , but it some times get "dirty". The fluid is called 'PROJECTION TV COOLANT', it contains; High Concentration of Ethylene Glycol. You can purchase at M.A.T. Electronics; (215) 354-7667, in PA. Part Number 212072-16.
    BUY at least 2 containers. CAUTION: remove tubes from TV, just alot of plugs,remove plugs, clean "fluid" chamber, replced discarted fluid. Good Luck, big IRISH. PS more INFO; come back.
    Mar 28, 2008 | Hitachi 53FDX01B 53" Rear Projection...
    Yellow tinge in picture how do I change the coolant fluid?
    you need to remove the CRT from the set. the problem CRT is the blue CRT. after removing the gun leave the yolk inside. there is a drain plug on the side of the CRT remove it and drain into a hazard waist container and dispose of it as hazard waist according to your local regulations (ethylene glycol) very dangerous if ingested. use rubber gloves and becarefull of the CRT it can implode. after its drained you must take the lens assembly off the clean the CRT face. use 95% rubbing alcohol to clean the face and lenes of the gun. replace the lens assembly and refill the chamber with fresh fluid. replace the CRT assembly in the set. alien according to the service manual. check for leaks after warm up. if leaks accure remove the CRT and repeat the process but save and re-use the fluid reseat and clean all gaskets and make sure the screws are tight.
    Feb 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
    Poor color
    You may need fluid change. CRT gets dirty fluid, must be changed after long time of use.
    Nov 26, 2007 | Philips 55P8341 55" Rear Projection...
    Red picture cannot adust with convergence
    You have bad CRT Fluid, the green and Blue tube need the fluid changed. This is a messy and possibly dangerous to the tv proposition, you will want to call someone to change the fluid, you will probably spend $450+ for the repair, but it should look pretty good when done, possibly better than it has looked in years.
    May 27, 2007 | Philips 9P5034C 50" Rear Projection...
    Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
    46 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
