Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
The red is wavy and doesn't line up
    Filmmaker:
    Uploaded 5 video answers.
  • 41 Answers
Sounds like you are trying to adjust convergence through the menu setting on your TV. Make sure you are using that TV's original remote to make these adjustments. If you are unable to make these adjustments then typically it is because one or both of your TV's convergence chips are burnt and need to be replaced. You can find these chips fairly easily but make sure you are purchasing OEM chips made by Sanyo. Sanyo made the majority of the convergence chips for most major brand rear projection TV's. You can find good quality chips at convergencechips.com. Hope this helps,James
Posted on Mar 27, 2012
How do you hook up a sharp stereo cassette deck RT-W800
If that tape deck of yours has an audio line out jack (like the RCA red & white holes, usually located at the back), get an RCA plug to connect it to your stereo receiver's line in jack..... or
if that tape deck of yours doesn't have an audio line out jack but, instead, has phones (or headphones) jack (usually located at the side or front of the unit), then get a plug to connect it to your receiver's audio line in jack (RCA type, also coloured red & white).. Usually the plug is small so you may have to use an adapter for your tape deck's phones jack.
BOB (June 23rd '12 3:45am)
Apr 28, 2012 | Audio Players & Recorders
Red and green wavy lines
chek your power in if it is stabile than you musht range a power stabulisator othervice if is ok need chek in to change crystal diodes and aom other parts
Jan 22, 2010 | Toshiba Televison & Video
Cctv wavy lines from camera
often problems with lines is either down to RF or if all the cameras are powered of the same psu that it could be that your psu is underated and the cameras are pulling to many amps most moden cameras rum anything from 200mas upto 1.5amps with infra red so if you only have a 500ma psu its going give up slowely
Apr 01, 2009 | Cyberhome CH-DVR1500 DVD Recorder
Red dash light
wavy lines usullay means ckeck coolant level.
Dec 13, 2008 | 2001 Chevrolet Venture
A wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
JVC AV 56WP74 Problem after fix
Will the colors move into alignment controlling them manually?
If you can get the colors to align but they simply won't hold it's a matter of programming. If they won't align you still have a failure in the convergence circuit. If red or blue will only move so far but not close enough to align you have an amp problem.
Bill
Mar 31, 2008 | JVC AV-56WP74 56" Rear Projection...
Red Wavy lines running across the screen...
Yes - - that indicates one of your convergence amps have failed. That unit takes two STK392-110 Sanyo amps which I personally would replace with STK392-150's for greater reliability. Also check all of the return resistors in that circuit 1.5 ohm 2w and feed resistors 3.3 ohm 1w all are flameproof. You'll likely find that one or more of the return resistors are bad, with suspecting the red is the failed amp check in particular R846 for change in value or open.
Bill
Mar 24, 2008 | JVC AV-56WP74 56" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Pioneer sd-643hd5 rear projection 64" tv has green geometry grid problems
Sony Convergence
Jan 25, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Toshiba tv
convergance amp ic bad.
Jan 07, 2008 | Toshiba 50HX81 50" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
