Question about Sunbeam SEK17 Electric Kettle
What's your problem?After the water has boiled the water tastes funny
It tastes as the plastic smells inside
  • jack laferty Jan 29, 2013
    it might need descaleing
Try cleaning it out i did this and now its alot better
Posted on Jan 07, 2013
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 245 Answers
Try another pan.
Posted on Feb 15, 2012
Why does the water taste funny after two . Months use
Usually taste change is created by a build-up of something inside the kettle or pot. Try the Baking Soda cleaning method:
  • Pour one cup of baking soda into the kettle.
  • Add water to fill
  • Heat the water and baking soda to boiling
  • Unplug the kettle and allow it to set for at least 10 minutes.
  • With a scrub brush or other scrubber, gently scrub the inside of the kettlepot. Be careful not to burn yourself.
  • Once it's all clean, wash with soap and water normally and rinse really well
That will usually get out any old residue that's affecting the taste
Mar 13, 2015 | Kitchen Appliances - Others
How do i get rid of a taste when making a brew
Water and white vinegar will descale your kettle which may be causing the taste. Follow these instructions:
http://www.topcleaningsecrets.com/house/kitchen/how-to-clean-an-electric-kettle.html
Jan 19, 2015 | Kitchen Appliances - Others
Russell hobbs kettle
You will need to first shock that kettle first bold hot water then remove it and replace with very cold or ice water. The smell like plastic is brought by the Plastic which over heats and somehow weakens to a point of melting thus releasing a smell into your water, Shocking the kettle would help if not then you will need to buy another kettle as that one might not be original or just wasn't tested for regularities and standards.
Sep 21, 2012 | Russell Hobbs Kitchen Appliances - Others
Why does the water boiled in this kettle smell and taste chemically? Any boiled in a plastic kettle in my home is fine.
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Jun 01, 2010 | Morphy Richards 43072 Cordless Electric...
Awful smell and taste to water boiled in a stainless steel kettl
I have the same problem. Noticed it was in two different pots. The comment number one must be correct because I only use VERY high alkaline water to boil my foods. I had a feeling it was my water. So interesting! I will clean it w white vinegar and see if the smell goes away. SAME weird chemical smell- turns your stomach.
May 25, 2010 | Kitchen Appliances - Others
Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Jan 15, 2009 | KitchenAid KSRS25IL Side by Side...
Smell and taste from water after it has been boiled in kettle. Water from tap, or boiled in a pot has no taste or smell. We are ina soft water area and have no limescale. anyone else complained?
It must be the kettle causing the problem from what you say. If th e kettle is new the problem should reduce with use but if it is old it will get worse (possibbly due to rubber washers/seals perishing)
Oct 17, 2008 | Le Creuset Kone Electric Kettle
New danby kegerator - tastes like rubber hose
There is a check valve inside the coupler of the danby kegs that cause this problem. The valve is mainly there to prevent beer from back-flowing when changing the keg. Next time you change your keg check for a little black plastic retainer and also a small white plastic ball inside the coupler. Remove those (or just smell it) and you should notice that this is the taste/smell your beer has. I removed mine after this discovery, and there isn't any issues with the taste/smell since. I've heard this is a common issue with the Danby D coupler systems. Also, you won't have any issues with beer backflow when you change the keg, provided the line going to the tap is empty (which usually is if keg is kicked).
Dec 30, 2007 | Danby DKC646BLS Full Size / Pony Beer Keg...
Sunbeam SEK17 Electric Kettle Logo
987 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
