Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
How to mirror print
I don't know how to mirror print
When mirror printing you need to turn the picture backwords in the word document you are using
Posted on Feb 15, 2012
Don't know how to replace mirror bulbs. 2003 eclipse
Hey Alex,here's a link on your rear view mirror bulb removal.
Mar 12, 2013 | Cars & Trucks
How do i remove the mirror on the hp laserjet 1200
Not required to remove mirror to avoid abnormal sound. The mirror is a part in Laser scanner assembly to reflect the image on OPC drum in various angles depends on model. In your series 1200 having single mirrored scanner assembly mounted on top area. To remove this you need to remove right,left back & top covers.. The laser scanner protect with four screws & two connectors. Remove all take out the unit. For removing the bonnet single screw protection remove this screw, take out cover. Inside you can observe a motor with four faced reflector. While motor got the energy it will rotate, if motor lubes are dried up it will make noise, remove motor head gently,(to remove take out entire motor unit with PCB which protects three screws, you cab observe black 'U' shaped plastic lock unlock it & pull motor up, apply lube to rotor & refix it back, ref see the drawing, you want to clean the mirror? ear bud you can clean surface of the mirror gently..
But it is no so easy, bare hands you cannot handle the mirrors, If mirror disturbed its factory fitted angle its very difficulty to back its own position. Removing the motor also difficulty,motor head carrying 4D reflector, while removing any scratches, or finger prints will damage the quality of prints some times scanner error appears.. 9_5_2012_11_07_49_am.gif
Sep 04, 2012 | HP Office Equipment & Supplies
2004 mercury mountaineer side mirrors don't work
Fuse,Switch or Control Knob,Mirror Motor or Module
if one applies
Don't know if you can control or check with a scanner
I would have to look at my software to see if ford offers that
Aug 03, 2012 | 2004 Ford Escape
My interior lights, cigarette lighter and electric mirrors don't work on my 1991 gmc 3/4 ton 4wd surburban
I don't see a power connection to the three components. The interior lights are on a 20 amp courtesy fuse, the cig lighter should be on a 30 amp ACC fuse, and the mirrors are probably powered thru the key on a different 30 amp ACC fuse.
The only common factor would be a ground connector somewhere.
If they all died at the same time, a ground problem would be my guess.
Jul 09, 2012 | Cars & Trucks
Hp printer 1312 fadad print how to fix
Check any refilled cartridges?.. No.Go to main menu select default setting.. check for the quality..No..
Need to clean reflecting mirrors in scanner assembly..Only professionals can perform this activity..
Remove right, left & back doors..
Detach the cable which came from flat bed assembly, remove two screws back side just below of flat bed, gently push flat bed assm back to front, lift & take out the flat bad unit.. remove upper cover, you can observe the scanner assm ( see the snap shot) "Note: to take out scanner assm cartridge & cartridge bank must be present in to the printer to prevent the damage to transfer kit, other wise scanner will fall down on transfer belt" Unlock & remove scanner secure pins(4nos), detach scanner flat cable connected to DC controller, take out scanner assm, open the bonnet of scanner assm, clean surface of the mirrors very very gently with ear buds.Don't disturb any factory settings, once its cleaned refix every thing back.. "Note: scanner flat cable which is connected to DC controller is not that much lengthy, before powering on check once cable connected in properly or not, if any thing goes wrong in this area printer wont power on & it may damages the DC controller or scanner assm .." But I am sure that only professional can perform this activity, if you are not qualified pl don't try it..5_25_2012_8_24_06_pm.jpg
May 25, 2012 | HP LaserJet CM1312 All-In-One Printer
How do I clean the laser mirrors myself? is there a manual or video that can show me how. i don't have the money to pay to have it done. the cheapest quote i have gotten is way more than i can...
Fist you need confidence.. then only you try it.. no video/manual for this, because of its no suggestible. Read once again & once again understand it then try it..
Open back cover & side covers.. two boards you will found at back side left one is formatter & right one DC controller. remove both DC & formatter, mark the connectors where you removed.
Remove the plate where DC & formatter placed,after that only you will find the scanner assm.
Two screws only protected to scaner assm, mark them where you removed.
Scanner assm: While cleaning the scanner assm must be wear glows..to avoid finger prints.
Remove the scanner assm cover(two screws) & shutter. Observe two motors with four reflecting mirrors, clean the mirrors & engine reflector sides(a squared metal part which was rotates along with the motor) with ear buds
gently. ( ear buds are good cleaning method) while fixing the unit back ensure that seated properly.. fix back every thing & do calibration.. check the print quality, if you failed to fix the scanner unit in properly, you need to do entire things once again.. Good luck..
Sep 27, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
I bought a Epson Stylus NX125 and I don't know how to set the printer to print only Black & White.
You can control the format of your print-out via your Windows Printer properties (e.g. in W7: Control Panel -> Hardware and Sound -> Devices and Printers -> Printers and Faxes section -> Double click on Printer -> Pinting preferences) : under Preference/Features - 'Color Options' should set to 'Print in Grayscale'.
Sep 22, 2011 | Office Equipment & Supplies
I can't find any documentation on how to remove the primary mirror for cleaning. I'm a newb and don't want to mess anything up. Thanks, Bob
First -- how do you know the mirror needs cleaning? Did you shine a flaslight down the tube and see some dust? Never use a flashlight to determine if a mirror is dirty-- they are ALL dirty when you use a flashlight to check them.
Only clean the mirror if it is interferring with the views through the scope.
There is a ring around the back-- remove those screws and the mirror should come out-- don't driop it! Then remove the mirror from the mirror cell.
Sep 03, 2011 | Celestron Advanced C10-NGT (600 x 254mm)...
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
37 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
