Question about Coffee Makers & Espresso Machines
Faema x3 manual
Hi I bought this machine off ebay but do not have a manual for it. The machine works, although I do not have a milk dispenser/ cabinet/ fridge for it. An instruction guide or help on how to program dosages would be appreciated Thanks Jon
  • 4 Answers
SOURCE: DeLonghi BAR 4 Espresso Machine User Guide
Go to http://www.delonghi.com/Int/USA/customer.html
Choose the Customer Service tab. On the left, notice a link to Instruction Manuals - follow that link and choose your model by following the products tree. It will give you a pdf file of the instruction manual for download.
Posted on Mar 26, 2008
SOURCE: User Manual
Please email me tomorrow at dspringer5114@hotmail.com. I can scan my manual and send you the pdf from my office. I just need you to remind me. Thanks
dgsrgr8
Posted on Jun 01, 2008
SOURCE: steamed milk
I just had this same problem and solved it.  It was due to a very small amount of milk residue on the inside of the black frothing unit (the one with the dial which lets you choose foam or no foam).  Grip the dial firmly and pull it out while twisting. It may take a few seconds to twist and pull it out.  I had a very small spec of milk residue in one of the crevices on this piece.  Quick clean with a toothpick and plenty of hot water, reassembled, and it works perfectly.  Hope this helps someone.
Posted on Jul 05, 2008
  • 75 Answers
SOURCE: Cappuccinatore Milk Temperature on Saeco Royal Pro Machine
Hi
First open it up and run it without any milk attached until just mostly steam is coming thru. Turn off - then drop the tube into a jug of milk which is locted below the outlet. If its steaming, the milk will be heated up ok - it may need flow adjusting - lift the thin 'plug' near the tube up and down to adjust flow. You can add to the froth by lifting the tube out of the milk for a moment then back in again a few times.
To clean the unit just run clean water tru as tho it was milk until it comes out totally clear (about 1/4 cup). For hygiene sake make sure the tube is wiped clean on the outside with a clean paper each and every time when finished.
You can flush your main coffee lines out by making out its doing a large preground coffee - but don't put any preground in.
Select preground - select large coffee and go. Pays also to remove the brew unit and wash in warm water once a week - saves coffee goo building up and causing it to stick.
Posted on Feb 22, 2009
  • 1089 Answers
SOURCE: machine does not dispense milk properly
Hi
There is a pin in the cappucinator the needs to be turned slowly to create the venturi action to make it work. If you have lost the pin it won't work.
Posted on May 24, 2009
Franke Evolution no milk being dispensed
May be the milk pipe between the fridge and machine is kinked.
Mar 03, 2015 | Franke Evolution
No milk or frothy milk being dispensed
Link to manual
Milk may not be frothed optimally. In these cases simply turn the flow regulator as shown in the figure.
Turn the regulator 2-3 times to perform a quick maintenance.
Note: If the assembled regulator is missing, replace it with the other 3 regulators provided.
There is a pump
English version of manual pages 101 to 149
Dec 21, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Can' t remove milk dispenser retainer cva4062 to clean because milk will not dispense. Machine is brand new , used 2 times
see the owner manual on how to manualy clean the pipe work
i do it on a weekly basis
u have to remove the face plate pull down the dispenser nozels and the open the door and remove the mild flask and the remove the milk pipes
run the bristels and run some water trough
Nov 03, 2012 | Miele Coffee System
Machine does not dispense milk properly
Hi
Mar 16, 2009 | Saeco Royal Digital Plus Coffee...
I need instructions for a Cuisinart Iced Cappuccino Maker
I have a PDF of the user manual if you want me to e-mail it to you. In the meantime, here is my Wiki Manual (BTW, pagan, the machine does make hot espresso or cappucino, but it doesn't froth per se like a regular espresso machine - it just heats the milk internally and dumps it into the espresso):
General Directions for Making Iced Cappuccinos
- Place carafe on top of drip/tray grate with handle touching right front of ICAPP – the ice fill lines should be visible when looking at front of unit
- Turn “milk knob” to OPEN position, and open lid of ICAPP
- Remove milk container, espresso collector, espresso spinner cup and cover
- Put espresso collector back in place with two plastic teeth facing front of machine
- There is a stepped fill line inside water reservoir that measures off 1,2, and 4 cups
- Fill water reservoir with either 1,2 or 4 fill line cups – do not overfill to avoid damaging the electronics
- Add espresso grounds to espresso spinner cup
- Line up teeth of spinner cup cover with spinner cup so that the cover locks into place
- Fill milk reservoir with 3 oz of milk per cup of iced cappuccino that you plan to make – there is a fill line that measures off 2 cups or 4 cups
- Fill carafe with either 2 cups worth of ice or 4 cups, depending on how much iced cappuccino you plan to make
- Press down on lid and turn milk knob to HEAT postion
- Turn ICAPP on using the ON/OFF button – it will begin to heat – takes about 5-6 minutes (HEAT light will stay on during this process – doesn’t make noise or steam for several minutes)
- When READY light turns green, turn the milk knob to the DISPENSE MILK position – your espresso and milk will start dispensing
- Unit turns itself off automatically when ready – takes several minutes
Feb 26, 2009 | Cuisinart ICAPP-4
LG Fridge Freezer display has CF error code
Turns out a CF ER is a Compressor Fan problem.
Had a look and the fan was not turning, although it spins freely. Apparently it's a 3 phase 12v fan. I was able to get a resistance measurement across it but didn't know what to expect.
This also explains why it seemed a bit quieter and why the water is a bit warmer sometimes. The valve for the water dispenser is right beside the fan and it's getting pretty hot in there at the moment.
Dec 07, 2008 | LG French Door Cabinet Depth Refrigerator...
How to work Spidem Cappuccino Instantly Espresso Machine
the coffee portion of the knob only allows the instant coffee to be added to the mixing process, then when the knob is turned to the milk selection, the milk is frothed and the instant coffee is added and dispensed into a container under the dispenser area on the front of the machine......Hope this helps.
Aug 16, 2008 | Coffee Makers & Espresso Machines
Hca391k-al fridge freezer keeps shutting down
You said the light inside coincides with the cooling not working either? If so, this sounds like an electrical problem in the house, or maybe the cord isn't fitting the outlet good and tight. I personally had that happen to me one time.
Nov 11, 2007 | Hoover HCA391K Bottom Freezer Refrigerator
Coffee Makers & Espresso Machines Logo
41 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
