Question about LG 37LC3R 37 in. LCD Television
Lg 37lc3r 7times led
The led flash 7 times and go to stand by
Philips 42pf9431d/37 stopped coming on won't come on and red light on front flash s 7 times pause 7times over and over
Unplug the television from the back or at the recepticle. Wait 60 seconds or so and plug back in. This will reset the TV.
May 25, 2014 | Televison & Video
Hi, my panasonic tv power light flashes green, then it turns to orange flashes 7times then stops and starts again=orange and repeats itself by flashing orange 7times over and over , Again This is the power...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts...
Jun 23, 2017 | Panasonic PT-56LCX66 Television
My Sony KDS-R60XBR1 60 inch HDTV came on for a few min then shut down itself, and the power/standby led blinks in a 7 times mode (7 times then 7times then 7 times ... ). I read thru the fixes on this site...
Ok i have consulted the shops service manual on that sony model.A blinking led of 7 times is and indication that your audio cuircitry has blown. or shorted. most likely the audio amplifer ic. ic number 3005 on the K cuircit board. Specifically the audio power supply line has become shorted. most likely it would need replaced along with its assocated fuse ps3001
May 28, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Need Scientific Atlanta 8300HD DVR code
You can follow the two methods I have explained below:
AUTO SEARCH FOR CODE
To program your remote in Auto Search Mode, first turn on the device you wish to program and point the remote toward it.
Then press and hold the SET and POWER buttons until the LED turns on.
Then press the device key ( CATV or RCVR) .
The LED will flash once.
Then press the CH+ button.
Then hold the POWER button for about two seconds until the LED turns on.
Release the POWER button and the LED will flash slowly. Your remote is searching through all of the codes. Continue to point the remote at the device until your device responds.
If your device turns off, turn it back on and press the CH+ button on your remote. Then press the POWER button and CH+ button alternately until the device turns off and the code is correct. Press the ENTER button to confirm and store the code. The LED will flash three times and then turn off.
If the above is not helpful then try manually searching for code:
First, press the device button on your remote.
Then press and hold the SET button. While holding the SET button, press 1 to find the first digit, 2 to find the second digit or 3 to find the third digit.
The LED flashing time will stand for each code number. If it doesn’t flash, it will stand for zero.
For example, the TV code you are trying to find is 102.
Press the SET button and 1. The LED will flash one time.
Press the SET button and 2. The LED will not flash.
Press the SET button and 3. The LED will flash two times.
Hope it helps to find your code. Thank you for using fixya!
Sep 25, 2009 | One For All URC-7800 Remote Control
Looking for the remote control code for LG 37LC3r Flat Screen TV
hi..the remote control that supports ur LG
is Universal Remote Control Inc. Digital R50.
This will definitely suite ur tv.
try this out.
thank u..
rate me..
Feb 05, 2009 | LG 42LC2D 42 in. LCD HDTV
Clean light flashes 7 times
try doing button setting change from "Hi-Temp Wash - Normal - Hi-Temp Wash - Normal" sequence of button selections. This must occur within 6 seconds and initiates an internal diagnosis of the machine.
The process runs for about 19 min. and shuts off
During the process several LED's light up and several funtions start and stop.
If the machine has no broken systems, you should be able to open the door add some soap and the usual dirty dishes and carry on with normal operation. this is the method to reset the machine.
Most likely is that there were suds in the last cycle or the door doesn't close smoothly.
Jan 09, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
LG 37LC3R 37 in. LCD Television Logo
Computer Repairing
Computer Repairing
