Question about Vacuums
Little yello steam cleaner only the red light is coming on when red and yellow should be lit hence it is not working
Yellow light is not lit, and it is not heating up
reddevil6
  • 1673 Answers
SOURCE: No steam
Take it apart, the heater is most likely plugged, use something small enough that you can put in the ports and clean them out. Once they are cleaned out, then use a mix of water and vineager, run that thru it for awhile to clean out the lines.
Posted on Feb 22, 2008
geemarie
  • 876 Answers
SOURCE: polti steam cleaner problem
Here is a site where you can obtain information or service for your equipment. There is no online support that I can find.
http://www.polti.it/eng/index.htm
Good luck to you.
Posted on Aug 18, 2008
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
heatman101
  • 43501 Answers
SOURCE: cleaner heats up but no steam is coming out.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
nt
Posted on Sep 25, 2010
SOURCE: My steam cleaner seems like
It is likely that you have a thermoswitch problem. Mine seems to have the same problem. You plug it in and it says ready, but steam does not come out. Here's a picture of the thermoswitch. If you can find a replacement part, let me know I need one too.
Posted on Jan 27, 2011
What does yellow exclamation point light mean
YELLO and RED mean danger - clogging, not brush turning, overheating, .... it is time to RESET -- turn it all off and let it sit for half hour - that is what the manual says, check the brush that is not clogged up and check the inlet to the hose and where the hose goes into the body from the head unit where the brush is - make sure those not clogged either. Turn it on, push the RESET button on left back side of head unit by the switch that changes height. The reset button is like a circuit breaker - stops unit when overheats, starts when reset. Yello is ERROR, and fix it before it turns red and stops all the way. Cheers!!!
May 31, 2014 | Electrolux EL8807A Precision BrushRoll...
Red light on no steam
Hey Michelle! Sorry to hear you're experiencing no steam.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=18994&cid=ccsocial
Mar 02, 2013 | Bissell 1867-7 Steam Mop Chemical free...
Instruction manual for Little Yello Steam Cleaner
what brand name is the model BISSELLL/ SHARK/HOOVER/?
Nov 20, 2012 | Vacuums
Little yellow steam cleaner wont work no steam coming out of nozzle
I have got a little yello steam cleaner there is no steam coming out of the nozzle wot should I do to be able to get this to work again if some one can help me please
May 06, 2012 | Vacuums
My little yellow steam cleaner will not release any steam from gun
Nor mine, can't seem to buy a replacement. Any luck?
Mar 11, 2012 | Vacuums
Need to download a manual for my little yello steam cleaner
You usually go to the manufactures web site
Aug 05, 2011 | Vacuums
After a short time of using my steam cleaner the red light comes and steam stops.
red light of course means stop, so do. second its a vacuum so my next assumption is its full either it needs to be emptied or cleaned so it can resume its job. I hope this helps.
Jul 13, 2011 | Domena NVT200 Steam Vacuum
Polti steam cleaner problem
Good luck to you.
Aug 18, 2008 | Vacuums
Euro-pro shark steam cleanercs618hd
I am looking for an operator's manual for the Euro-Pro Schar SC-505 Handheld Steam Cleaner.
Any ideas?
May 26, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
Vacuums Logo
116 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
