Question about Lexmark X9350 All-In-One InkJet Printer
No power to my X9350
My printer has just died! There is definitely power going into the power pack as the green light is on but it will not turn on! Have bought a new pack but it makes no difference.
Any ideas as I am going frantic!
  • mckinney36 Mar 06, 2009
    There is power to the printer, but will not power up no lites. just seem to have blown a fuse.It is a lexmark x9350.
Error 5100 what do i do???
Error 5100 points to a "carriage jam"
The carriage is the assembly that contains the print head and cartridges.
This error can be difficult to solve because various things can cause it.
Since this is a new printer, maybe there is some packing or packing tape that is obstructing the carriage.
Verify that the carts and print head are installed properly.
Check the gears as best you can for any obstructions.
If the carriage moves to a center position when you open the cover as if to change cartridges, try a reset to clear the error message :
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Sometimes you have to try this a couple of times, if you've n
Sep 08, 2011 | Office Equipment & Supplies
How can i fix error 5200 on my canon pixma ip2770
You can try the following 1. Turn off printer, cable power still plug in,
2. Press Resume Button don't release
3. Press Power Button don't release and than release Resume Buttons
4. Press Resume Button 6X
5. Turn off printer cable power still plug in
6. Turn on printer again, now this printer ready to use.
Or try
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
Jul 27, 2011 | Canon Office Equipment & Supplies
I have a canon printer IP 2770 .....i try to one my documents and shows that error 5200... what does it mean
Here's How to Reset Canon IP2770 Error 5200:
Mar 23, 2011 | Canon PIXMA IP5200 InkJet Photo Printer
It was showing error code 5200, I did the fix of removing the print head and when I re-installed it , now it is showing that print head is incorrect. It is the original one that came with the printer and...
Mar 17, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Always time sow Error number; 5200 A printer
Mar 16, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Printer was working fine, tidying up for xmas pulled electric cable to disconnect and the black power pack???? unit in the back came out instead. Never thought anything of it. Now gone to start up and no...
Pull the power pack out of the back of the printer and reinstall. The two silver tabs and green light should be facing up.
The green light on the pack just indicates that you are getting power from the wall outlet...
Jan 07, 2011 | Lexmark X5470 All-In-One InkJet Printer
My Lexmark x9350 only turns on and off if I plug and unplug...
This, probably, is a power issue on the printer. Unplug the printer from the computer. Unplug the power supply from the printer (it's the black box behind the printer where the power cord is attached). Try not to use any power strips or extensions for the power cord. If possible, plug the power cord straight to the wall outlet. With the power cord plugged in straight to the power outlet, plug the power supply back in the printer. That should refresh the printer. When everything's powered on, plug printer to computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 13, 2010 | Lexmark X9350 All-In-One InkJet Printer
My Lexmark X9350 All-in-One doesn't turn on.
Actually, the printer's power cord should be plugged in to a power source having 110-220V output. The power supply (the black box behind the printer where the power cord is attached) converts that power to 30V. Basically, if your wall outlet has power output of 110-220V, you won't need a transformer to convert that to 30V. That's the job of the printer's power supply. Hope this helps. If you need more clarification, place a comment so I can get back to it. Thanks.
Apr 16, 2010 | Lexmark X9350 All-In-One InkJet Printer
I get a message telling me that the waste tank absorber is full. Could you solve this problem for me?
Try this to reset the error.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Sep 12, 2009 | Canon PIXMA iP90 InkJet Printer
Lexmark X9350 will not scan or copy
Hi, have you had any luck repairing this? I also had this problem. I rang Lexmark support who, after 45min on phone, decided to send me a new machine. They did not want the old one back so I intend to try and repair it when I have time. I reckon the x9350 are prone to scan head problems as mine was making strange noises before it packed up and I have seen other reports of problems on various forums.
May 05, 2009 | Lexmark X9350 All-In-One InkJet Printer
Lexmark X9350 All-In-One InkJet Printer Logo
114 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
