Question about KitchenAid Dishwashers
Model KUDH230B Water is leaking from the bottom and also from the top of the door
  • 210 Answers
SOURCE: water leaking out of bottom of door
There is a rubber seal that runs along the bottom of the door. If you carefully run your hand along there just to see if it is all even. Sometimes they get out of place and you can push it back and then closing the door it realigns itself and all is good. If the seal is damaged, you have to replace the door liner as the seal is attached.
Sgt 48
Posted on Jun 07, 2008
  • 35 Answers
SOURCE: Leaking water
Check and replace the seals if need.
Posted on Jan 06, 2010
Testimonial: "thank you is it worth fixing because it is at least 30 yrs. old but good shape inside. Costs 75.00 for service call I appreciate your input"
SOURCE: water leaks from the door of countertop model on
My older model had cheap plastic type rivets around the window. Of course they broke and water leaked out the window. I took the door apart and put in a new gasket the siliconed the heck out of it!
Put dishwasher on a counter or floor and put a nice thick phonebook under neath the opened door for support. Carefully replace window with gasket and a bead of silicone. Put enough weight on top to press it down and seal it. Leave for 24-48 hrs. I've replaced the window 3 times and this fix has lasted 2 years now. total cost about $10 and a little effort. make sure you use heat tolerant silicone.
Posted on Jul 09, 2010
heatman101
  • 43501 Answers
SOURCE: Why is water leaking from the bottom of the door? ...
Hi, Yes... Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 29, 2010
heatman101
  • 43501 Answers
SOURCE: water leaks at top &bottom of door only on
Leaking Dishwasher
heatman101
Posted on Mar 08, 2011
When I run the water dispenser there is a water leak on the floor.
What happens to be the model number?
26173865-qoiw5swae02ur1lnfj3irvmf-5-0.jpg You very likely have a leak in the water line coupling at the bottom or top of the dispenser door where it goes through the hinge
APPLIANCE 911
Apr 24, 2016 | Refrigerators
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
Maytag Model...SAV205DAWW leaking water at bottom
there could be 2 things that i know of
first one is that someone bended the door to much and the joint's are eather lose or out of place
the second thing is that the door sealing rubber is out of place, you need to putt it back to place
Dec 27, 2009 | Maytag SAV515DE Top Load Washer
Water leaking on the floor at the door.
frigidaire models usually leak water at the top of the door and water enters in the door through door latch.2 fix this u can insert a double sided sticking tape behind the tub seal at the top so that door top sits tight against the top part of seal.
also u can remove the front door panel 2 c if water ia jumping out of tub at the bottom at lhs and rhs corners.if thats the case pull out the door seal and insert it back stretching it little bit and leaving some of it extended at both bottom corners so that it can stop the water from splashing out.
Aug 15, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Please reference SubZero Model No. 680. My
OMG DO NOT TAKE THE DOOR APART!!!!!!! The water line is not in the door. It comes from the valve on top of the unit into the fridge behind the control. Make sure that the drain behind the crispers isn't blocked causing your leak.
Jul 20, 2009 | Sub-Zero 680 / S
Water leaking at bottom of freezer door where water line goes into door
DRAIN IS STOPPED UP! IS THIS A TOP AND BOTTOM OR A SIDE X SIDE?
Apr 27, 2009 | Freezers
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Door still leaks after replacing bottom seal
the bottom seal isn't actually a seal, rather it serves as a splashguard. I had the same problem with the same model and started by replacing what I thought was a seal located at the bottom of the door.
Check if the screws on the top half of the pump (located under the lower spray arm which needs removed first) have become loose. The screws were barely in the threads which caused a stream of water towards the door and leaked between the splashguard and bottom edge of the tub and onto the floor.0d084cc.jpg
Dec 20, 2008 | KitchenAid KUDC25CH Dishwasher
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Dishwashers Logo
23 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
