Pioneer VSX-AX4AVi-S HDMI connection to PS3. HDMI light flashing just cannot get an image or sound. Very frustrated. If someone could give me a step by step advice on what to do it would be greatly appreciated. PS3 works through TV ok.
  • sovello Nov 26, 2008
    pioneer VSX-AX4 AVI kinda similar model. Same problem.
    Any luck so far?
  • Anonymous Mar 23, 2014
    After hooking up my reicver up the hdmi cable keeps blinking
Found solution myself, will post shortly
Posted on Mar 16, 2009
I heard that a firmware update is out (which could help solve this problem), but it requires you to send the unit for service, which is unavailable in my region.
My hdmi is on my pioneer vsx 523
The HDMI inputs are on the back upper left of the unit. the 4 on the left are INPUTS (like you connect you DVD to port 1) then you need a 2nd HDMI cable from the white 5th port going OUT to your TV HMDI port.
http://www.pioneerelectronics.com/StaticFiles/PUSA/images/Product%20images/Home/VSX-523_back.jpg
Dec 07, 2016 | Pioneer Audio Players & Recorders
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Jan 19, 2015 | Pioneer Vsx-1121-k 7.1 Home Theater...
I want to connect a ps3 to my new pioneer receiver
if your tv has audio output, connect from there then into your pioneer
Nov 22, 2017 | Pioneer Audio Players & Recorders
Make sure that whatever input you are using is set for hdmi audio. You may have mistakenly changed the input mode.
Jan 10, 2014 | Pioneer Audio Players & Recorders
Pioneer vsx 1027 drops hdmi signal to ps3
will it display after retarting box and ps3?
Mar 06, 2013 | Audio Players & Recorders
Pioneer vsx-522k Receiver Sound skip on SD only
use the hdmi from player to tv, use seperate coax or optical cable from player to reciever for your sound
Mar 02, 2013 | Audio Players & Recorders
Dial norm +4 on Pioneer vsx-ax4avi-s? Understand is an auto feature but annoying, controls volume level. can it be switched off/
here is a link to your manual:
http://www.pioneer.co.uk/uk/products/archive/VSX-AX4AVi-S/media.html
looks to be an auto calibration the mcacc turned on during the testing and setup phase. you could always put the mcacc in manual mode and go through the settins yourself. Just be aware that the setting you are talking about controls the level of you dialog channel and lowing might cause you to have less ability to hear low dialog.
Cheers!
Feb 01, 2010 | Pioneer Audio Players & Recorders
Can the Pioneer VSX-74TXVi support 1080p video resolution thru HDMI? I have PS3 and I cannot get 1080p thru my TV unless I go to the TV directly and bypass the receiver.
No. Your receivers HDMI version is 1.1 It was the first, and as always, riddled with compatability issues. Nothing you have should be run thru this receiver via HDMI, use your receiver for digital audio switching via optical or coaxial digital. If you really want all the HDMI info and problems; google hdmi forums. There are hundreds that specifically deal with this issue and all the specifics you could ever ask for. Long of the short of it though, Version 1.1 will not work and can not be updated by firmware. Also, it's not Pioneer's nor any other MFG's receiver's problem it's 80% recording industry trying to protect copyright on video, and 20% poor design by HDMI and not forward thinking. Hope this eases the frustration!
Nov 22, 2009 | Pioneer VSX-74TXVi 7.1 Channels Receiver
Pioneer VSX-818V-k wont work with PS3 or AT&T U-Verse
That model does not support audio via hdmi. That is the problem.
Jan 04, 2009 | Pioneer VSX-818V-K Receiver
1,052 people viewed this question
 Grubhead
Grubhead
