Question about Dell Wireless Keyboard Optical Mouse w0147
DELL XPS M2010 blutooth keyboard is not working
I Have lost Bluetooth keyboard connection with my DELL XPS M2010
  • 998 Answers
SOURCE: XPS One Keyboard's Characters not functioning
Try to re-sync the keyboard to the computer. Here’s the procedure:
1) Turn the computer on.
2) Turn on the keyboard
3) Press the sync button on the rear of your computer’s left speaker.
4) Press the sync button on the keyboard. ( I believe it’s on the bottom of keyboard)
The sync button has a symbol next to it, (2 arrows going in clockwise direction).
Ensure that the keyboard battery has not run low.
If that doesn’t work, look for a Bluetooth icon in the lower right hand corner of your desktop and double click on it to open the Bluetooth configuration utility. See if there’s a configuration file for the keyboard. If there is, delete it and then re-detect Bluetooth devices.
Hope this helps.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Posted on Oct 20, 2008
  • 60 Answers
SOURCE: my dell bluetooth keyboard is locked i hve re
check yor drivers. dell website has free downloads.
Posted on Jul 24, 2009
  • 11 Answers
SOURCE: I have lost sound on my Dell XPS M2010
Yep - this I run into every start up, or every awake session from Standby - the problem is that the default sound device changes - I've gone through the control panel, and put a shortcut to the Sound mechanism in my taskbar - then when it changes, I just modify back to the Speakers/Headphones setting - I usually have to change stations on Pandora, or skip to a new Youtube, but it all works our very quickly.
Posted on Feb 15, 2010
  • 10865 Answers
SOURCE: The keyboard battery will not stay charged, I have
Hello. Remove the battery and clean the contacts of both the battery and the keyboard with the eraser end of a common pencil. Then reinstall the battery. J.
Posted on Jul 31, 2010
Ezrahite
  • 2632 Answers
SOURCE: I have a Dell XPS
Welcome to Fixya. If you have isssue with the bluetooth connection of your Keyboard and Mouse then all you need to do is to use the guide provided below to fix the issue. You also need to make sure that the driver for your bluetooth device is already install on the system
Dell XPS 420 Drivers
Resolve Bluetooth mouse or keyboard failure to function - Microsoft (Refer on Method 4)
Mouse, Keyboard or Touchpad Not Working Correctly - Dell (Refer on Issue 2)
Hopefully the problem will be fixed.
Thanks for using Fixya.
Posted on Feb 27, 2011
I have a dell xps that came with a wireless/bluetooth keyboard with mouse pad and i have another dell xps 420 that i'd like to use the wireless keyboard on...they are both dell xps's and both
Wireless/Bluetooth keyboards and mice can only be used with one device at a time it is like a bluetooth headset once it is paired with a phone it will 99.99% of the time only work with that phone and that phone only, Wireless keyboards and mice are setup on the same principal once they are paired up with 1 PC to use on another PC you have to remove the pairing. The worst case scenario is that the second PC's Wireless/Bluetooth has failed. I hope this helps.
Sep 03, 2012 | Dell XPS 420 PC Desktop
I have Dell XPS M2010. Windows Vista 32 bit. 350 bluetooth module The mouse connects and works well. The keybboard won't pair. I put it into discoverable mode and the three lights next to the power...
The solution is to formn a class action suit against DELL for this overpriced piece of junk. I went through 3 of them and they all failed.
DELL left these dogs out there in the market until the warrenties expired on all the M2010 machines and now they will charge you for their failure to build a solid product.
The Bluetooth Access Icon is nowhere to found in the control panel, so the manual is wrong as well.
DELL is acting irresponsble and needs to be punished. Let's form a Class Action Suit today.
Apr 14, 2011 | Dell XPS M2010 Wireless Bluetooth Keyboard
My laptop touchpad button not working
most likely, it already needs a replacement, but do try to uninstall and reinstall your touchpad driver and make sure your touchpad settings are correctly configured. you can also try to use the drivers and utilities CD from dell to run a test on the touchpad to see if they will respond to determine if it is a hardware level
Mar 12, 2011 | Dell XPS M2010 Wireless Bluetooth Keyboard
XPS M2010 boots in and everything works but fans
You can try installing this program that controls the fans on a Dell laptop. If this does not work you have a hardware issue with either the fans or the main board.http://www.diefer.de/i8kfan/index.html
May 29, 2010 | Dell Inspiron XPS M2010 Notebook
I have a xps m2010 laptop.. lights flashes but screen wont come on
Which light flashes?
You can try to run the diagnostics, while the computer is off Press and hold the power button with the Fn key,
If you have bad hardware it will an annoying sound.
This can help minimize the problem.
If it gives you the sound you can post here the LEDs on the keyboard so i can tell you what it means or simply you can contact dell tech support for further help.
Jan 18, 2010 | Dell My XPS M2010 Notebook
Keyboard locked or not working. three lock lights blinking blue
This isn't a fun solution - the best thing I've come across is to hit both reset buttons (on the computer, and on the keyboard) until both are flashing - pull up your bluetooth settings (from control panel (I've got mine shortcutted into my task bar)), then disconnect the keyboard, and search for a new item - after the computer finds a new keyboard, connect using a new pairing code.
While this might not be the best solution, it works for me, and I don't know of a better one, or quicker!
Sep 30, 2009 | Dell XPS M2010 Wireless Bluetooth Keyboard
Dell M2010 Not booting up.... Craziest dell story to date
Your power supply might not have enough power to feed to your system. Especially if you have alot of components connected to it.
Aug 12, 2009 | Dell My XPS M2010 Notebook
May 29, 2009 | Dell XPS M2010 Wireless Bluetooth Keyboard
COOLING FAN DONT WORK ON DELL XPS M2010
call the dell tech 18006249896 they will be the right people to talk to
Jan 12, 2009 | Dell XPS M2010 Notebook
Dell Wireless Keyboard Optical Mouse w0147 Logo
100 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
