Question about Olympus FE-210 Digital Camera
Formatt memory card and battery empty!
Formatt memory card and battery empty always appering everytime i don't use my olympus fe-210 for a period of time.
  • Anonymous Jan 02, 2009
    Having the same problem..
    Genius:
  • 1,234 Answers
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Accepte My Greetings
    Posted on Aug 27, 2010
    Why does my Olympus FE-210 says ' Card full' on the screen ?
    Usually because the memory card in the camera is full and cannot record any more photos. You have to insert a new memory card, or delete some photos from the current inserted card.
    Jul 12, 2014 | Olympus FE-210 Digital Camera
    I need the program to unload my pictures from the camera Olympus FE-210. Thank you !
    You don't need a program.
    The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
    Sep 15, 2010 | Olympus FE-210 Digital Camera
    Olympus FE-210
    Consider NOT connecting your camera to your computer.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
    Aug 10, 2009 | Olympus FE-210 Digital Camera
    Write Protected. What does this mean?
    no, there will be a small button on your memory card just 'slide' it the opposite side. its on protect mode.
    Regards
    Apr 08, 2009 | Olympus FE-210 Digital Camera
    Repairs
    i have a olympus FE 210 i had this less than a year ago when my memory card is in the camera the camera does not turn on but when i remove the memory card the cam works fine. please Help
    Jul 24, 2008 | Olympus FE-210 Digital Camera
    Olympus fe-210 fault
    i think u need to change some small componnt in power board.
    Jun 16, 2008 | Olympus FE-210 Digital Camera
    Memory stick problems
    Try taking memory card to someone with a card reader on their computer, if it's going to work then a reader will get it to work. If it doesn't work then reformatting is the least expensive option, unless you take it to Specialists to have it analyzed. If card won't format then it probabaly has gone bad.
    May 08, 2008 | Olympus FE-210 Digital Camera
    Downloading to computer
    yes take your sd card ok and buy a sd card reader usb then it will show up trafer off sd card to hard drive then u can formatt that sd card again thx for using fix ya
    Feb 03, 2008 | Olympus FE-210 Digital Camera
    How to put memory card into Olympus fe-210 digital camera
    Did you buy the proper memory card? Your camera supports only XD cards.
    Dec 28, 2007 | Cameras
    Olympus FE-210 Digital Camera Logo
    43 people viewed this question
    Top Olympus Cameras Experts
    Willem.
    Willem.
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
