Question about Sony VAIO Computers & Internet
The laptop swithes it self off after some time
Av replaced the fun and its working ok but after the fun slows down or stops then it switches itself off after give like 10 minutes amtold its the timeming chip that has aa problem the problem is how can i locate it on the motherboard so that i can replace it. or give a another solution to this
  • Sony Master
  • 32,281 Answers
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Posted on Feb 16, 2012
How to fix the HP Laptop are shutting down by itself
Hi Walter, The link below is a YouTube video showing how to fix your lap top shutting down by it self, Also there's videos down the right side of the link that may help as well, By the way instead of using a straw I'd undo the back..........CHEERS..
Don panic Is your laptop shutting off by itself or slowing down during use
May 11, 2016 | HP Pavilion dv9000z Notebook
Heat Pump comes on, fans slow down, switches off?
Sounds like a bad temp sensor or switch. Like in cars my guess is that the switch is failing to work causing the fans to stop despite the pump getting hot.
Jun 23, 2014 | Aquacal ICEBRKR HEAT/COOL 110K TITANIUM...
2002 thunderbird window won't go up or down replace swith still wont work fuse are ok does the switch get power
The master switch connector does have circuits that have power on them. The Master switch is not directly connected to the window motors. The switch sends a signal to the Front Electronic Module and the module controls operation of the motor on the driver side. The passenger door window motor is controlled by a different module
Nov 28, 2012 | 2002 Ford Thunderbird
Dryer wont stop with stop button...still all lit up and jumps back and forth from 20 to 30 min
THIS SOUNDS LIKE IT IS THE SWITH ITSELF, BUT FIRST COMPLETELY UNPLUG THE DRYER, CGECK THE RECEPTACLE FOR THE RIGHT AMOUNT OF VOLTAGE, 110 ON EACH LEG, IF OK PLUG IT BACK IN THEN SEE WHAT IT DOES, IF THIS DOESNR WORK, I WOULD SAY YOU NEED TO REPLACE THE SWITCH THKS LARRY LET ME KNOW
Jun 07, 2010 | Kenmore Elite HE4 Electric Dryer
WIRELESS SWITH RADIO ON OFF IS NOT WIRKING
Does your computer have an ON/OFF button (or slider) for the wireless, and a separate ON/OFF button (or slider) for BlueTooth?
Try each of the 4 settings:
* OFF/OFF
* OFF/ON
* ON/OFF
* ON/ON
Click Start
Click Control Panel
Click Network Connections
Click with the SECOND (usually the RIGHT) mouse-button on the wireless-adapter.
Click ENABLE.
May 14, 2010 | Dell Latitude E5500 Laptop
Heater blower motor blows normal then slows down 1999 grand marquis
There is a blower resister within the blower fan that is replacable. Most likely this is the problem
Jan 04, 2010 | 1999 Mercury Grand Marquis
Couldn't Turn off my 96 Grand Marquis
Seems your ignition swith has come disconected from the key switch. The actual swith is not the key. The key links to a switch on top of the steering column down around the pedals. Or the switch itself is broken free. The switch is replaceable although a pain to access. No need to pull out the steering column. Good luck.
Jun 02, 2009 | 1996 Mercury Grand Marquis
Overheat?
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
Nov 27, 2007 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
