Question about Intertherm P3RA-036K Air Conditioner
Where is the Air Filter located on P3RA-036K?
This is an iutside unit. I have looked inside the Mobile Home and can not even locate anything but the Floor Vents and the Air Return Vent. I have a Filter in there but there shoiuld be one on the Unit, right? I bought this place used and there are no Owners Manuals. The Lady I bought it from was the 2nd owner and she bought it in 2005 and said she never changed anything except the Floor Air Return Filter. My Electric Bill is way high so I think there may be a problem. Anyone out there have any idea where this Filter may be locaterd? I looked all around the unit and all Panels seem to be permanent.
Thank you
  • PatMB Oct 25, 2008
    Thanks jasond1011 that reallyy helped, at least now I know I am not crazy
    Novelist:
  • 124 Answers
NO FILTER IN A PACKAGE UNIT EVER AT ALL AT ANY TIME. YOUR FLOOR GRILL FOR RETURN AIRT IS ALWAYS YOUR ONE AND ONLY FILTER LOCATION. YOU MAY HAVE A VERY DIRTY EVAPORATOR COIL ON THE INTAKE SIDE WHICH WOULD CAUSE POOR PERFORMANCE AND POOR AIRFLOW. HAVE AN AC CO COME OUT AND REMOVE THE LID AND INSPECT OR WASH THE COIL. YOU MAY ALSO BE LOW ON R22 . HAVE IT CHECKED WITH A GAGE. AS A GENERAL RULE PRESS LESS THAN 40 POUNDS EQUAL LOW CHARGE OR DIRTY COIL. 65 TO 70 POUNDS FAIRLY NORMAL. IT NEEDS TO BE 70 TO 80 DERGEES OUTSIDE AND INSIDE TO REFLECT THESE GENERAL PRESSURES. IF LOW ON R22 THEN A LEAK HAS DEVELOPED, USUALLY IN THE EVAP COIL.. BE AWARE R22 IS OUT OF PRODUCTION NEXT YEAR. STRONGLY CONSIDER NEW 410 REF UNIT BEFOR ESINKING A BIG CHUNK OF MONEY IN R22 EQUIP
Posted on Oct 25, 2008
I was changing the filter and unit came on and sucked the plastic bag down the hole.This is on a Mobile Home
The unit is more than Likely a package unit meaning everything is outside. So you can go to the unit, switch it off, and remove the top or a panel to get to the evaporator coil which is where it is probably sucked into now.
May 06, 2016 | Intertherm P3RA-036K Air Conditioner
No problem trying to find out tonnage i would like to know how big a unit i will need when i replace this
This unit is a 3 ton unit
P3RA-10 SEER
3, 4 and 5 Ton Units
Cooling: 32,500 to 55,700 Btuh
P3RA- Cooling Btuh SEER
036K 32,500 10
048K 45,500 10
060K 55,700 10
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 09, 2011 | Intertherm P3RA-036K Air Conditioner
WHAT IS THE WARRANTY ON THE P3RA-036K? I'VE BEEN IN MY HOME FOR 4 YEARS AND 7 MONTHS. I BOUGHT MY HOME NEW BUT IT HAD BEEN SITTING FOR ABOUT A YEAR BEFORE I BOUGHT IT. EVAPORATOR COIL WAS REPLACED ON...
it should be. but you would need to check with intertherm they make that call. most unit come with a minimum of 5 year parts however who ever put it in and the dealer make final call so its to gray to say sorry if you explain your concern to intertherm they may give you an extended warranty it happens sometimes if customer feels cheated please give me a rating and vote
Sep 21, 2010 | Intertherm P3RA-036K Air Conditioner
I have a Intertherm outside AC & it was put in when the mobile home was built(1982) and I do not know what it is, I only can find the name of the manufacture, where would I find the model, & other...
mobile homes have split units, I would check the unit inside to see if it has any information. I would check all breakers inside and out, and thermostat. Hopefully it will be something simple. Good Luck Tim
Aug 09, 2010 | Intertherm P3RA-036K Air Conditioner
Where can I find a wiring diagram for a interrherm
Hi; Call Your local mobile home supply house and they can tell You how to or fax You the Info. Also the equipment will have the wiring diagrams glued to the inside covers of the outdoor unit as well the indoor unit cover. Power down the indoor unit before removing the indoor electrical cover for the schematics. Do You not have a user or install manual. Call your local mobile home supply house they can often help.. Be care full You get more bees with honey so be very nize...alpharome416
Feb 19, 2010 | Intertherm P3RA-036K Air Conditioner
Where can I purchase the filters for model#C3QA-042U
This looks like package type unit. your filters should be located inside the home where ever the air return is. You can find most any size filter at any home improvement store or locate a Baker Distrib. company branch and buy by the case. Steve
Jul 12, 2009 | Intertherm P3RA-048K Air Conditioner
Size
Greetings jdreisbaugh,
The tonnage is usually found on the name plate on the condensing unit outside. 12000 btu = 1 ton, 24000 = 2 ton and so forth. In your case the unit is 36000 btu, therefore a 3 ton.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jul 24, 2008 | Intertherm P3RA-036K Air Conditioner
Vent ducts
Try to match the original ducting. Other than that, any ducting material will work, including the the thin aluminum piping sold for dryer vent.
Jun 24, 2007 | Intertherm P3RA-036K Air Conditioner
Intertherm P3RA-036K Air Conditioner Logo
145 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
