Question about Electrolux Refrigerators
Electrolux fridge freezer keeps creating water in the bottom of the fridge
  • Electrolux Master
  • 4,655 Answers
Your freezer most likely has a blocked freezer condensate drain. Click Here=> Leaking Refrigerators Just What may Be Happening
Much more on this page=> Leaking Refrigerators!
Thanks Sea Breeze
Posted on Feb 16, 2012
SOURCE: FF200EP Fridge Freezer - water
I had the same problem, the fridge would leak overnight (usually) I found with some more searching the answer..... try it at you own risk!
Here are 2 detailed answers depending on your circumstances/technical ability....Turn off fridge....
1. Defrost fridge...catch all the water
or
2. Work quickly....
Remove drawers, at the back of the fridge there is a panel with 5 phillips screws (note that there are long and short screws). Remove the screws and the panel. (if you chose the second option then this will be "frozen in place" so you will get crunching noise when you peel it away - so be careful when removing it). At the top of the panel is a connector that powers the fan, squeeze the 2 sides in to remove. This will allow the panel/ducting to be removed from the fridge. (If you chose option 2 you will now probably see a large lump of ice over the drain hole).
Remove ice or debris from drain hole, re-asssmble not forgetting to connect the fan again!!!) then repower the fridge following the instructions as you will get the alarms... the fridge cools and the warning lights dissapear.......24 hours on mine is OK!
Mal Function
Posted on Dec 28, 2008
SOURCE: fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Posted on Jun 23, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Posted on Apr 28, 2009
  • 72 Answers
SOURCE: Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Posted on Jun 17, 2009
  • 111 Answers
SOURCE: water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Posted on Jun 18, 2009
Can I turn off the freezer but not the fridge on my electrolux french door bottom freezer refrigerator
Unfortunately, the lower frizzer is connected straight to the primary engine. It can't be turned off, unless you turn off the whole fridge. I know, it will be smart for Electrolux to allow that option at a consumer's discretion: to be able to turn the bottom fridge on/off.
Aug 09, 2014 | Electrolux Refrigerators
From the top compartment water is dropping and leaking out of the fridge.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 16, 2011 | Electrolux ER7626B Bottom Freezer...
I have an Electrolux EW28BS71IS and I have water dripping from the ice maker. When I take the ice maker tray out it has water sitting in the bottom of it. I can't tell if it might be overfilling the...
i have an elecolux ice maker leaks water into the bottom trays from the back of the fridge and water always drips from the front dispenser. the ice freezes in a solid block can anyone help me please. ew23bc71is3 is the model double door freezer on the bottom tks.
Mar 31, 2011 | Refrigerators
Water on floor beneath aeg/electrolux upright fridge freezer [freezer at bottom
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | Refrigerators
Leaking water inside bottom of fridge, fridge not keeping a cold
Sounds to me you are having a ice blockage and or defrost problem. When that happens water can not get outside of the refrigerator. If you look inside the rear of freezer you may see a frost line or layer building on rear panel. You may just need to begin manual defrost until we can get a look at the evaporator coils and condensate collection tray. Unplug and begin and let me know your model number. I can help if you like, Sea Breeze
Mar 19, 2010 | Refrigerators
I have a Electrolux Frdige Freezer Model ERF 2830.
check appliance blog .com and type in your make/model,sometimes there are fixes on there
Nov 01, 2009 | Refrigerators
My freezer is still freezing but the fridge is not cold. You can hear it running but nothing. HELP!
is the fan running in the freezer? if not replace fan .if not unplug fridge,,remove all inside pannels in freezing unit,,in the bac ,in the middle, on the bottom ,there is a drain that drains into the very bottom of fridge,is it like aice bottom across the bottom of the freezer?if so,use hot water to defrost all the ice and may be a hair dryer,water will melt and **** down the drain threw the drain tube,to the bottom of fridge into a shallow pan under the fridge,that slides out(could be messey).clean all bottom of freezer out good(crumbs mostley)that stop up drain and pour water threw drain a few time to clear drain good.reasemble and ur good to go.now if there is no ice and drain is good,you might find ice on coils,this means ur defrost timer is most likeely gone out ,just replace timer
Jul 04, 2009 | Electrolux Refrigerators
Whirlpool fridge getting water from upper freezer compartment
well if you hat the freezer on top normaly air leaks inside freezer through the drain tube, that air turns into condensation and creates a ice and cloges your drain. now water can drain down to pan everytime ref goes into defrost , and water leaks to bottom section to air ducts and air returns. there are several ways to solve this problem the cheapeste way is to unplug refrigerator for 2 days then plug back up and it should go back to normal another way is to install a heat probe on your drain attached to your defrost heater , and add a grommet on drain tube that will let water drain but it will keep air out and that will solve your problem.
Oct 12, 2008 | Whirlpool Refrigerators
I have an electrolux Aeg santo fridge freezer. Frost free. There seems to be water leaking from the bottom.
remove back plate inside freezer. there is a drain tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely. check drain tray heater is ok as well
Oct 08, 2008 | Electrolux Refrigerators
Refrigerators Logo
660 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
