Question about Gateway Computers & Internet
No longer able to access my external hard drice
Hi there, 1. I have had this external hard drive working for some time. 2. Not sure if this is the cause of the problem, but recently bought a USB component for reading my digital cameras memory card. 3. While transferring photos from the memory card to the external hard drive I noticed a slight error when one of the images could not be saved. 4. The hard external hard drive at this point could still be accessed 5. The next day, attempted to transfer more pictures to the external hard drive, this time none of them could be transfered? 6. Now I can no longer access my external hard drive 7. The hard drive is recognised and listed within Windows 7 file manager, but when you attempt to open/view it you get an error message? Any ideas what might have happened, or if there is a way of making it work again and not loosing any data from the external hard drive?
  • Kevin Trainer Feb 15, 2012
    Thanks mate, i'll give one this a try.
  • Kevin Trainer Feb 16, 2012
    Novelist:
    Champion:
  • 224 Answers
From your description it sounds like your drive has developed a case of bad sectors. It's a common problem.
I would suggest http://www.r-studio.com/ if you want to try recovering the data yourself.
Or have the guys at http://FreeDataRecovery.us take a look at it for you. They operate remotely over the Internet and work off of donations.
Posted on Feb 15, 2012
My hp SimpleSave have been working fine until this morning. I plugged in the power and the USB cable now its taking a long time for the computer even recognise the external drive even after it registers...
There are two possible causes for what you're describing. Either the disk drive inside the enclosure is dying/dead, or the circuitry inside the enclosure is having problems. The only way to know for sure would be to open the enclosure and remove the drive. With the drive removed, you can either connect the drive to a computer using a SATA cable directly or using a SATA to USB dock. Or you can try another hard drive with the enclosure to see if it has the same issue.
Feb 28, 2011 | HP SimpleSave 1 TB USB 20 Hard Drive
Windows 7 states external drive 'malfunctioning'
you got two possiable issues here.
1. The ac apadtor not suppling enough power to the hard drive.
2. The USB controller insdie is faulty.
I have a solution for you. Take the hard drive out of the unit (if you care about your data)
1. put it into another external case witch are sold for under $15.00 at amazon.com or simply plug it into your desktop inside vai your SATA controller. If you have a laptop of course that will not work you need to then purchase a external enclosure.
Click HERE for my tip and video on how to get your SATA drive out of its case.
We work for your ratings so please before you leave the site be sure to leave you feedback and ratings today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 01, 2010 | Western Digital My Book Essential Edition...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard disk not detected sometimes
I can think of 3 possible causes to your problem:
1. Faulty cable - try replacing the cable by borrowing a working cable from a friend. If this solves the problem then you need to buy a new cable
2. Lack of power - some USB drives especially those for high capacity drives require extra power aside from that provided by USB. If you do not have a separate power leading to your drive, check if there is a separate power slot and run a cable from it to your outlet/USB slot. Just make sure that the voltage levels are correct.
3. USB Slot - some laptops' USB slots do not produce power enough to drive a hard disk. Other devices may work (e.g. keyboards, mouse) but not hard drives. Try to use another slot in your laptop. If this works, remember to use the same slot next time.
Hope this helps.
NOTE: Please rate our help to keep this free service online
Jan 08, 2010 | Western Digital External USB 2.0 80 GB...
USB External Harddisk Detection Problem
some people say that its because of not enough power . try inserting the hard disk in other usb slots ( at the back ). onlu usb slots at the back of my pc detects my hard disk
Aug 06, 2009 | ASUS M2N-MX Motherboard
I require a driver for our Beyond micro external hard drive.
It looks as though there is no driver support for beyond micro although the specs state that the drive is plug and play. which means you just plug it in and windows sets it up. other than that there are no software or drivers for it.
best of luck.
hope this helped.
please remember to rate me.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 02, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Hi, I recently bought your 750GB My Book external drive, which I have connected to a Macintosh G4 desktop computer.  The computer does not recognize the external drive now, although I was previously able...
Be sure to plug the USB connector and the back of the CPU. Then go to Application folder if your running on OS X. Locate the disk utility, then double click it and see if your external drive have been detected. If it is detected try to repair it. and then thats it
Dec 07, 2008 | Western Digital My Book Premium ES...
Simpletech 500 gig usb plug in hard drive
Is the drive running when connecto to power ans PC?
Try it on another PC.
Check the power supply if it is operated from an external power supply.
It it is self powered via the USB then this is a possible problem- the PC power supply cannot cope - Removing other USB devices may help here
Feb 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
226 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
