SOURCE: Removing Numbers from Reject list Samsung u900
Main Menu> Settings> Call Settings> All Calls> Auto Reject> Reject List> Delete the number out of the list.
Adam
SOURCE: accidently add number in reject
Go to settings = application settings = call = all calls = auto reject = reject list
SOURCE: remove no from reject call list
From page 83 of the manual...
At "idle" screen press menu key
Go to "Settings" and select
Scroll to "call settings" and select
select "all calls"
scroll to "auto reject" and select
At this point you can go under "Activation" and turn the feature on or off.
or else...
scroll to "reject list" and select
Here you can add, remove, or edit numbers to reject.
SOURCE: cannot bring up call reject list on samsung sgh-a707
Menu
Settings
Call Settings
All Calls
Auto Reject
Reject List
Press center key
Scroll to number
Options
Delete
SOURCE: removing numbers from reject list in samsung f480
Goto
Settings-->Call settings-->All calls-->Auto reject
Click on 'Reject list'
Here just for making them to be receivable calls, uncheck them
If you want to completely remove, you need to click on each entry and then press Options-->Delete. But the problem with deletion is you need to do that for each entry separately.
