Question about Taylor 5757 Digital Glass Body Fat Scale
TEC 21 SL calibration - Taylor 5757 Digital Glass Body Fat Scale
  • John Taylor
    John Taylor Feb 15, 2012
    when switch ON the Scale dose not become zero,the LCD display dose not show 00000 00000 but 88888 88888 and the Key not work
    Please help me to find the solution to this problem . 000000 888888
    Thanks .
    New Friend:
I have a tech sl 21 on the start up the number displays just keep flashing and it wont stop help please
Posted on Nov 01, 2016
95 accord error code check engine code 21
This code is for a V-Tec valve control failure, which is why it doesn't come on until you hit 4200rpm. That's when the system activates. Check your connections at the V-tec solenoid/valve on the back of the head. You'll likely see it leaking quite a bit of oil leaking down the back of the engine from it. Don't bother messing with it, replace it. And don't use any kind of additives in your oil. (Slick 50, etc) These products notoriously clog the V-Tec valves. Good luck!
Apr 02, 2014 | 1995 Honda Accord
Paper gap sensor
Ok, this is easily solved in 3 different ways
1) Driver: Download the greatest driver I know, the one developed by the NiceLabel guys: www.nicedrivers.com
you need to go on right click in te driver(Start/Control panel/TEC Toshiba...) choose properties. In options you will have the chance to verify the gap mode(continous/black mark/ etc). You can also calbrate your printer from there.
2) If your printer needed to calibrate, turn-it off, then, by holding the feed button, turn-it on and let go after 3 seconds, or after you see a light. It will calibrate automatically with your label size at that moment, it may also print the printer settings, so be prepared for stoping the baby.
3) If you have a barcode software(did i say I reccomend NiceLabel?), you can set the instructions on 1) directly from printer settings.
Good luck, peace.
Aug 14, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
I keep getting a Paper Jam message even after calibrating many times. Am using continuous roll of 1 X 4 lables. Was working fine until I tried to print another set of lables. What Gives? Am using a...
2 x possibilities.
1. sensor may need moving to to see label edge (green knob at RHS)
2. possible sensor faulty. Only testable by substitution.
Jul 06, 2011 | Toshiba TEC B-572 Printer
Barcode printer type: TOSHIBA SX4 sensor setting for thermal transfer / transmissive error msg paper jam. how to see the sensor?
Diagnostic boot
Feed PAuse button pressed and switch on Keep button prressed until message (1)Diag ...
with feed goto 5 sensor adjustements.
Pause to enter the menu
select the sensor you want to calibrate!.
Feed or restart button for 5 seconds until a star appears.
Switch off and on the calibration is stored in Eprom
Feb 10, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
My scale starts out with 7.2 instead of 0.0
try removing battery if this does not work you have a faulty weight sensor
May 10, 2010 | Taylor 5757 Digital Glass Body Fat Scale
Imprimante bsa4 tm ne detecye pas echenillage
Quelle erreur est que tu as a l'ecran? Si tu as l'erreur PAPER JAM, tu as de calibrer la machine. Dans l'USER MANUAL tu as une explication pour faire la calibration. Tu peux suivre cet link
http://www.fixya.com/support/t588560-need_calibrate_sx4.
Excuse-moi pour mon français. J'espère qu'il marche.
Nov 30, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
How do you calibrate a TEC b472
http://www.fixya.com/support/t588560-need_calibrate_sx4 (send by pkwc)
Oct 12, 2009 | Toshiba TEC B-472 Thermal Label Printer
Taylor 5757 Digital Glass Body Fat Scale Logo
495 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
