Question about Logitech V470 Cordless Laser Mouse for Notebook
Mouse will not pan in mastercam using the wheel
My screen appears to be 'zoomed in' note that this is not a resolution issue nor is it just a web browser page that i have zoomed in on using the mouse wheel. My screen was zoomed when the log in screen...
This sounds as if you have the magnifier on if you are using Windows. What the magnifier does is just what you are describing. It zooms in on part of the screen and lets you pan around the screen when you move the mouse to the edge. Unfortunately, I do not know which version you have. If you have XP, you can view this webpage for specific instructions: http://www.microsoft.com/windowsxp/using/accessibility/magnifierturnon.mspx.
If you have another version, to change it, click on Start Menu>Programs>Accessories>Ease of Access. It should be found there. Once you open it, you should be able to turn it off and go back a normal screen.
I hope this solves your problem. Let me know if it does not.
Apr 02, 2011 | Computers & Internet
Wheel settings
you the lock the scroll.
Jun 19, 2008 | Logitech Cordless Mouse
Can not get Microsoft 5000 wireless mouse to Pan in AutoCAd 09
Do you use the "hold middle click" way of panning? If so, check that in the Windows Ctrl Panel under Mouse, that the scroll wheel is set for middle click. Why this is not default on all new mice I do not know!
Aug 09, 2010 | Microsoft Wireless Laser Mouse 5000
The middle wheel does not work as a pan option in my AutoCAD 2002 program . Run in vista. Dell mouse SN-H100009B
In your control panel in windows under your mouse options. Make sure that you have the middle options button selected. It could be windows vista has not select it.
Dec 04, 2009 | Dell U0636 Mouse
I am installing mastercam v9.1 having trouble installing softwar
Disc drive or the disc is fu.k.d up.  Go online and download the driver to your desktop or USB flash drive and install that way.
Nov 18, 2009 | Computers & Internet
Cannot use centerscroll wheel to click and pan
Your scroll mouse may not have a button built into the wheel.
Do try to push down on the wheel, though. Most (quality) modern mice have a button built in below the wheel that just takes a little extra pressure to use.
Sep 29, 2009 | Dynex Wireless Optical Mouse
Mbj58 wheel mouse curser wants to go all over screen
Hi a. Have you tried another mouse and
b. Are you using a glossy or prismatic mouse mat? Try using a different one or a sheet of A4 and see if this fixes it
hope this helps Mark
Aug 22, 2009 | Logitech Wheel Mouse Optical
I cannot pan with the mouse in Autocad or Revit.
Go to START > CONTROL PANEL > MOUSE ..... Here you will find the Logitech settings. On the BUTTONS tab, you will see a diagram that numbers the buttons on the mouse as well as a table that shows what each button is assigned to. In this table, double click the number assigned to the mouse wheel (usually button 3) and reassign the wheel to MIDDLE BUTTON. This should restore your Autocad pans.
Dec 08, 2008 | Logitech Cordless Wireless Optical Mouse...
Microsoft wireless laser mouse 5000
Assign a keystroke to the mouse, in this instance I assigned 'p' for pan (as per the .pgp file short cuts etc) against the scroll wheel click.
Click the scroll wheel, 'p' comes up on the cad screen, right click to confirm then the pan icon appears, hold the left mouse button and drag at your leisure. Yet to find a fix for Inventor.
Not ideal, but better than nothing at presnt.
Jun 08, 2008 | Microsoft Wireless Laser Mouse 5000
Google Earth
I have a LX5 cordless mouse that was part of my S510 desktop set. Prior to this set I had a seperate USB keyboard and generic optical usb mouse. I noticed after installing the SetPoint software that i lost all use of the middle mouse button. Here's how you can restore the use of the middle button. SetPoint reassigns the middle button so that it no longer functions as the default middle button function. This can be changed in the SetPoint configuration. (Look for the icon in your system tray) Click on My Mouse and select the middle button. It's number 3 on my list and was originally titled zoom, but, clicking on a button name will give you a picture of the button location on the picture to the left. Once you locate the middle wheel button, in column next to the list, under select task, select other, then from the drop down list, select middle button. apply and save your settings by clicking ok. pan and tilt will now work properly in google earth.
Jun 13, 2007 | Logitech MX1000 Laser Cordless...
Logitech V470 Cordless Laser Mouse for Notebook Logo
364 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
