Question about Panasonic GigaRange KX-TG5432 Cordless Phone
Phone beeps all the time, no range capability
I just got a used, supposedly factory refurbished Panasonic phone system of this type with three handsets. The main phone beeps repeatedly when just sitting in the cradle. The other problem I have is the phones have almost no range. I see no reason to have three handsets if they have to be in the room with the main base. Is there something I can do to make the range farther?
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: DeRegistering a Damaged Cordless Phone????!!!!
If you are still looking for an answer on dereg of a handset, the manual says Menu - 0-0-2 then 3-3-5-OK then select the handset you want to cancel/deregister
Posted on Feb 17, 2008
SOURCE: Panasonic KX-TGA101S base not charging.
PyroPC Man is right! Thanks!
Posted on Mar 18, 2008
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
SOURCE: new expansion handset doesn't recognize base-station
Unplug the base for 1 minute to reset system.
Posted on Feb 16, 2009
Panasonic phone model kx-ts108w how to change emergency to a new number on this phone
Page 20 in the manual
ftp://ftp.panasonic.com/telephone/om/kx-ts108_en_om.pdf
PDF]Operating Instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/telephone/om/kx-ts108_en_om.pdfIntegrated Telephone System. Model No. KX-TS108W. Pulse-or-tone dialing capability. Operating Instructions. Preparation. Basic Operation. Advanced Operation. Useful Information. PLEASE READ BEFORE USE AND SAVE. Panasonic World Wide Web address: http://www.panasonic.com for customers in the USA or ...
20
Storing Phone Numbers
You can store up to 20 phone numbers in the one-touch auto dial buttons
(10 numbers in UPPER memory locations, 10 numbers in LOWER
memory locations).
Make sure that a call is not put on hold.
To store in an UPPER memory location
It is recommended that you program an emergency number in the
EMERGENCY button.
Press
(PROGRAM)
Enter a phone number, up to 22 digits.
If you enter a wrong number, press
(PROGRAM)
and start again from step 1.
Press one of the one-touch auto dial
buttons.
A long beep sounds.
The unit will return to the standby mode.
If 3 beeps sound, the number entered in step 2 may be over 22 digits.
Press
(PROGRAM)
to return to the standby mode, and start again from
step 1.
If a pause is required for dialing, press
(PAUSE)
where needed. Pressing
(PAUSE)
counts as one digit (p. 24).
When using the Dial Lock (p. 27) or Call Restriction feature
May 01, 2018 | Panasonic Lands Phones
How do I change the ring back to a longer time.
The installer sets that amount of time in the main system box. For business it's typically set for two minutes (129s) or three minutes (180s), for residence it's usually set for more time, three or more minutes. Panasonic calls it the "Hold Recall time." It's not set in the phone, it's a system wide setting.
May 05, 2014 | Panasonic KXDT343 Phone
Unable to reset nokia 3120 classic to factory reset It asks for creating new code accepts no code
Dear murari_verma
Type default code as 12345. I think this will solve it. Otherwise you have to change the software for that you should go to a service shop.
Mar 03, 2011 | Nokia 3120 Cellular Phone
Trying to connect my nokia N71 to my toyota kluger system. The bluetooth connects for about a second and then cuts out. I rang toyota and they explained I must update my phone using "patch...
Just follow the steps
Take a full backup.
First Try it:
You may try default phone and security code to remove it
Defalt phones codes is 12345 or 00000 you can use it
if the problem is same do the next,
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
If
Soft reset( factory setting)
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
Mar 03, 2011 | Nokia E71 Smartphone
I cannot get the default security code of nokia 5310
Take a full backup.
First Try it:
If
On Sybmian phones:
Hard reset
Remember.
Hope this helps.
Feb 25, 2011 | Computers & Internet
How can full format my nokia 5200 mobile
Take a full backup.
First Try it:
If
On Sybmian phones:
Hard reset
Remember.
Hope this helps.
Feb 19, 2011 | Computers & Internet
How can I clear the previous registrations from the TRU 9485 base?
Use the following steps to reset the base to factory settings for all TRU models:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep).
According to Uniden Tech support, this is supposedly all it takes to reset the phone.
Aug 12, 2009 | Uniden TCX905 Cordless Accessory Handset...
Ringing everywhere
If it used to work and stopped, I'm guessing the system is no longer in the DAY mode. Each system tends to program differently and the 7730 phone can be plugged into one of about 18 different Panasonic systems.
From the main phone, try dialing 780#. If it beeps and says DAY MODE, it was the right command :-) Now test the lines and see if that fixed it.
If it doesn't work, please go to the phone closet/back room/attic/whatever and grab the model number of the phone SYSTEM and post back.
Carl
May 11, 2009 | Panasonic KX-T7730 Corded Phone
Voice Mail drops last of message and cannot listen entirely
It's possible the system thinks the caller has completed the message because they make a long pause in what they are saying. OR does it ever cut them off in mid sentence? Do you use standard copper lines or are you on a VOIP network such as a cable provided phone line? Some VOIP lines produce slightly different voltage levels, ring signals etc.. and cause problems with sensitive equipment like this system. On these codes that Panasonic had you change. Were they A/B on/off etc.. or was there a range (like 1-10) and you can try a setting in the middle somewhere instead of just 1 or 10. The older system had a phone line setting of A or B. The default was A but often changing them to B made a difference on certain types of phone lines. Panasonic probably had you change this (if the same feature is available on the 4500) but if not, and it's there try that.
Oct 06, 2007 | Panasonic KX-TG4500B Phone
Panasonic GigaRange KX-TG5432 Cordless Phone Logo
47 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
