Here are some steps you can try to clear the problem:
Check the Label Tape: Ensure that the label tape is properly installed and correctly aligned in the label printer. Sometimes, an improperly installed label tape can trigger an error message.
Check for Paper Jams: Open the label printer and check for any paper jams or obstructions that might be causing the error. Clear any jams or obstructions you find.
Replace the Batteries or Use AC Power: If your Casio KL-60 label printer is powered by batteries, try replacing the batteries with fresh ones. If you're using AC power, make sure the power adapter is working correctly and properly connected.
Perform a Soft Reset: Turn off the label printer and unplug it from the power source (if applicable). Wait for a few seconds, then plug it back in and power it on again. This can sometimes resolve temporary issues.
Check the User Manual: Consult the user manual or troubleshooting guide that came with your Casio KL-60 label printer. It may have specific instructions for troubleshooting error messages.
Factory Reset: If the error persists and you have tried all other steps, you may need to perform a factory reset to restore the printer to its default settings. Keep in mind that a factory reset will erase any custom settings you may have made.
Hi, If you can't get it to work, try to do a factory reset.
Turn the unit off, then Hold the PRINT and ESC key down and then Press the power button. KEEP HOLDING THE Print and Esc key down for 2 seconds and then release both of them. You should see a message in the display INT?, Press SET to Reset your printer, or Esc to cancel.
Hope this helps.
Mac =)
Hello, If you can't get it to work, try to do a factory reset.
Hope this helps.
Best wishes
Mac =)
to reset memory
1. Make sure that label printer is off
2. While holding down the PRINT and ESC keys, press ON?OFF to power on.
3. KEEPING PRINT and ESC held down, release the ON?OFF key only.
4. Release PRINT and ESC keys.
5. Press SET to initialize the Label Printer or ESC to Abort
