Question about Samsung NP-NC10-KB02US 10.1 inch Netbook Carrying Case (Cube Shell - Pink) (894581907748)
Windows cant start as file missing or corrupted
Cannot access anything message on screen is windows could not start because the following file is missing or corrupt windowsroot \system32\ha1.d11. how do i reinstall
No big deal about that just get d operating system installation CD u are using, insert it and go to d C Mos environment when u are there set the first and second boot device to be CD or DVD ROM and the third to be hard disk then pres Y on your keyboard.d CD wil go inside the CD ROM it display some intructions, follow d instructions carefuly anyone you don't understand contact us back. when u get to d stage it ask if u want to repair or format choose repair then wait 4 it and after restart and that is it.
Posted on Feb 15, 2012
I cannot boot up my Microsoft Windows 7 due to a corrupt ntfs.sys file. I can access command prompt through computer or cd. Please help!
As you are able to access command prompt, you can run the "System File Checker" tool to repair/ replace the corrupted ntfs.sys file. To do this, follow the instructions below:
1.Restart your system and tap F8 key repeatedly until you see Advanced Boot Options menu on your screen. If you miss reaching the screen in the first attempt, repeat this step until you reach the screen.
2.On the Advanced Boot Options screen, select "Safe Mode with command prompt"
3.In the command prompt window, type "SFC /scannow" (without quotes).
Note: There is a space between C and / in the command above.
This will scan all your protected system files and replace the corrupted files with a cached copy stored in your system.
Important: Please do not close the command prompt window until the verification is 100% complete. After the process is completed, the scan results will be displayed on your screen.
To know more about System File Checker, you can refer to the following Microsoft support page:
http://support.microsoft.com/kb/929833
Hope this will help you.
GuruAid.com
Aug 17, 2014 | Computers & Internet
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
Ntfs is missing
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
I have a asus eeepc 900 netbook.suddenly it stop booting & everytime showing"windows could not start because the following file is missing or corrupt:Windows/system32/config/system.You can attempt to...
/WINDOWS/SYSTEM32/CONFIG/SYSTEM
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM
Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
Jun 15, 2010 | ASUS m6n Notebook
Windows setup using the original CD-ROM
you have to re install the copy of the file missing, if you do not re install this file. you wont be able to install windows. you need to re install this file to avoid this messages, you a have a windows installation disc have a copy install to your pc
Nov 25, 2009 | Toshiba Satellite Pro L300 Notebook
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
Apr 08, 2009 | Acer Aspire 5610-2328 Notebook
Laptop won't start up in Windows due to a missing or corrupt file
No all you have to do is follow its instructions and use the Windows XP cd and during startup boot to the cd and during installation choose the repair option.
This will not make you lose any files and then you will be able to get in and back to work or whatever it is for again.
Dec 18, 2008 | Toshiba Satellite A100-S8111TD Notebook
Samsung NP-NC10-KB02US 10.1 inch Netbook Carrying Case (Cube Shell - Pink) (894581907748) Logo
78 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
