Question about Toshiba e-Studio 161 Copier Copier
E_studio 161 cannot copy on the middle
Copier cannot copy in the middle of the paper, i clean laser unit, we put developer and there is no image on the drum
  • lavert Feb 17, 2012
    when i make copy from a4 paper copier can only copy information from top and bottom, the middle information does not appear on copy paper, i clean laser unit, i put new developer the problem continue
    New Friend:
  • 10 Answers
Did you clean the scan unit (the mirror)
Posted on Feb 17, 2012
  • 653 Answers
SOURCE: c46 appeared on my toshiba e-studio 550 copier
C46 indicates Abnormal pressure roller thermistor during a ready state.
Perform following inspection:
1.. Clear the status counter.
Change the current status counter value (08-400) “3” or “8” to “0”.
If happen again, perform following inspection:
1. Check the pressure roller thermistor.
(1) Check if the connector is not disconnected.
(2) Check if the pressure roller thermistor closely touches the surface of the pressure roller.
(3) Check if the harness of the pressure roller thermistor is not open-circuited.
2. Check the LGC board.
(1) Check if the connector J334 is not disconnected.
(2) Check if the conductor pattern on the LGC board is not short- or open-circuited.
(3) Replace the LGC board.
Posted on Mar 05, 2009
  • 5 Answers
SOURCE: Developer leakage while copying
after replace  developer you dont turn round the developer wheel left side. only right side.try this take out the developer and after re fill in to the developer unit. and u change the main charger unit also.
Posted on Mar 22, 2009
  • 653 Answers
SOURCE: Can't print or copy with my toshiba e studio 161
H2 indicates thermistor open.
U can enter simulation mode and input "14" to clear the message.
If happen again, u need to check following:
Thermistor
Control PWB
Fusing section connector disconnection
The fusing unit is not installed.
Perform the following procedure to enter the simulation mode.
"C" key AUTO/TEXT/PHOTO key
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
Posted on Apr 06, 2009
herminio_hal
  • 210 Answers
SOURCE: konica 1212 - no image on the copy, but copier run properly
this is might be simple solution check how you place you original to Document feeder it should be face up not face down. The transfer/separation corona is not install properly, drum carriage is not install and the locking screw is not screwed in. the last thing my question is did you completely run out of toner? If you did you have run 75 copies before the toner mix in to the developer. there is a shorter way to add toner to the developer but I can not tell you how not unless you are a copier tech.and you should have a extra developer with you in case the developer is over tone. HH
Posted on Aug 10, 2009
  • 4 Answers
SOURCE: how can download drivers for windows 7 for Toshiba
www.eid.toshiba.com
Posted on Nov 26, 2010
When copying i have a shadow in background
Check copy life of consumables like Developer and Drum if ghost image might be Cleaning Blade found Imagaing Unit or Upper Fuser at Fusing Unit. If replace the whole imaging unit can solve your problem but individual parts try to clean first imaging include charge roller before you replace drum, cleaning blade and developer. mostly we replace developer only.
Mar 06, 2015 | Ricoh Aficio 1013 All-In-One Laser Printer
I have bizhub c450 , printing time devoloper comin on edge of paper , my imaging units are nes
Removed all imaging unit then below you will see PCL in every imaging unit you must clean it with soft cloth completely. When PCL is covered with dust,toner,dev etc.. the developer from your imaging unit become to fall causing developer on edge of paper(dirty copies).
Dec 26, 2014 | Konica Minolta bizhub C450P Laser Printer
Why does my toshiba e-studio 161 prints black?
The scanner unit is damaged. Check for busted exposure lamp while making scans. There should be light on the glass where you put the original copies while scanning for copies ..
Jul 22, 2014 | Toshiba e-Studio 161 Copier Copier
Toshiba e-studio 161 developer low functions reset code
Sir, i added new toner and new developer but my printout is dull. What i do?
Nov 18, 2010 | Toshiba e-Studio 161 Copier Copier
Feb 06, 2009 | Toshiba e-Studio 161 Copier Copier
COPY IS NOT GOOD....
weast toner is not go properly.or paper jam in drum unit or paper dust clean in drum unit.
Jul 24, 2008 | Toshiba e-Studio163 Copier
Toshiba e studio 161
already paper jam in feeding assembly so please check any paper jam.or lubricate all drive gears
Jul 08, 2008 | Toshiba e-Studio 161 Copier Copier
Copy quality
Try cleaning the laser.
Jul 02, 2008 | Toshiba e-Studio 161 Copier Copier
Toshiba e-studio161 Developer
Technical Service Procedure
Correct procedure for service of TOSHIBA e-Studio 161
When the spanner light and the developer (sun) light are illuminated it is time for a service.
* Try and run the PM Service and drum life counters together.
* Part that are required for a 50,000 copy service (OD 1620 DRUM, D1620 DEVELOPER, BL1620D DRUM BLADE)
* Clean and inspect drum unit.
* Clean all optics and glass.
* Clean and rewire transfer corona.
* Clean and check main charge needle electrode [saw tooth]
* Clean and check fuser units including blades, rollers and scraper fingers.
* Clean erase lamps and ozone filters.
* Clean and check all feed rollers.
* Clean machine inside and out.
* Replace the required parts.
* Reset mini maintenance counters:
* [CLEAR] > [EXPOSURE] > [CLEAR ]> [EXPOSURE] and the machine will die.
* Input [20] [START] [01] [START]“000””000” will flash on the display.
* Reset the drum life counter:
* Input [24] [START] [07] [START] "000"000" will flash on the display
* Reset developer life counter:
* Input [42] [START] [01] [START] “000””000” will flash on the display.
* Once all the part have been replaced and the counters been reset, check the copy quality.
* Notes: Application of the patting powder is for reducing the friction between the drum and cleaning blade. If the application of
patting powder is neglected, the drum and cleaning blade may be damaged. Please clean off the patting powder before putting the
cleaner unit into the machine.
Developing doctor gap adjustment
1) Loosen the developing doctor fixing screw A.
2) Insert a thickness gauge of 1.5mm to the three positions at 20mm and 130mm from the both ends of the developing
doctor as shown.
3) Push the developing doctor in the arrow direction, and tighten the developing doctor fixing screw. (Perform the same
procedure for the front and the rear frames.)
4) Check the clearance of the developing doctor. If it is within the specified range, then fix the doctor fixing screw with
screw lock.
* When inserting a thickness gauge, be careful not to scratch the developing doctor and the MG roller.
CHANGING A TRAY’S PAPER SIZE SETTING
Follow these steps to change a tray’s paper size setting.
* The paper size setting cannot be changed when the machine has stopped temporarily due to running out of
paper or a misfeed, or during interrupt copying.
* During printing (even in copy mode), the paper size setting cannot be changed.
* A5 (ST) size paper can only be selected in upper paper tray.
* Do not load paper that is a different size than the paper size setting. Copying will not be possible.
Hold down the [PAPER SIZE ENTER]
key for more than 5 seconds to
set the selected paper size.
The currently selected
paper feed location
indicator will blink and
the corresponding paper
size (which is currently
set) indicator will light
steadily. All other
indicators will go out.
If the machine has two paper trays,
use the [TRAY SELECT] key to
select the paper tray for which you
wish to change the paper size setting.
Each time the [TRAY
SELECT] key is
pressed, a paper tray will
be indicated with a
blinking paper feed
location indicator.
Use the [ORIGINAL SIZE ENTER] key
to select the paper size.
The indicator of the
selected paper size lights
up.
Apr 11, 2008 | Toshiba e-Studio 161 Copier Copier
Unsolved fault
check all your paper cassettes and make sure the paper isnt jammed in there or that it is installed properly
Jun 19, 2007 | Toshiba e-Studio 350 Copier
Toshiba e-Studio 161 Copier Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
