Question about Dell Dimension 3000 PC Desktop
Cannot detect my usb mouse in Windows XP - Dell Dimension 3000 PC Desktop
  • 22 Answers
Did you UN-installed the USB mouse driver in the device manager?
If not to this.
Are you using a USB mouse ?
If yes :) update the driver using the device manager
If no now using PS2 :) update driver using device manager, and select the ps2 mouse driver.
Posted on Feb 15, 2012
How to download software of mouse and keyboard for windows xp
if you have a usb keyboard or mouse normally xp detects it,try btjunkie for drivers for this or try reinstalling xp with everything hooked up...
Apr 15, 2011 | Lenovo Computers & Internet
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
I don't know if it is a problem but when i plug in a mouse to my computer it doesn't detect it at all i don't know if something changed in the BIOS it has windows 98,2000 i had windows xp on it but it...
Dear macrocks22 :
If you are using a PS2 connection for your keyboard and mouse you will need to reboot windows for it to see them. Its just random how it sees them or not.
Any version of windows earlier than windows XP with second edition update will have problems with anything related to USB. Its just hit and a miss if you are trying to use USB connections with windows earlier than XP with SP2.
Hope it helps, if it does don't forget to give the thumbs up.
Feb 07, 2011 | Intel Motherboard
Mouse is not moving
Shutdown your PC. Unplug the mouse and replug in the mouse. Restart your PC, if your mouse cursor is not detect then replaced the mouse.(PS/2 or USB)
Hope it helps.
Aug 26, 2010 | Dell Microsoft Windows XP Home Edition
Hello.. ive had this computer with vista as its operating system, because im not used using vista ive reformat it to windows xp pro but after formatting screen goes blank.. what could be the problem?? the...
There likely may be no XP Drivers for this model. If thats the case your choices are Vista or Windows 7 (Windows 7 Only if the system is capable)
Friendly, affordable, REMOTE computer help!
Nov 23, 2009 | Computers & Internet
P4m800p7mb Motherboard
Is the mose being detected??? was there an error message when you plugged it in???
Most usb mouse today doesn't require any drivers. unless you are using a Windows 9x or lower operating systems.If you are on an XP system then try plugging that mouse to other computers to see if it works. if it does try using other usb ports on your computer and see if it detects the mouse.
Aug 13, 2009 | Computers & Internet
Windows is not detecting usb mouse and mouse is not working
which OS you have..? xp/2000 , both OS not need USB driver but auto detecting.., i request you to try another usb socket.
Jun 28, 2009 | Lenovo IdeaPad S10-1211U Netbook
Optical usb mouse cursor frozen
If it is a USB wireless then your operating system will not need any additional drivers. The USB port takes care of that. Windows XP and Vista support almost 100% of any USB wireless mouse including Logitech..I own three of them, never had a problem. The only problem would be the USB port itself. Which is a totally different subject. You can still also go into control panel and make mouse adjustments if needed.
Please rate solution.
Mar 05, 2009 | Logitech 3-Button Cordless Optical Scroll...
Onboard usb
VIA needs to stop making USB chipsets... lol... Are you sure you have USB legacy support enabled? Moreover, the default Windows XP drivers are not error free when used with a VIA Rev 5 USB Host Controller because it's actually a VIA Enhanced Host Controller. Every time I have USB problems with the VIA Enhanced Host Controller I go to there website, download the driver, and it usually fixes the problem.
USB 2.0 (VT6202, VT6212, VT6214/L)
Moreover, I have plugged in a Microsoft Wireless Optical Mouse and Windows XP could not detect it until I installed Microsoft Intellipoint; if you can believe that. Try also installing the mouse drivers as well...
Nov 27, 2008 | MSI 865GM3-LS (MS7043020) Motherboard
Usb mouse on laptop
go to start>>control panel>>add and remove porgrams.
uninstall all of the Logitech software related to the optical mouse.
restart the computer, plug in the mouse usb, the windows OS should automatically detected the mouse.
Windows OS has logitech mouse driver buldin. you don't need additiona; software.
Nov 04, 2008 | Computers & Internet
Dell Dimension 3000 PC Desktop Logo
136 people viewed this question
Alun Cox
