Question about Sunbeam 2346 Heritage MixMaster Series Stand Mixer
I have a Sunbeam Mixmaster 2351 Heritage Series that the speed dial control numbers fade. Sunbeam replaced my mixer but want to prevent the same problem for reoccurring, Any suggestions?
  • Joanne Scindelka Feb 17, 2012
    I sounds like a good solution. I have not tried it yet. I'm afraid it might affect the warranty,
  • 93 Answers
I would propose to solution to your problem,
one. Try getting some clear contact and cutting a a square or circle a little more than the size of the dial. Removed the dial if possible and later clear contact over the surface.
Two. Get some clear nail polish and cover the markings on the dial with thin coat.
Warning warning warning!!! (Test the nail polish on a surface that is not exposed, for example underneath) to make sure that the nail polish does not react with the surface of the mixer.
Regards
Trevor
Posted on Feb 15, 2012
  • 4 Answers
SOURCE: Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Posted on Dec 16, 2008
greenspan
  • 1734 Answers
SOURCE: I need a User Manual
Check here, I guess they can get you virtually every Sunbeam manual
Posted on Jul 28, 2009
  • 44 Answers
SOURCE: Where can I find the Manual for Sunbeam Model 2350 350
http://www.sunbeam.com/ca/category.aspx?section=kitchen&cid=14
Posted on Sep 08, 2009
SOURCE: Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Posted on Dec 13, 2009
  • 2841 Answers
SOURCE: My Sunbeam Heritage MixMaster mixer just stopped
If it is plugged into a circuit protected by a GFCI breaker, which it should be if it is a kitchen circuit, reset the breaker. If you know for sure there is power at the receptacle you have it plugged into, then the power cord is bad or you have an internal mixer problem. You will have to pay someone to repair it or take the mixer apart yourself and find out what is wrong. Before paying someone be sure and get an estimate as to the cost of the repair. In some cases you are better off buying an new mixer as the repair costs will exceed to price of a new one.
Posted on Dec 18, 2009
How to disassemble mixmaster heritage series model 2351
try the following sites
www.eserviceinfo.com/equipment_type/model###
www.freeproductmanual.com/manufactures_name/model###
www.info.com/manuals
www.s-manuals.com/manufactures_name/model###
at the browser type the following information
sunbeam disassemble procedures for make/model ###
you could look at www.youtube.com/disassembling mixmaster model 2351
Mar 31, 2015 | Sunbeam Food Mixers
How to disassemble a sunbeam 2370 mixer
To disassemble a sunbeam mixmaster 2370, find four plastic snappers arranged at 1, 5, 7 and 11 o'clock around the front circle of vents. They can be seen with the help of a good flashlight. un-snap them and the top and bottom shells will separate. From there on, it is clips and screws. Good luck!
Nov 28, 2013 | Sunbeam 2370 MixMaster Series Stand Mixer
How can i get a replacement manual for the sunbeam mixmaster heritage series 2347
You can download the manual from the manufacturer's web site at
http://www.sunbeam.com/Manuals/MANUALS/002347-030-000_43_32347182.PDF
Feb 25, 2011 | Sunbeam Heritage 2346 Stand Mixer
Sunbeam Mixmaster... where's the model number?
Lift up the head, should be right by where you insert the blades
Jan 24, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam Heritage Mixmaster Won't Tilt back
Hi
Most of them have a button to push that releases the mixer head to tip back. Sometimes the buttons stick and will not release. That picture looks like you are using the Heritage model.
You have to remove two parts in order to get access to the piece that was causing the problem:
1) The "torpedo" shaped knob that sticks out from the mixer speed dial;
2) The speed dial itself
Both of these pieces clip-in, and can be removed with a screwdriver by pressing in on one of the hooks that hold them in place.
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; tighten it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer you may also notice that the tilt release had become easier to use -- previously you may have found that you have to press the tilt release button very hard to get the tilt to unlock.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Jun 12, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixmaster jammed, will not tilt back
That picture looks like you are using the Heritage model, which is the one I just fixed for myself.
I had to remove two parts in order to get access to the piece that was causing the problem:
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; I tightened it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer I also noticed that the tilt release had become easier to use -- previously I found that I had to press the tilt release button very hard to get the tilt to unlock.
I hope this helps!
Dec 28, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam mixer
When you open it, there is are contact points and a piece that has to touch to change the speed. It may just be slightly bent or out of place. Some food may have gotten in there.
Nov 25, 2007 | Sunbeam 2485 MixMaster Series Hand Mixer
Sunbeam 2346 Heritage MixMaster Series Stand Mixer Logo
232 people viewed this question
Top Sunbeam Food Mixers Experts
Jerry Greenberg
Jerry Greenberg
Tony Vallette
Tony Vallette
Level 1 Expert
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
