Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Freezer is below zero even at cooler settings everythings is frozen solid
I had the temperture gage replaced and the condition still exist.
    Champion:
  • 210 Answers
I dont understand the problem.
Posted on Nov 05, 2008
FFU14FC4AW3 keeps on running. Will not stop, even it is full and everything is frozen solid.
Try checking the Temperature Control:Testing Temperature Control
Test the control for continuity using a multi tester. Set the multi tester to the ohms setting X1. Place a probe on each terminal. Turn the control to warmest setting or off. The multi tester should display a reading of infinity. If the control does not have an off position, the reading should be near the infinity end of the scale. Now change the control to the coldest setting and retest. The display should read zero ohms. If the control does not pass both of these tests, the switch should be replaced.
Aug 27, 2012 | Frigidaire Freezers
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
Maytg Top Mount Freezer drip tube leaks into bottom of Refrigerat
Just had this problem a few weeks ago. tube from freezer was frozen solid 1-2 feet down from the freezer. Empty EVERYTHING out of the the Fridge and the freezer into coolers or other suitable 2-4hr container(s). Unplug the unit and use a hair blow dryer on the coolest warm setting. If it's too hot it may melt plastic or styrofoam parts. As long as long as you have everything out and it's going to be at room temperature for a while, why not clean it totally out with fantastic or your favorite cleaner. Once your sure the clog is gone from the tube, put it all back together, plug it in and stop being a slob and keep it clean!!!! hehehehehehe
Sep 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
Frozen foods collecting ice crystals in my freezer
Your freezer is getting too warm during the defrost cycle, causing condensation in your veggies and eventually freezer burn. Likely your door seals are leaking as well after 17 years which introduces even more humidity into your freezer, but I'm assuming your talking about sealed bags of veggies? You need to decrease the temp in your freezer. Get a thermometer and make sure you average around zero degrees. The cause? When is the last time you cleaned the coils at the back of the fridge. Or if they are sealed, perhaps you need to have it serviced. You can try moving your freezer setting to a colder setting it may take care of the problem.
May 20, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
Temp not going below zero
If that is 0 F it is probably the default temperture and is ok. Above 0 food detoriates quicker and below you get freezer burn faster.
If the controls are locked to that temperature it usually involves holding the button for 3 to 5 seconds to unlock and then adjust. (That is on modern frost free freezers in general)
May 04, 2009 | Bosch Freezers
Tank won't freeze
The keys are to make sure the freezer is cold enough, and to make sure the bowl is level when it is sitting in the freezer. 24 hours is usually required, despite what manual says.
If all else fails, the freezer bowls are replaceable - you can order them from Cuisinart - if you are in-warranty, they may even be able to give it to you for free.
-tha Mp3 Doctor
Jul 08, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
FREEZER TEMPERTURE
From 0 to 10 degrees. Ice cream should stay very solidly frozen.
Jul 07, 2008 | Freezers
Best temperture to keep up right freezer and a different refrigerator
Freezer temperature for storage depends on the type of product you are putting into it. Ice Cream as an example must be kept below zero °F as also with bread dough type products. Refrigerator temperatures are best kept below 41°F.
Jun 30, 2008 | Refrigerators
Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Jun 15, 2008 | Frigidaire Freezers
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
52 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
