Question about Bose Lifestyle 38 System
Lifestyle and Spotify
I have a lifestyle 38 system and have now subscribed to Spotify, does anyone know of a way to get Spotify playing through the Lifestyle system with the functionality to skip tracks, choose playlists and adjust volume through the remote? Thanks
  • 14 Answers
SOURCE: Bose Lifestyle 38
No reset button. Simply unplug the power cord in the rear, wait 20 seconds and power back up.
Posted on Dec 24, 2007
  • 4 Answers
I believe there is a USB port on the back of the unit. Has anyone been able to connect to it? Can anything be seen of the files on the hard drive?
Posted on Aug 10, 2008
MarineTech1
  • 76 Answers
SOURCE: No sound Bose Lifestyle 38 III
I am quite sure that the indicator lights should be green. The blinking yellow likely indicates that there is no communication between the head and the audiomass. Verify that the connections are tight and then try powering off (unplugging) the system (both head and audiomass) for 30 seconds and then powering on again. That will often re-establish communications.
Posted on Aug 22, 2009
  • 8 Answers
SOURCE: Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Posted on Sep 12, 2009
welcomejee
  • 10594 Answers
SOURCE: My Bose Lifestyle 25 System has been erratically
This kind of problem happens when optical lens got thin layer of dust that causing problem to laser beam to read data properly. Please put lens cleaning disc in unit and press play button, cleaning disc has little brush that will clean optical lens, this will hopefully solve skipping problem.
If cleaning disc does not help then unit will take apart to clean optical lens manually with good quality cotton swab.
Hope these info will help you.
Thanks.
Posted on Dec 04, 2010
Bose lifestyle 38
It's a system fault from the motherboard.I'm afraid you may need to replace it and in some instances,with the DVD ROM.
Dec 22, 2013 | Bose Lifestyle 38 DVD Home Entertainment...
Tip
Reset Bose LifeStyle 38 VChip Password
Bypass or Reset Bose LifeStyle 38 System V-Chip Password Lock
Would you like to bypass, defeat or reset your Bose LifeStyle 38 System Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked signal without entering your password.
When your passcode is requested, enter the temporary code 2673. This process temporarily unlocks your system, and you can reset or change the password.
I hope that helps.
_______________________________________
Bose LifeStyle 38 Manual Download
Bose LifeStyle 38 Video Mode
on May 02, 2010 | Bose Lifestyle 38 System
Tip
I hope that helps.
on May 02, 2010 | Televison & Video
Can I connect my pc to a lifestyle 28 system
If you want to connect your PC's audio output to the Bose Lifestyle system, simply get a cable with 3.5mm stereo male plug on one end, and dual RCA male plugs on the other end. The 3.5mm side will plug in to your PC's LINE OUT jack. The two RCA male connectors will plug in to the Bose AUX IN jacks. On the Bose console (or the remote control) select AUX as the audio source. Your PC's sound will play through the Bose Lifestyle system.
For persons having a large library of MP3 music files on their PC, this is a great way to listen to the music on your hard disk.
Nov 28, 2009 | Bose Lifestyle 38 System
Bose Lifestyle 38 can't read CD anymore...
some dvd player are unable to play burnt cds, does not support format, maybe your s.o.l
May 04, 2009 | Bose Lifestyle 38 System
Tip
Download Bose LifeStyle 38 System Manual
Have you misplaced your Bose LifeStyle 38 Owners Guide?
Would you like a digital, searchable, pdf version of the Bose LifeStyle 48 System Users Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
Tip
I hope that helps.
Bose Lifestyle 38
Aug 10, 2008 | Bose Lifestyle 48 System
Bose Lifestyle 38
Dec 22, 2007 | Bose Lifestyle 38 System
Tip
Bose LifeStyle 38 System Video Mode Change
Follow these steps to change the video setting from European to North American:
With the media center turned off, use the controls on its front panel to follow these steps:
  1. Press and hold the Enter button on the media center.
  2. While holding the Enter button down, press the Store button. Selections will appear on the media center display each time you press Store.
  3. When Video appears as the selection on the display, release the Store and Enter buttons.
  4. Use the Volume up and down buttons to scroll through the Video options.
  5. Stop scrolling at the proper selection:
  • For a component connection only, select:
  • -NTSC COMPONENT (in N. America)
  • -PAL COMPONENT (outside North America)
  • For a component connection and progressive scan, select NTSC PROGRESSIVE.
6. With the proper selection made, press Store to confirm the
selection and leave the Video options.
I hope that helps.
Bose Lifestyle 38 System Logo
213 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
