Question about Acer Computers & Internet
How to get the sound to work ? - Acer Computers & Internet
Why would tv sound work fine but while using roku 2 the sound suddenly stopped working?
If the picture is OK then check your sound cables, red and white if analog, or swap out the HDMI cable with one that you know works.
Also, on the SETTINGS screen make sure your audio is set to stereo not surround sound.
Dec 27, 2014 | Roku 2 XS
No sound on my A105 s4334 Drivers are ok and system thinks that sound card works.
Check with a external speaker if it works, else you might have to reconfigure the sound settings in control panel..create a new user profile and check as well if it works
Feb 28, 2012 | Toshiba Satellite A105-S4334 Notebook
The sound isn't working on my pc. I have checked speakers on a different pc and they work fine. Have you any idea what the problem could be?
Have you checked the sound driver? Does the sound work with headphones?
If the sound driver is correct and working there will be, when checking the sound mixer, moveable virtual slider controls.
If it works on headphones, the headphone socket may be faulty.
The likelyhood of no sound due to a power problem is not very high.
Nov 17, 2010 | E-Machines (T2824) PC Desktop
Sound card stopped working
1st you disable the onboard sound card in BIOS level, then install/update the sound driver for Maddog Prowler 4.1 DSP soud card will solve your problem.
Dec 08, 2009 | Mad Dog Multimedia Prowler 4.1 DSP Sound...
I have a Dell Dimension 4600, will a PCI Express sound card work in place of the original Sound Blaster 5.1 sound card
Well, the short answer to your question is "No, it won't work". The Dell Dimension 4600 does not have any PCI Express slots in it, therefore you can't install it, and therefore it won't work. But, if you installed a PCI sound card, it would work. The BIOS would recognize the add-on sound card, disable the onboard sound, and your sound will start going through the expansion card instead. Hope this helps.
Jul 18, 2009 | Dell (8H390) Sound Card
New Sound Card is not working.
Ted, the first thing you should do is go into your computer's BIOS and disable the built-in sound card. Once you do that, go back to your device manager and if the onboard sound card still appears there remove or disable it. Then reboot and your new sound card should be recognized and you can install drivers and begin using it.
Apr 25, 2009 | Computers & Internet
Toshiba satellite L10 117 sound problem
The internal sound does not work but external sound works.Please help. contact me ady_service_pc@yahoo.com
Apr 30, 2008 | Audio Players & Recorders
Sound
the sound card is to be attached to the isa slot, if working should receive its resource and work, carefully attach the sound card to the isa slot, if working sound card it will be read if not it won't then put a working sound card.
UZOWUANYA
e-mail uzowuanya@yahoo.ca
Feb 15, 2008 | AOpen AX45-V (91.88I10.004) Motherboard
No Windows Sounds or windows sound functions but All media players work
Select control panel >Sound and audio devices >select Sounds> Sound scheme options check whether the windows default theme is set. if not then set windows default theme.
thank you !
Dec 24, 2007 | Creative Labs Audigy Gamer Sound Card
Computers & Internet Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
