Error code 116-325 in xerox wc 7328
Error code 116-325
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
  • 2072 Answers
SOURCE: Xerox 7328, error 018-543 Shared name error in server
Prerequisites:
  • The printer must be connected to the network.
  • The IP address of the printer is required.
  • The HTTP option must be enabled on the printer. To obtain the IP address or to confirm if the HTTP option is enabled, print a Configuration Report. See the Related Items below for additional information.
  • A user account for the scanner must be created (account needs full control access rights).
  • A directory to be used as a repository for the scanned files must be created. The directory must then be shared.
  • The Hostname of the workstation must be known.
Scan to File is set up in several steps:
  1. The first step is to make sure the scanning service is enabled on the printer.
  2. The second step is to set up the scan file repository.
  3. The third step is to create any necessary templates.
  4. The final step is to configure the template with the required settings.
NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary.
  1. Make sure the SMB port is enabled. Print a Configuration Report to verify this setting. See the Related Items below.
  2. Open an Internet browser window.
  3. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  4. If prompted, enter the username and password in the fields provided, and then click [OK].
    NOTE: The default username is "11111". The default password is "x-admin" and must be entered in lower case letters. If the username or password has been modified or forgotten, contact your System Administrator.
  5. Click on the [Properties] tab. The Properties options will be displayed.
  6. Click on the [+] next to Services on the left side of the window to expand the options.
  7. Click on the [+] next to Network Scanning.
  8. Click on [File Repository Setup]. The File Repository Setup window will be displayed.
  9. Click on [Edit] in the Default File Repository section. The File Destination screen will be displayed.
    NOTE: A maximum of five file repositories may be configured. Generally, just the default repository is configured for scan to file.
  10. Select [SMB] from the Protocol menu.
  11. Enter a descriptive name in the Friendly Name field.
  12. Enter the IP address or Hostname of the computer where scanning will be setup in the Hostname / IP Address & Port field.
    NOTE: The default SMB port is 139. Generally this port number does not change.
  13. Enter the Share name in the Share field.
  14. If necessary, enter the scan path in the Document Path field.
  15. Click on the [Prompt at User Interface] or [System] radio button from the Login Credentials to Access the Destination section.
  16. Enter the scan user name in the Login Name field.
  17. Enter the scan user password in the Password and Retype Password fields.
  18. Click on [Apply]. A “Settings have been changed” message will be displayed.
  19. Click on [Reboot Machine]. A "Do you want to reboot?" message will be displayed.
  20. Click [OK].
  21. Close the browser window.
  22. Test scan to file using the default template. See the Related Items below.
  23. If necessary, create scan templates.
Posted on Dec 16, 2008
wrinaldo
  • 185 Answers
SOURCE: xerox workcentre 7328 fault code 062-393
This is a document scanner problem, probably a bad circuit board. (This PN may be 960K00442 but that needs to be verified in your unit)
Short of that, you could reinstall the "IIT software".
A technician could reseat the EEPROM on the IIT board which controls the document scanner. He should also reseat the scanner bar and cables underneath the glass.
Whit
Item, Inc
Posted on Oct 06, 2010
markandcandi
  • 3 Answers
SOURCE: My Machine Xerox Workcentre 7328
Fault Code 062-393: Scanner Control Board Failure. Power off. wait 1 minute. power on. if still broke call for service - 1-800-821-2797.
Posted on Dec 03, 2010
Ezrahite
  • 2632 Answers
SOURCE: I have a Xerox documnet
Welcome to Fixya. 116 325 - A failure of the Controller Fan has been detected Or he fan that cools ESS module on the machine has failed. This is not a quick fix, Field Service is required to fix the problem.
Thanks for using Fixya
Posted on Mar 06, 2011
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
    Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Error code message
    What Does Your Treadmill's Error Code Mean? - LifeSpan
    www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
    Free
    May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
    [PDF]ERROR CODES: ADDITIONAL ERROR CODES:
    www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
    ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
    [PDF]Error Code Troubleshooting Guide
    Jan 19, 2016 | Exercise & Fitness
    Error code AC-6
    ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION ...ERROR 1-2: AC SERVO ERROR - MOTOR IS OVERHEATING (SPEED RESTRICTED ... error codes listed by category: treadmills, bikes, elliptical trainers.
    [PDF]Precor Error Codes
    The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
    LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
    Select
    Use our model number finder
    Choose your product type
    Common model number plates
    Close
    LG Refrigerator Error Codes
    These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
    Er FS Error Code
    Er rS Error Code
    F dS Error Code
    r dS Error Code
    Er HS Error Code
    Er IS Error Code
    Er SS Error Code
    Er rt Error Code
    Er It Error Code
    Er gF Error Code Error Code
    r dH Error Code
    Er IF Error Code
    Er FF Error Code
    Er CF Condition
    Condenser fan motor is defective Check/Repair
    Condenser fan motor, wiring or the control board Shop Parts
    Condenser fan motor, Power control board, Wiring harness Error Code
    Er CO Condition
    Communication error Check/Repair
    Communication error between main board and display board Shop Parts
    Display control board, Power control board, Wiring harness
    Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
    How to resolve erreur code E000051-0000 whith canon ir 2800
    the Canon E500 printer is one of the most advanced printer which is build upon the latest printing technology. The printer comes in medium-size device and is reasonably light weight of around 5.3 kg. The black plastic body has no sharp edges, and the design is fairly pleasant to appear. The trays of the Canon printer Pixma E500 are quite flexible to use according to Canon Pixma E500 Printer Supportprofessionals. Its glossy finished touched feature makes the printer most eye-striking among users. But here in this blog, we will be introducing you guys with various Canon Pixma E500 error codes that you need to know.
    List of top Canon Pixma error E500 codes
    Error code 1: Canon E500 Error Code E02 (E,0,2)
    • This error symbolizes that printer is out of paper or is incapable of feeding any document.
    Error code 2: Canon E500 Error Code E03 (E,0,3)
    • This error signifies the Paper Jam.
    Error code 3: Canon E500 Error Code E04 (E,0,4)
    • The error signifies that the "fine cartridge" is not installed accurately.
    Error code 4: Canon E500 Error Code E06 (E,0,6)
    • As stated by Canon Pixma E500 Printer Technical Support experts, the paper output cover is not in a closed state.
    Error code 5: Canon E500 Error Code E07 (E,0,7)
    • The ink absorber is complete and users need to reset the counter.
    Error code 6: Canon E500 Error Code E08 (E,0,8)
    • Here the error signifies that the ink absorber is almost in a full stage. Users are then required to press the "black or color" button to resume it in a proper.
    Error code 7: Canon E500 Error Code E16 (E,1,6)
    • The ink in completely finished as of now. You are required to tap on the "Stop/Reset" button to resume the printing process.
    Error code 8: Canon E500 Error Code E17 (E,1,7)
    • The front tray is totally closed.
    Error code 9: Canon E500 Error Code E30 (E,3,0)
    • The error code defines that the size of the original cannot be accurately detected or even it is possible that the document is too small when the "Fit-to-Page copying" is selected.
    Error code 10: Canon E500 Error Code E31 (E,3,1)
    • The machine is surely disconnected with the computer.
    Error code11: Canon E500 Error Code E40 (E,4,0)
    • It shows that the protective material of the Canon Pixma E500 printer for the FINE cartridge or the tape is still attached.
    Error code 12: Canon E500 Error Code E50 (E,5,0)
    • Scanning of the print-head alignment sheet has failed to function
    Error code 13: Canon E500 Error Code P02 (P,0,2).
    • This is a critical error which shows that the printer is in malfunctioning stage.
    Error code 14: Canon E500 Error Code P10 (P,1,0).
    • This error signifies that the mechanical printer is in total malfunction stage.
    So, these are few topmost errors of Canon Pixma E500 printer that users need to be aware of. Our professional team of Canon Pixma E500 Printer Support experts is always available for you to help overcome with any kind of unexpected issues. Call us or even you may drop us an email to our professional email ID.
    May 16, 2015 | Canon IR-2800 Copier Reconditioned
    Erreur cod 009-330 xerox 7245
    009-330 error code xerox work center 7345 problom & soluson
    Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
    60 people viewed this question
    jasbo
    jasbo
