Question about Packard Bell Computers & Internet
Case loose round hinges - Packard Bell Computers & Internet
  • Packard Bell Master
  • 32,281 Answers
If the screws securing the hinges to the base of the laptop is loose then tighten these screws.
Hinges have no tightening adjustments and loose/faulty hinges need to be replaced.
These WEB sites can assist you to replace these hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Posted on Feb 16, 2012
How do I fix the door on my Kenmore Elite HE5 dryer?
Sounds like the screws in the hinges might be loose (or some may have fallen out). Just tighten or replace the screws if that is the case. I guess the hinges might just be worn out (not likely).
Aug 14, 2014 | Dryers
Loose hinges and screen trim comin off
screen trim should be able to be pressed together from front to back, loose hinges is caused by the screws at the hinges. you can pop the trim all the way off normally either by unscrewing the screws or in the case of most hp netbooks by simply applying some pressure between the 2 halves of the screen casing. i'd remove the front half and tighten the screws and then pop everything back together.
Dec 12, 2013 | HP Pavilion DM1-4050US 11.6-Inch Laptop
1995 jetta iii GL door hinge
You can pry up on the door untill it lines up.yes the striker cushion can be replaced.
May 13, 2017 | 1995 Volkswagen Jetta
Loose case round himges
The screws that secure the hinges to the body of the laptop may be loose. In this case tighten the screws.
If the hinges are faulty, they are not adjustable and they need to be replaced.
These WEB site can assist you to replace the hinges.
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
Feb 15, 2012 | Computers & Internet
When I close the fridge side the freezer side pops open a little and stays open. The appliance is 5 years old. This started very recently
a couple of problems can cause door problems first open door and check seal for damage [popped off trac or rip-tears]other is hinges worn- bent-loose --if seal is good at top and bottom of door are hinges check for loose if loose tighten -if bushing lookes like a little round washer type is broken or missing replace --needs realignment loosen top hinge and close door and adjust till door is straight and stays closed tighten door hinge done good luck
Jun 28, 2011 | Jenn-Air JCD2389G Side by Side...
Screen hinges very loose
If you pop off the plastic casing around the keyboard, you should see two screw ends on the hinges that should allow you to tighten the friction of the hinges themselves. Be careful to remove all the necessary screws from the underside of the laptop before removing the plastic case.
Feb 11, 2010 | Acer Aspire 4520-5582 Notebook
Nintendo top pulled off hinges
Look on ebay for replacement shells for DS.
There around $15 and you also need to buy a Special Nintendo Screwdriver
Dec 07, 2009 | Nintendo DS Lite Console
My ds is losse
I have had a similar problem, i think. if the hinge is loose, buy a kit to fix it. it is about $25.00, and take about 5 hours to do but it is worth it. i promise.
Jun 20, 2009 | Nintendo DS Lite
Dryer door/casing is loose on hinge side of door
you can go to repairclinic.com and enter your model number. It will list all the parts. Find your hing and screws and your set.
Apr 13, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Computers & Internet Logo
366 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
