Question about Philips Blenders
Assembly reassembly
  • bc6910
    bc6910 Feb 15, 2012
    My girlfriend assemblied my philips blender HR2094 wrong which destroyed the 2 plastic parts that joins the motor to the knife. Phillips has been so kind to sent the spare parts free of charge.
    Now the problem is how to take the mashine apart. I have managed to get the motor part out - the part I need to change is the plastic part sitting on top of the motor - the one that takes a grip on the knife part on the blender glass. How do I get the old part of the motor blok ?
    Best regards Brian
  • bc6910
    bc6910 Feb 17, 2012
    Problem solved - It had to be screewed off but it was very thight.
I cannot get the blade assembly into the base of my bella cucina rocket blender?
Turn the cog in the base a little. Sometimes it gets misaligned.
Sep 24, 2014 | Bella Cucina Rocket Blender
Replace ball bearing
Part of the blade assembly or drive socket assembly?...
check here:
Amazon com vitamix wrench assembly Home Kitchen
Jan 30, 2014 | Vitamix Blenders
I NEED A PITCHER FOR BLENDER MODEL KSB540WHO
The jar assembly for the KSB540 is part W10503762. this is for the 48oz jar assembly. Here is a link to the product KitchenAid Blender Jar Assembly for KSB465
You can also use the 56oz jar on your blender, which is part number W10555711, here is a link to that product as well: KitchenAid Blade Jar Assembly W10555711
Nov 26, 2013 | KitchenAid KSB5 Professional Stainless...
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
I need the Jenn-Air Blender blade assembly too. Anyone sell me one?
Hello, Do you still need the jenn-air blade assembly? I have one to sell. Do you need the collar also?
Jun 28, 2009 | Jenn-Air JBL800 Work Top Blender
Leaking cuisinart smart power 7-speed electronic blender
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
Apr 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Jenn air jbl800 blade assembly?
Got the blade assembly make me an offer! Contact me at freedom4u@myarbonne.com .
Andrea
Mar 15, 2009 | Jenn-Air JBL800 Work Top Blender
Waring blender - new blade
You can call Waring and they can send you a parts breakdown showing the order the parts need to be in. If you still have problems they can go over the assembly with you on the phone or direct you to a service center near you to help.
Feb 21, 2009 | Blenders
Blenders Logo
Top Philips Blenders Experts
Ross Keen
lakeareaserv
Tom Chichester
Are you a Philips Blender Expert? Answer questions, earn points and help others
