Question about Cell Phones
1600 bsi line jumper solution
Solution bsi line
NOKIA 1280 WATER DAMAGE STE DEAD
Aug 14, 2011 | Cell Phones
Isert sim but sim i c is ok
nokia n70 simtray bsi line circuit diagram
Aug 03, 2011 | Nokia N70 Cellular Phone
Caina set ie, karbonn,lemonetc battery low set down problem pl give exact solution.
First check the BSI (the center terminal of the battery interface)line.Clean the center point of battery as well as the BSI line.If the problem still persist Change the battery.There will be no "battery Low Shut Down".Thanks for visiting fixya
Jul 26, 2011 | Cell Phones
2003 ford explorer is stuck in park, the brake lights are on so i dont think it is something to do with the brake
adobe.gif Printable View (109 KB) TSB
04-22-12
  • GEAR SELECTOR LEVER - INCREASED EFFORT TO SHIFT FROM DRIVE TO PARK
Publication Date: November 1, 2004
FORD: 2002-2005 Explorer, Mountaineer ISSUE: Some 2002-2005 Explorer 4dr/Mountaineer vehicles, may require a greater effort to move the gear selector lever (shift lever) from drive to park. This may be due to a time delay with the brake shift interlock (BSI) pin retraction.
ACTION: To service, replace the BSI switch. Refer to the following Service Procedure.
SERVICE PROCEDURE
  1. Remove the two (2) fasteners supporting the instrument panel knee bolster from below the steering column and remove the cover (Figure 1).
    Figure 1 - Article 04-22-12
  2. Remove the three (3) fasteners supporting the steering column lower shroud and remove the cover (Figure 2).
    Figure 2 - Article 04-22-12
  3. Remove the three (3) wiring bundle carrier fasteners from the bottom of the steering column to allow movement while removing the BSI switch. It may be necessary to release the connectors from the multifunction switch (Figure 3).
    Figure 3 - Article 04-22-12
  4. Remove the BSI fasteners (T-30 on the side and T-20 on the bottom) (Figure 4).
    Figure 4 - Article 04-22-12
  5. Pull the BSI tab on the bottom of the column downward to help free the BSI from the column housing.
  6. Break the two (2) side tabs off the BSI by the white wiring connector (Figure 5).
    Figure 5 - Article 04-22-12
  7. Push the locking tab on the white connector towards the wiring to release the connector from the BSI. Be careful not to damage the connector or wiring. If the connector does not free easily, a very small flat screwdriver may be used to help lift the locking tab (Figure 6).
    Figure 6 - Article 04-22-12
  8. Connect the wiring to the new BSI. Ensure all clips are fully engaged to prevent the connector from pulling free.
  9. Reinstall the BSI onto the steering column and reinstall fasteners (Figure 7).
    Figure 7 - Article 04-22-12
  10. Check BSI function. With the key in the accessories or run position, press the brake pedal. The BSI pin should retract on brake application, and spring up one (1) second after releasing the brake pedal. Repeat several times.
  11. Reinstall fasteners to connect wiring bundle carrier to the steering column. Make sure all connections to the multifunction switch unit are secured properly.
  12. Reassemble steering column in reverse order. Ensure rubber gap hider around shift lever is properly seated on the shroud.
  13. Cycle the shift lever from park to drive and drive back to park several times to verify improved shift effort.
PART NUMBER PART NAME 1L2Z-3Z719-DA BSI Switch
Feb 15, 2011 | Ford Explorer Cars & Trucks
1600 insert sim problem tips tricks
hello
try this site http://4free-mobile.blogspot.com/2008/11/jumper-tricks.html
you will find everything that you want
May 02, 2010 | Nokia 1600 Cellular Phone
Jumper setting Nokia 1600
1650 earphone jumper setting
Mar 28, 2010 | Nokia 1600 Cellular Phone
My nokia 6280 is not keeping gharge and is refusing to charge
1-Try another trusted genuine battery.
2- Try another trusted genuine charger.
3- If RETU IC is not under-filled try yo reflow it, if not works then replace it.
4- No way but to try replacing TAHVO IC even if it's under-filled (if you really want to solve the problem) ;) .
maybe ur bsi line short to ground!!
try to remove the resistor in bsi line....
Mar 21, 2009 | Nokia 6280 Cellular Phone
Not charging pbm
1600 display & keypaid no light
Dec 27, 2007 | Nokia 1600 Cellular Phone
Nokia 1600 problem
try the below given jumper settings,it is applicable only if the board print is available
Dec 03, 2007 | Nokia 1600 Cellular Phone
Cell Phones Logo
99 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
