Question about Neff Refrigerators
Where do I find an engineer to do a domestic regas?
Bought a second and fully working freezer but think it was left too long not upright before switching in, we dd leave it upright for 10 days before switching on for first time. Now think it needs a re gas, all research has led to commercial ony engineers, any ideas everyone?
  • 1462 Answers
SOURCE: my samsung frige freezer RL41WGTB
i suspect fault is nothing to do with gas and as this unit uses r600a, gas needs to be dosed exactly - no good just squirting a bit in!
if freezer is ok, i guess fault is with the fan jammed.
Posted on Nov 04, 2008
tborn6
  • 700 Answers
SOURCE: fridge freezer light on nothing else after transporting.
IS THIS A AUTOMATIC DEFROST UNIT? IF SO THEN THE DEFROST CLOCK PROBABLY IS BAD, LOOK UNDERNEITH BY THE COMPRESSOR AND THERE SHOULD BE A SQUARE ISH BAX THAT HAS 4 WIRES COMING OUT OF IT. TAKE AND TURN THE RED KNOB WITH A SCREW DRIVWER UNTIL THE COMPRESSOR COMES ON. IF THAT WAS NOIT IT TAKE A HAIR DRIER AND HEAT UP THE LIDUID LINE DRIER SOME TO TRY TO CLEAR THE RESTRICTION ON THE DRIER. GOOD LUCK (SORRY ABOUT ALL CAPS BUT GOT TIRED OF CORECTING THE SPELLING) NOT SHOUTING
Posted on Jan 11, 2009
  • 68 Answers
SOURCE: acquired second hand electrolux er3167bn fridge
yep sounds as though it is iceing up after it runs for a couple of days
you may have a defrost heater or defrost timer not working
the fact it didnot have water in the tray, you prob have a blocked drain as well
Posted on May 02, 2009
garing
  • 998 Answers
SOURCE: left door open on frigidare commercial white
you killer it's dead
Posted on Aug 08, 2009
SOURCE: BRADA MF-305 UPRIGHT FREEZER AMBER/YELLOW LIGHT ON
I bought the same freezer and have the same question.
Anybody know? Did you figure this out vemmy?
Posted on Sep 27, 2010
Need a GE fidge freezer regas but cannot find anyone who does that type of gas
What gas you looking for? R 12? Any gas can be gotten but some, due to discontinuation can be very expensive. Cannot be bought at store and only licensed refrigeration technicians can get it.
Jun 22, 2016 | GE Refrigerators
How can I adjust an upright freezer door ?
Hello there,
It is always the feet and their adjustment and floor must be level
From the user guide it says
;The freezer must have all bottom corners resting firmly on
a solid floor. The floor must be strong enough to support
a fully loaded freezer.
NOTE:It is VERY MPORTANT for your freezer to be level in order to function properly. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems.
To level Upright Models:
After discarding crating screws and wood base, use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, half a bubble higher, so that the door closes easily when left halfway open. ;
User guide here
http://crosley.com/assets/product/1707/useCareGuide.pdf
Sep 24, 2014 | Crosley CFUM21LW 20.6 cu. ft. Upright...
Does Kenmore Elite upright freezer reach -20 degrees celsius, where is the info?
Best way I can answer this is to purchase the right equipment for the job. A domestic freezer is not designed to work like that, although it may get there in temp it won't hold it. Recovery is slower then the industrial unit you seek. Domestic unit warranties are void if used for commercial settings (i.e. lunch rooms, offices, lab's, etc...) I wish I had a better answer for you but if you need a specific temperature get the correct equipment for the job. Good Luck
Jul 31, 2014 | Kenmore 20.6 cu. ft. Upright Freezer 2809
Coils frozeup and iced on top shelf of freezer---did a defrost--when shut the door don't hear the shhhh sound-nothing blocking it and seal is good--light is on but won't freeze any food--threw out alot! ...
Defrost the unit totally so you can see no more ice, may take a day or more with door open, once done, restart the unit, check you can hear the fan running in the freezer, if not, replace fan unit, if you can hear it, the defrost timmer may have failed or the defrost element has gone. If the unit appears to work correctly, dont be fooled, the problem will return, if the unit does not work as it should, regas is required. Hope that helps.
Dont forget to vote for the solution, thankyou
Mar 04, 2011 | Frigidaire 13.7 cu. ft. / 388 liter...
My bottom freezer has stopped producing cold air, fan still works, any thoughts ideas, Daniel
if the compressor keeps switching on and off in short bursts, its your gas thats finished. it may need a regas. gas being finished may be from either standing a long time, it being an old freezer, or a gas leak. you'll need a repairman to regas it and also for checking for leaks.
Oct 29, 2009 | Sub-Zero 611 / O Bottom Freezer...
I have a UK bought rega planar 2 turntable. I tried to use it in the USA using a step up transformer and it runs fast. How can I fix this?
As far as I can see, this turntable uses a belt. I believe the motor is synchronous (12 vac), it is designed with a pulley for working at 50Hz. At 60Hz, it turns 20% too fast. It may be possible to change the pulley as it needs to have a smaller circumference. I think you should contact a Rega representative or the company directly in the UK (www.rega.co.uk)
Jul 14, 2009 | Audio Players & Recorders
New chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Jul 13, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Kenmore freezer not cold at all!
We had a Kenmore upright which worked fine but then suddenly was not keeping food frozen. Long story short, do not store anything on top of the freezer unit. It will insulate the coils that run across the top of the unit, and cause your compressor to work harder than it needs to, and eventually overheat and become ineffective. Says nothing about it in the user manual. We learned the hard way by losing food.
Jul 30, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Top Shelf of Freezer Not Cooling
sounds like you may have a refridgerant blockage in the system. it may need a regas to see if it can be unblocked, as this is not a quick job it may cost you but phone around on the cost/feasibility of it. it may be just as well to get a new or second hand freezer.
Jun 06, 2007 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Refrigerators Logo
22 people viewed this question
Top Neff Refrigerators Experts
John Tripp
John Tripp
richie46
Rabbit Brains
Rabbit Brains
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
