Question about Microsoft Xbox 360 Console
MY XBOX 360 WILL NOT EJECT OR EVEN EJECT BY CONTROLLER
WHEN I TRY TO EJECT IT WILL NOT, NOT EVEN WHEN I TRY TO EJECT IT BY THE CONTROL PAD I AM RUNNING OUT OF IDEAS
  • Jon Hutty
    Jon Hutty Feb 22, 2012
    I tried that but the drive does not spin when i put a disc in once i re shut the drive tray. Any other ideas would be appreciated. Thanks
  • Austin Evans
    Austin Evans Apr 13, 2013
    Then the motor is probably shot, you'll have to take it apart and replace the motor.
    Sergeant:
    Champion:
  • 242 Answers
Emergency eject with a paper clip.
Posted on Feb 18, 2012
360Solutions
  • 79 Answers
SOURCE: xbox 360 controller for pc
You know it works on the PC but nothing is working? Sorry, this isn't very clear, is the controller not working on the 360 or the PC? More explanation is needed here I think
Posted on Nov 25, 2007
SOURCE: programming Xbox 360 wireless controller
As Rizla said
however sometimes they just flash for a little while if this happens turn the controller off and try again and it should then work
Posted on Feb 06, 2008
  • 6 Answers
SOURCE: xbox 360 guitar hero no sound controller 2
goto options with the controller and check if sounds are turned up.
alex
Posted on Jul 10, 2008
thaurfen
  • 623 Answers
SOURCE: xbox 360 wireless controller not connecting.
it sounds like your controller keeps losing sync with the 360.
- turn them both off
- turn on the 360 with the power button on the console
- wait for it to start up, then press the sync button next to the usb flap on front.
- then press the sync button on the controller (by the recharge connection slot)
That should reset it.
Posted on Nov 13, 2008
SOURCE: xbox 360 wireless control pad wont connect
have you tried to pair it... the little white button on both the controller and the 360? works just like the wii remote
Posted on Feb 07, 2009
When i hit right on the D pad it moves left how do i fix it?
DIY Fix the d-pad on the Xbox 360 control pad (more than just
www.instructables.com/.../DIY-Fix-the-d-pad-on-the-Xbox-...
InstructablesOkay, first things first: I find the d-pad on the 360 wireless controller to be a mushy mess. ... hits the contacts on the circuit board) and the bottom of the d-pad's contact ... All we're going to do is add a very thin layer between the membrane and the ... controllers, pressing right will for example register as down-right, and so on.
Weird Controller Glitch - Left on Analog is Right on the D-Pad
Dec 25, 2015 | Computers & Internet
My xbox 360 wireless controller will not connect to my xbox 360 console even when i press the button that scans for the pad but it still turns on the xbox 360 when you press the middle button on the pad
Turn off both the console and the controller, then follow these steps:
  1. Turn on both the Xbox 360 Wireless Controller and the Xbox 360 console.
  2. On the console, press the connect button. (to the immediate right of the memory card slot on the console)
  3. On the controller, press the connect button. (Look on top of the controller for a small button.)
  4. The green lights that surround the Guide button on the controller and the power button on the console spin and flash when the controller is being connected to the console. After the controller is connected, a single green light illuminates on the controller and on the console to show you which quadrant the controller is connected to.
Feb 28, 2011 | Microsoft Xbox 360 Controller
Wired 360 pad isn't working
I had same problem..if u have a dance pad with foam inserts....take out the insert and try to start up without them....the problem we had is one of the inserts was putting pressure on one of the buttons preventing xbox from reading pad...if u don't have inserts one of your buttons is sticking...give it a shake and try again....we fixed ours by simply rearranging the inserts...hope this was helpful
Jun 12, 2009 | Konami Dance Revolution DDR Original Dance...
Xbox 360 wireless control pad wont connect
Feb 07, 2009 | Microsoft Xbox 360 Console
Xbox 360 wired control pad won't work
Possible fix, make sure your contacts are clean, and your cable is not damaged. Obviously the 5v lines are connecting, but no data is getting through. I reccomend using a q-tip to get any grime off, but you may need rubbing alchohol (90% reccomended because it dries cleaner). Clean off the connections on the xbox and the controller. If it still doesnt work, list any extras you have plugged into your controller, and the estimated time you bought the controller.
If all else fails, I've just got a great deal on a MadCatz xbox 360 controller ($25) and its fully functional, minus the controller faceplates if thats your cup-o-tea.
Jan 29, 2009 | Microsoft Xbox 360 Controller
Controller
you have to press the connection buttons, one on the controller and one on the xbox 360, the one on the controller is located on top by the triggers next to the cartridge insert port right by the left button, it has 3 wavy lines next to it, when you press it, the controller will light up and go in circles. After that quickly press the button on the xbox 360 located under memory unit A, to the left of the disc eject, then the xbox 360 lights will go in a circle then automatically connect. If it doesnt work at first, try it again, but quicker.
Nov 28, 2008 | Video Game Consoles & Games
Wireless xbox 360 control pad
Sorry if you have done this and I'm being really patronising but have you held down the connect button on both the controller and the console?
Jun 02, 2008 | Microsoft Xbox 360 Wireless Controller and...
Xbox controller not working only has two lights on game pad
There should be a sync button right on the top of the back of the Xbox 360 controller. While the system is on. Power on the controller. Hold down the sync button on the controller, and then press and hold the sync button on the Xbox 360 console. Wait for a few seconds until the Xbox 360 controller lights stop blinking. Then test out the controller. Any comments of questions, post them by clicking on the add more details link inside of this question that you've asked.
Nov 16, 2007 | Microsoft Xbox 360 Controller
Wireless Controller not connecting to console.
Hey guys,
I've had the same problem today. The controller wouldn't connect no matter what. The strange thing was I could still turn the console on using the controller, but afterwards it wouldn't do anything.
Now I think I found a solution, at least for my case. All I did was to remove the HDD (that thing on top of the console) and put it back in. Then I started the console again using the controller and it was instantly connected.:)
Now I just hope it stays this way.;)
Sep 20, 2007 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Console Logo
111 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
