Question about Quinny ZAPP Stroller
Back wheels will not click back in. have tried to clean the inside incase of a build up but none
I had the same problem. It was a sort of buildup which was ammazingly problematic. I undid the small screws on the inside of the wheels (1 screw per wheel). Be careful because a spring and black plastic piece will fly out. then use a screw driver to push the gray wheel removal button. You will find that it seems sort of stuck. Clean inside the plastic chamber and the slider piece...I just used my fingers. Then you will see that it slides freely. Put the sliding piece in the correct position for when the wheel is removed...button depressed. Put the wheel on. Push the sliding piece with a screw driver so that the wheel is locked and the button is popped out. Put the spring back in and the black plastic piece back....hold it on and redo the screw. The wheel should be locked on. I am not sure if you would be able to remove it and put it on again...I think so, but I am not trying since I don't usually remove the wheels anyway. I hope this works for you too! Good luck!
Posted on Nov 01, 2008
Asus rock G31M motherboard
are there any beeps from the motherboard. can you be a explain your problem more elaborately. if there are any beeps try to clean up your ram and try again
Jul 19, 2013 | Computers & Internet
Why is my singer SEWING MACHINE prelude HAND WHEEL RESISTING
Make sure the bobbin winder is in the position away from the bobbin stopper. When you fill a bobbin, you have to push the "spindle" towards the handwheel. If you do not push the "spindle" back into position (away from the handwheel), the wheel will remain locked.
Jul 18, 2012 | Singer 8280 Mechanical Sewing Machine
I can't get the wheels off my 2006 Volvo XC90. I
This is very common, the center hole of the rim is whats holding the wheels on due to corrsion, you will need to hit inside of tire with a good size hammer and spinning it so you hit diffrent spots of the tire. the tire will break free.
Note try not to hit the rim as it will dent, wont harm it but try to avoid it.
You will note the build up on the inside center hole of the rim and also on the center hub. use a steel brusk and some fine sand paper to clean.
After you clean apply some lube grease around hub, this will make the wheel go on and come off alot better. hope this helps.
Mar 04, 2012 | 2006 Volvo XC90
I have a Brother all-in-one & keeps saying paper jam when there is none. All paper has been removed. Unplugged it to reset. Did everything in the manual I could do. Is there a reset button somewhere?
remove the drawer from the printer turn the printer on its back try cleaning the pick wheels. use cfc free contact cleaner spray it on a rag and wipe the wheels clean. these wheels get residue build up on them from the paper and this makes them smooth and inafective. contact cleaner removes this buid up
Oct 01, 2010 | Brother Office Equipment & Supplies
Brake pedal goes all the to the floor. can not
Check the reservoir to be sure the fluid is full. If not, top it off and try it again. If there's still trouble building pressure, pump the brakes a bunch of times, and then check around each wheel for fluid on the ground. If you see none, it's possible that you have a break in the line somewhere through the chassis and that the fluid is leaking out inside. If you see no evidence of leakage, and the reservoir is still full, you need a new brake master cylinder - what will have happened is that the diaphragm around the plunger inside the master cylinder (which moves through the cylinder when you push the pedal, and forces fluid out to the wheels) has a hole or tear in it, so instead of pushing the fluid out to the brakes, the plunger simply moves through the fluid. It never builds pressure, and your brakes don't work.
Dec 22, 2009 | 1992 Cadillac DeVille
Dryer won't heat up and tried changing the heating element. still won't heat up Whirlpool dryer
check the thermal fuse located on top of blower wheel housing and see if there is lint build up inside the blower wheel duct,when was the last time you cleaned out the dryer?
Nov 28, 2009 | Kenmore Elite HE4 Electric Dryer
Won't drain water it just builds up inside, its new out of the boxIve tried slight tilt and flat same thing water just builds up, is there a hose or drain i need to open??
If you can find the drain line outside it probably is is white pvc or black polyurethane i use a wet vac. and secure it with tape so you get a better suction. If its upstairs there is probiably a second one so do both just incase. After time fungus builds up and can cause it to over flow try that see what you get out of it. if it doesnt work thetimnelson@yahoo.com
Jun 27, 2009 | Heating & Cooling
Model 64213 (not a wireless model) Trackball is not working smoothly - already tried cleaning it and still gets "stuck" especially moving left and right. Up and down works well.
This is because the wheels that move with he trackball are getting stuck.
Try cleaning the inside housing.(The part that holds that trackball) Mainly, the tiny wheels that grab the trackball. Normal use can build up a gummy buildup inside that can be easily rubbed off with a cloth. Since the housing is underneath the trackball, there can be a greater potential for lint, crumbs or anything else to get inside as well. Clen in there, empty out any debree and you will find ti moves much smoother.
alternatively, one of the tiny wheels could be damaged and is not rolling properly. Roll each one with your finger to see if you can feal anything rough or if the wheel is rubbing against something.
Jul 28, 2008 | Computers & Internet
WHEELS!!!
you have to replace the spring inside the wheel hub. the same thing was happening to me and my husband made a new spring out of spring steel. I guess they just loose their strength after a while. It was very frustrating!
Dec 12, 2006 | Bertini 906T TWIN - Navy Check Standard...
Quinny ZAPP Stroller Logo
219 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Al Toledo
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
