My Washing machine stains clothes; they come out with brown rusty stains. Otherwise the washing machine works fine. my washing machine is lessthen three years old and always give brown stains in white clothes i have change the detergent but no change
  • 1 more comment
  • MSOK Mar 10, 2009
    I have the same problem. A line of light brown on white clothing. Usually white dress shirts or light colored pants. We suspect the rubber around the front loading opening. If we run a towel in there, it comes out really dirty, icky. The dirt seems to gather there. Even after wiping it out - no easy task - I get the stains, so not convinced that's the cause.
    The washer is only 4 years old.
  • Anonymous Mar 23, 2009
    I have a Whirlpool Duet front loader. In addition to the mold issue on the gasket, I also get a goldish brown line of stain on the white clothing. It especially affects light weight clothing. If it is missed and the clothing goes into the dryer the stain never comes out.
  • rjl1953 May 25, 2009
    I have a Whirlpool front loader washer also, I am going to try rust remover to see if those brown pencil like stains come out. It seems to also get on the most expensive items or new items. They are all cotton as well.... hmmmmmmmmmmmmm....Let you know how the rust remover goes.
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Posted on Apr 12, 2010
    Problem Solver:
  • 19 Answers
Its the felt drum seal (clothes getting stuck in there and getting the greasy adhesive on them). I took a Q-tip and slid it between the felt seal and the metal, and the color and consistency of what came out was the same as the marks on the clothes.
Call a Whirlpool tech, they can replace
Posted on Aug 21, 2009
  • 903 Answers
If it definalty not rust causing this, check the pump incase there is something trapped inside that is letting of a colour.
Posted on Oct 25, 2008
Brown stains on clothes
Sounds as tho there is an excess of fabric softener build up on the inside of the outter tub. Try Filling with Hot water and bleach and let set for an evening and then turn back on and e tcontinue washing thru cycle.
Jan 31, 2010 | GE WHRE5260E Top Load Washer
Kenmore top loading washing machine does not clean clothes well.
I would seriously consider getting a newer machine. A brown stain could be rust, or an oil leak. Either way it probably is not worth putting any money into. If this helps, please rate my answer. Thank you.
Jan 07, 2010 | Kenmore Washing Machines
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FSE747GESI Frigidaire frontload dryer brown stains
I have the feeling that faded from the clothes .. so that there are brown marks .. or .. we have washing machines ber rust .. until that happens
Jun 16, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
May 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My Kenmore Elite HE3 washer doesn't get the dirty laundry clean. It redeposits the dirt on the clothes, causing brown stains. I had a Sears rep look at it when it was new (5 years ago), and he said it was...
Brown stains are likely from the felt seal. The adhesive used from the factory disintegrate over time, and when you replace the felt - use some silicone instead.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore Washing Machines
Brown stains from wash machine
Hi!!! Your tub inner seal is worn off its a seal which protects the inner tub fron the transmission..Need a new tub seal..Good luckk..
Jan 03, 2009 | Washing Machines
I've had this problem for many months now.  Even when it ruined my favorite tops & jeans, I couldn't get myself to let go of them... Good thing though because I have found a solution!  Make a paste using cream of tartar and hydrogen peroxide.  Generously spread the paste over the stains and let sit for about 5 minutes.  Boil enough water to fully immerse the stained garment in.  While waiting for the water to boil, figure out a way to wrap/roll the garment so that the paste doesn't come off when put into the water.  You want the paste to melt onto the stain while in the hot water.  After wrapping/rolling the garment, secure it with string or thread (anything that won't melt) that doesn't have color, just in case it bleeds.  After the water has come to a full boil, immerse the garment into the hot water and let it soak.  After about 15 minutes, remove the garment from the water.  The water should still be very hot, so I use cooking tongs to get it out.  Let the garment cool down to room temperature while still rolled up.  After it has fully cooled, unwrap the garment.  There should be very little or none of the paste left on the stain.  If there is still a great deal of paste, you may want to soak it again until the paste melts a bit more.  Once the paste is gone, rinse of the garment and it should be clean & stain free.  :o)
Mar 17, 2008 | Washing Machines
Problem with front load washer
Are stains a brown rusty color? If so, this may be an indication that the rear drum bearing is going bad. The bearing itself cannot be replaced. You will need to replace the entire back shell of the wash tub. Hope you have a warranty. This can be an expensive repair. Let me know if this is the case.
Jul 08, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
3,707 people viewed this question
Top Washing Machines Experts
