Question about Canon CanoScan LiDE 25 Flatbed Scanner
Error 2, 7 ,0
Twian data transfer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 76 Answers
I take scanner was working before.
Try connecting the USB cable to another port on the computer (directly to the computer, and through a hub or any other device.This will rule out issues with hub or any other device.
Try the scanner on another computer - this will rule out issues with the scanner.
Hope this helps.
Posted on Feb 15, 2012
How to transfer everything ftom my samsung galaxy 3 to a samsung sJ
With an android data transfer tool, you can transfer data fom one phone to computer, and import them to your another phone. Hope this helps you,
MobiKin Assistant for Android Windows Version
Dec 27, 2015 | Samsung Cell Phones
How to fix the error code for Ricoh 1232c sc517 and how to clear it
there's no error code like that
http://www.unitedtechsonline.citymax.com/page/page/4653767.htm
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER)
384-385:IMAGE DATA TRANSFER PROBLEM WHEN TANDEM IS USED(SBU,INTERFACE
BOARD,SICU,PRINT CONTROLLER)
390:TANDEM IMAGE DATA TRANSFER ERROR(NOISE,SICU,INTERFACE BOARD)
391-392:IMAGE STORAGE ADDRESS ERROR(SICU391-01)
395:CD-R/RW ERROR, INTERFACE BOARD ISSUES
397:CD ACCESS ERROR
398:CD-R/RW DATA ERROR
400:TRANSFER BIAS ROLLER ISSUES
401:TRANSFER ROLLER
430:QUENCHING LAMP ERROR
440:DRUM MOTOR LOCKED
441:DEVELOPER MOTOT LOCKED
491:LASER COOLING FAN LOCKED
495:TONER BOTTLE PROBLEM
496:TONER COLLECTOR BOTTLE PROBLEM
501:LIFT PROBLEMS FOR TRAY 1
502:LIFT PROBLEMS FOR TRAY 2
503:LIFT PROBLEMS FOR TRAY 3
504:LCT 1ST TRAY PICKUP OR LIFT PROBLEM
505:LCT 2ND TRAY PICKUP OR LIFT PROBLEM
506:LCT 3RD TRAY PICKUP OR LIFT PROBLEM
510:PAPER FEED MOTOR PROBLEMS
511:LCT MOTOR PROBLEM
515:TANDEM REAR FENCE MOTOR PROBLEM
520-521:DUPLEX JUGGER MOTOR PROBLEMS
531:FUSING DUPLEX MOTOR LOCKED
532:RELAY MOTOR LOCK
541:OPEN FUSER THERMISTOR
542:LOW FUSER TEMPERATURE
543:HIGH FUSER TEMPERATURE
544:HIGH FUSER TEMPERATURE
545:HIGH FUSER TEMPERATURE
546:LOW FUSER TEMPERATURE
547:ZERO CROSS PROBLEM
550:WEB EXPIRED
591:TONER SUPPLY MOTOR PROBLEMS
592:TONER BANK MOTOR PROBLEMS
601:SBICU TO SBU COMMUNICATION PROBLEMS
602:SBICU TO HARD DISK DRIVE BOARD COMMUNICATION PROBLEMS
620-622:SBICU TO ADF COMMUNICATION PROBLEMS
625-626:BCU TO FINISHER COMMUNICATION PROBLEMS
630:LINE ADOPTER TO CSS CENTER COMMUNICATION PROBLEMS
640-645:BCH TO SICU COMMUNICATION PROBLEMS
646:SICU PROBLEM
650-653:COUNTER ERROR JAPAN
701:ADF P/U ROLLER PROBLEMS
702:ADF FEED MOTOR PROBLEM
703:ADF TRANSPORT BELT MOTOR PROBLEM
704:ADF EXIT MOTOR PROBLEM
705:ADF ORIGINAL TABLE LIFT ISSUES
720:FINISHER LOWER TRANSPORT MOTOR ISSUES
722:FINISHER JOGGER MOTOR ISSUES
724:FINISHER STAPLER HAMMER PROBLEMS
725:FINISHER STACK EXIT MOTOR PROBLEMS
726:FINISHER SHIFT MOTOR PROBLEMS
727:FINISHER STAPLER ROTATION PROBLEMS
729:FINISHER PUNCH MOTOR PROBLEMS
730:FINISHER STAPLER MOTOR PROBLEMS
735:FINISHER PAPER STACK PLATE MOTOR PROBLEMS
736:FINISHER EXIT GUIDE MOTOR PROBLEMS
737:FINISHER FULL STAPLER HOPPER
738:FINISHER SHIFT TRAY LIFT MOTOR PROBLEMS
739:FINISHER FOLDER PLATE MOTOR ERROR
740:FINISHER FRONT SADDLE STITCH STAPLER MOTOR PROBLEMS
741:FINISHER REAR SADDLE STITCH STAPLER MOTOR PROBLEMS
742:FINISHER JOGGER SIDE FENCE MOTOR
750:COVER INTERPOSER BOTTOM PLATE MOTOR PROBLEMS
800:VIDEO OUT TRANSFER,CONTROLLER BOARD
804:VIDEO OUT TRANSFER,CONTROLLER BOARD
818:OPTIONAL BOARD,CONTROLLER BOARD, SYSTEM PROGRAM
819:BAD SOFTWARE
820:CONTROLLER BOARD OR SOFTWARE
821:CONTROLLER BOARD
822:HDD PROBLEM
823:NIB, CONTROLLER BOARD
824:CONTROLLER BOARD, NVRAM
825:NVRAM ERROR
826:NVRAM
827:CONTROLLER BOARD, RAM
828:SOFTWARE,ROM,CONTROLLER
829:RAM, CONTROLLER
835:CONTROLLER,CENTRONIC LOOPBACK CONNECTOR
836-837:FONT DEVICE
838:CONTROLLER BOARD
850:IP ADDRESS,CONTROLLER BOARD,NIB
851:1394 I/F CONNECTIONB,I/F INTERFACE,CONTROLLER BOARD
860-861:HDD
862:HDD BAD SECTORS
863:HDD
864:DATA TRANSFER ISSUES
865:HDD
900:NVRAM PROBLEM.ELECTRICAL COPY COUNTER
901:MECHANICAL COUNTER ISSUES
921:IMB, BICU FAILING
922:IMB, BICU FAILING
924:DRAM,BICU,IMB FAILING
925:BICU, IMB FAILING
926:BICU, IMB FAILING
951:F-GATE SIGNAL ERROR PROBLEMS
953:SCANNER IMAGE SETTING ERROR ISSUES
954:PRINTER IMAGE SETTING ERROR ISSUES
955:MEMORY SETTING ERROR ISSUES
964:PRINTER READY ERROR ISSUES
966:POLYGON MOTOR PROBLEM
970:SCANNER READY ERROR
980:HDD ACCESS ERROR
981:BICU, NVRAM
982:HDD CONSTRUCTION ERROR
984-987:HDD DATA TRANSFER ERROR
990:SOFTWARE PERFORMANCE ERROR
991:REBOOT SOFTWARE ERROR
997-998:DIMM, RAM ERROR
999:PROGRAM DOWNLOAD ERRORS
Oct 29, 2008 | Ricoh Office Equipment & Supplies
I receive the following error message, when I power on my Copystar CS 300ci: Machine Failure C1950 Any suggestions
Transfer belt unit EEPROM error No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively. Mismatch of reading data from two locations occurs eight times successively.
Mismatch between writing data and reading data occurs eight times successively
1. Poor contact in the connector terminals.
- Check the connection of connector YC28 on the engine PWB and the connector of the transfer belt unit, and the continuity across the connector terminals. Repair or replace if necessary.
2. Defective transfer belt speed PWB (inner transfer belt unit).
- Replace the transfer belt unit.
I hope this is helpful,
Shawn
Mar 14, 2011 | Kyocera Copystar CS2540 Copier
My hp printer m1005 show error 20 and some time error 17. Plz. give me solution.
A 20 error is insufficient memory.
The device received more data than can fit
in the available memory. You might have
tried to transfer too many macros, soft
fonts, or complex graphics.
Touch OK to print the transferred data
(some data might be lost), and then simplify
the print job or install additional memory.
As for the 17 error?...I can't find it in the manual.
Feb 13, 2011 | HP LaserJet M1005 Printer
How to use bluetooth in case of laptop, i have installed the driver and whiled i transfer the data it sows error why?i m nt able 2 transfer data from pc to cell phone throught bluetooth.
dear friend,
first of all you cannot send entire folder from PC to mobile... try to send individual file...
and you need to pair the mobile to your computer before you can start the file transfer....
please clarify your doubts clearly, for further assistance...
May 09, 2010 | Dell Inspiron 1525 Notebook
Upgraded from QuickBooks Basic 2002 to Quickbooks Pro 2006. Transferred data from one company successfully. Second company, get following message: "Problem: There wan an unexpected error reported...
If you reinstall QuickBooks, you shouldn't lose any data that you've already converted, however, it would be a good idea to backup any company data you have transferred. If sounds like there was a corruption in the data transfer process though in which case you need to restore the original data and then try it again. You might want to reinstall the original software, open the company file(s) you are having troubles with and verify the integrity of those files before going through the upgrade process.
Feb 12, 2010 | Computers & Internet
Twain Complient
twain data transfetr error help please
Oct 20, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Transfer between 2 External Drives
the best program for this file transfer is Director Opus 9 this can transfer 100gig in under 1hr as with windows transfer takes 6hrs.
As I do alot of video capture and my filse range from 400mb to 4gig in size and having to transfer 700 gig about would take forever and with this program quick and easy you also can transfer over lan or wirless net.
happy transfering
Jul 08, 2008 | Cavalry Storage Computers & Internet
Canon CanoScan LiDE 25 Flatbed Scanner Logo
60 people viewed this question
old marine
old marine
