Sceptre After my monitor has been on for awhile it has this electronic burning smell coming from the back of it and seems to be going out..id there a way i can fix it before it to late?
    Problem Solver:
  • 5 Answers
Ur fan is out causeing it to over heat do not turn on computer till fan is repaired so that no chances of buring the board is possible
Posted on Feb 15, 2012
Strange hissing sound and smell comes from the monitor
Whenever you experience an unusual smell coming from anything electrical, always turn it off and/or disconnect it from any power source until you learn more about the problem. A fire can make make any problematic device seem suddenly unimportant.
An extremely common component in nearly any electronic device is a capacitor. The sizes vary from baby-tooth-sized to bowling-ball-sized found in the power box for most photography studios. The hissing sound is likely caused by one of these. The noisy capacitor may be going bad or another component or an electrical short may be causing it to get too much power. I've attached a video of what happens when capacitors get too much power.
An electrical short could also be causing both symptoms. If the smell is similar to burning organic matter, you likely have an insect (a crispy critter) that can be removed to remedy your problem. However, an electrical burn usually releases gases from burning rubber or plastic and has a distinctly different type of odor. If that's the smell and you are handy with a soldering iron, remove the cover to your monitor and look for signs of burning or overheating. Otherwise, the task should be left to an electronics shop for repair.
If this information was helpful, please click the thumbs-up button below.
Oct 23, 2012 | LG Computers & Internet
TV catching fire
I have a 32inch Sceptre TV. Recently the picture stopped showing and smoke ces from the back of the set. I unplugged it and am waiting on the authorzation to return it as it was just purchased in February. Like the other writer I have another these sets in my bedroom. If anyone has further information I would appreciated it.
Jul 10, 2012 | Sceptre X32GV-Komodo 32 in. LCD Television
Power outage at home. Monitor (Sceptre x9g) no longer powers up.
pop the back off of it and remove the power board, (it's the one that looks more primitive) look at the solder points on the back of the board for any burns or bubbles....
if not then you need to order a new power suply
Feb 06, 2011 | Sceptre X9G-NagaIV 19" LCD Monitor
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
Sceptre x20wg 1080p monitor
In case you know very well electronics, you must open the cover of your monitor and find a fuse burned. You change this. You must repair power supply which supports voltage to work light on your screen. You must be expert to repair this.
Oct 29, 2009 | Computers & Internet
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
My Sceptre X7S-Naga LCD monitor keeps shutting down...
Main digital board fault. Check and replace it. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 07, 2017 | Sceptre X7s-Naga II Monitor
No picture
I fixed mine. Had to replace one bulging capacitor in the power supply. Yours may need more or less but it was pretty easy if you do any electronics. The specifics can be found under some of the other problem posts, especially for one of the 19" sceptres.
May 04, 2008 | Sceptre 17" LCD Monitor
Sceptre monitor will not return from idle.
The only workaround was to not use the DVI cable but to use the old VGA cable. You still get the same resolution.
I have a different ATI board, so I'm thinking it's an ATI+Sceptre on DVI input bug. Anyway, use the VGA cable, it'll work.
May 22, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
