Question about HP DeskJet 845c Printer
Flashing green & orange lights and does not print cartridges moved on left hand side
Can you hellp?
  • ELSIENANN Jan 12, 2009
    AFTER REPLACING WITH NEW CARTRIDGES THE PRINTER MAKES A FUNNY NOISE AND THE GREEN AND ORANGE LIGHTS KEEP BLINKING. I TRIED THE PRINTER WITH THE OLD CARTRIDGES AND IT DID THE SAME THING
  • Anonymous Mar 16, 2009
    Replace toner and orange light is still flashing. Turned on and off as well
It seems to me that either one or both your cartridges have defective [worn-out] sensors. Please try to replace your cartridges and the problem should resolve.
alexander king
Posted on Nov 02, 2008
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Canon S520 color bubble jet printer. Light flashes green/orange. Print head does not automatically move when cover is opened.
trun off the printer then try to pull the cartridge head from left to right with your hand manually then turn the printer on it should reallign the head after that you open the cover it will come in the center and you can have the access to the cartridge
Apr 16, 2008 | Office Equipment & Supplies
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
Left hand light flashing orange and printer wont
Check the following:
Make sure you have removed the seal on each cartridge.
Turn of Printer, open all shutters, front and back and close them firmly, firmly.
Make sure there is no paper jam.
Usually these are the immediate causes of this kind of scenario.
Then try to print again.
Dec 03, 2009 | Canon LASER SHOT LBP-5000 Printer
Very slow printing when it does run. has a flashing orange light alot too. have to unplug and replug to work
One or both print cartridges is failed.Turn the printer on and open the cover.the carriage unit will move and stop in the left side of of the printer.There is a yellow arrow on the carriage unit.There is a two marks in the left side of printer.If the arrow show left mark replace color cartridge.If show right mark replace black cartridge.
Dec 01, 2009 | HP DeskJet 940c InkJet Printer
Blinking lights on Lexmark Z12 printer
Unfortunately, the Lexmark website is set up so I can't provide you with direct links to the workaround for these problems....
Go here: http://support.lexmark.com/perl/support/support.cgi
Do a search on "blinking flashing lights + Z12"
and try to follow the steps outlined in the troubleshooting guides that calls up.
This is the most likely candidate, but there are others that could cause this symptom:
Lights Flashing on the Printer ID: 241
Test the cartridges one by one and do the printer hardware test (refer to the relevant document for your printer) to establish which one is defective. The defective cartridge needs to be changed.
If the power light on the printer is blinking, you may have a carrier stall. To check this:
First unplug the printer.
Move the cartridges to the left by hand. In order to do this, you need to grip the top of the carrier belt (a black/grey belt with cog-like teeth) and pull it towards the right-hand side of the printer.
Once the cartridges have been moved across, you can clip them out.
Try to print without the cartridges in the carrier.
If you no longer have a carrier stall, put the cartridges back into the carrier and clip them into place.
I hope one of these options will provide you with the solution to your problem. If not, please write back with a report of what you tried and we will try to help you further.
If I have managed to answer your question or solve a problem, please take just a moment to rate this posting....thanks!
  • Test the cartridges one by one and do the printer hardware test (refer to the relevant document for your printer) to establish which one is defective. The defective cartridge needs to be changed.
  • If the power light on the printer is blinking, you may have a carrier stall. To check this:
    1. First unplug the printer.
    2. Move the cartridges to the left by hand. In order to do this, you need to grip the top of the carrier belt (a black/grey belt with cog-like teeth) and pull it towards the right-hand side of the printer.
    3. Once the cartridges have been moved across, you can clip them out.
    4. Try to print without the cartridges in the carrier.
    5. If you no longer have a carrier stall, put the cartridges back into the carrier and clip them into place.
Mar 28, 2009 | Lexmark JetPrinter Z12 color InkJet
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
Canon S900
Category : Printer does not respond, or operate Description : The print head holder does not move to the center
Close the front cover, and check the power lamp indication status (blinking or lighting). List of power lamp indications Blinks in green After lighting in green, blinks in orange 2 or more times Lights in orange Blinks alternately in green and orange, 1 time each this is the option i got on the canon website for printer head not moving to the center. but the light indication given does not match with these options.
It is better for you to go to the above link and see what options suite your problem and follow the instruction given by the manufacturer.
the link is :http://www.canon-asia.com/index.jsp?fuseaction=support&prod_type=bj&country=IN.
select your model (i990) then step by step troubleshooting. follow the online instructions.
Jan 08, 2008 | Canon I990 InkJet Photo Printer
Mp600 error 6A00
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Dec 09, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power
LEDs light alternately, Alarm in orange and Power
in
green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
HP DeskJet 845c Printer Logo
165 people viewed this question
Ben Johnson
