Question about Dell E152FPb 15" TFT LCD Flat Panel Monitor
Problem with Dell E152fpb computer screen
Sometimes when i turn on my computer, i have to hit the screen for it to come on. Does this soound like a cord problem?
    Champion:
  • 220 Answers
No It seems to be dry solder joints on the Invertor / powerboard.
Samir
Posted on Nov 05, 2008
INSTALL
Simply connect via VGA, DVI, or HDMI to video card.
Aug 26, 2012 | Dell E152FPb 15" TFT LCD Flat Panel...
Have a dell E152FPb flat screen monitor which doesnt stays black even when on light is green. have taken back off but no obvious bulging etc. what can i try to get some life back imto it please
The backlight controler board is faulty. You can try replacing any capacitors in this board even if they look OK. If this does not work then you need to replace the inverter board with a universal inverter board - you will need to work out the wiring details though.
Mar 10, 2011 | Dell E153FP 15" LCD Monitor
Dell E152FPB LCD no light
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Nov 10, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
The complaint for this DELL E152Fpb LCD Monitor was when switched on has power (LED lit) but no display ti goes yellow on the power led but it brings no display on the screen.
It is standby mode, no signal, It is possible that your computer is not POSTing.
Connect your screen to another computer/laptop, just to make sure, which component is not working. Either the Screen or the Computer.
Make sure the DVI/VGA cable is firmly connected as well as RAM modules and Graphics Card.
Please take the time to rate my expertise.
Thanks
Nov 01, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
Upgraded to windows 7 and now my dell E152FPb monitor will not allow me to change the resolution. What can I do?
borkoven, Will E152FPD act same way when you reconnect it to a windows XP computer? 12fixlouie
Oct 24, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
The monitor main menu pops up and off constantly without even touching the computer. So much so that Ive almost broken it in frustration, an help would be grateful!
alexanderhic, When the ac to dc power supply inside lcd monitors develop "electronic noise" on the dc rails that power up the vga to lcd digital LCD interface board it can cause very "squirrelie" things to appear on the screen of your lcd panel. You will need to visit YOUTUBE to find DIY video clips to know how to disassemble unit to do inspection for BAD SWOLLEN filter capacitors that may have failed and learn how to replace them with new ones. See how many "hits" you get if you query the web for "swollen capacitors" or "bulging capacitors" or "failed electrolytic filter capacitors" or "CapXon capacitors" If this was of some help pllease leave additional comment or testimonial and rate this response on fixya. 12fixlouie
May 26, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
After changing c5707/c5706 transistors its burnt after 10 minute? i have changed its 3 times, pls advise me about actual problem
On E152fpb dell only replace all driver transistor the c5706 or c5707 this 2 types of transistor is not desame one is PNP & NPN so you must be careful of replacing component maybe it will help you
Apr 26, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
Lenovo 3000 C200 soound system not working can not listen the audio, today I installed the windows xp hence the audio system is not working.
If the pre-installed operating system is not windows xp and you just upgraded/downgraded to XP, you have to download the drivers for your audio device. You can download the drivers at: http://consumersupport.lenovo.com/driversdownloads/drivers.html
once you're at the website, type the serial number of your computer and hit search. scroll down to see the audio categories and select the driver for you audio device that is compatible with windows xp
Apr 11, 2010 | Lenovo 3000 C200 Notebook
Dell e152FPB LCD monitor backlight power problem
Check the four transistors (c5707/5706) in the inverter section for shorts, board looks like this? http://www.lcdrepair.us/e152-e153fpb-inverter-power.html
Feb 20, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
Can not display this video mode
If it is possible to boot this machine in safemode, you can boot it and change the resolution to low mode, and reboot the machine
Oct 14, 2009 | Dell E152FPb 15" TFT LCD Flat Panel...
Dell E152FPb 15" TFT LCD Flat Panel Monitor Logo
346 people viewed this question
Alun Cox
