Question about Motorola Mobility ATRIX 4G (16 GB) Smartphone
No wi fi Mac address or Bluetooth address on my atrix 1
Cannot turn on wi fi or Bluetooth . Get error message after attempting to turn on wi fi no error code or description just the word error. In addition to that most times after I attempt to turn on the wi fi the phone will shut off and turn back on sometimes more than once. Bluetooth just says turning on then goes back to turn on bluetooth .
  • 16 Answers
SOURCE: Don't have mac address can't
have you done that update for the I1? It is supposed to resolve this problem
Posted on Mar 31, 2011
SOURCE: Bluetooth failure
pleace select your bluetooth in your menu and you see bluetooth turn on for fuw minits or scoend set it for long time then start file copy
Posted on Jul 19, 2007
likha
  • 790 Answers
SOURCE: Problem with v3x phone
maybe you have virus doomboot virus thats why your phone is freezing. reformat your phone to software.
Posted on Sep 27, 2007
SOURCE: Displays Message "Contact Service Provider"
contact ur service provider and get the PUK code ..... Gizmo
Posted on Oct 06, 2007
bigjohn007
  • 425 Answers
SOURCE: RAZR will not power up
hi
you have a software prob.. have you fon flashed...
im sure your prob is solved...
give me feedbacks...
Posted on Oct 16, 2007
I rooted my dragon tablet now I don't have an IP address or Mac address so it won't connect to Wi-Fi or ethernet what do I do do
Every connecting device (ethernet port, wi-fi, bluetooth, FireWire port) has a Mac Adress, it's a physical attribute. If it has been erased, it needs to be recorded in the device ROM again...
The IP Adress is volatile, it just needs to connect to a DHCP server on your network (usually your router) to be regenerated.
Apr 29, 2016 | Computers & Internet
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
My Wi Fi on my Atrix has stopped working. When I try to turn it on I get Error. I have done a factory reset and wiped all data. Any Ideas?
Do you have original ROM? If you rooted the phone you can try another rom.
Do you have bluetooth working? if not, this is bad news, the chip is broken and from experience, changing wont solve the problem, you would need to replace the entire motherboard.
If bluetooth is working then you can check motorola support, they have instructions online to solve some issues related to atrix.
check this link: https://motorola-global-portal.custhelp.com/app/utils/prod_guided_assistant/g_id/407/p/30,6720,7898
Aug 16, 2013 | Motorola Mobility ATRIX 4G (16 GB)...
Can't get my Altec backbeat 903 headset to sync with my itouch
Try updating your Ipod touch to the latest OS. I have read that older versions of the Operating system didnt offer bluetooth capeability, or it wasnt very stable. If you have the latest update then try this:
First, sync your iPhone or iPod touch to iTunes to backup your user information, Contacts, Calendar, and other data. Then try the following steps in order.
One On the device, tap Settings > General > Reset > Reset Network Settings. Check to see if the device now displays the Wi-Fi address or Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth). If there is a Wi-Fi address and a Bluetooh address, then you're done with these steps and you can resync your settings and your media using iTunes.
If there's still no Wi-Fi address or Bluetooth address, then continue to step two.
Two On the device, tap Settings > General > Reset > Erase All Content and Settings. Check to see if the device now displays the Wi-Fi address and Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth). If there is a Wi-Fi address and Bluetooth address, then you're done with these steps and can resync your settings and your media using iTunes.
If there's still no Wi-Fi address or Bluetooth address, then continue to step three.
Three
  1. Restore the iPhone or iPod touch software (this erases all data on the device) using iTunes (see article 305744 for additional assistance).
  2. After the restore is complete, sync your previous settings (mail settings, text messages, notes, call history, contact favorites, and so on).
  3. Now see if your device shows a Wi-Fi address and Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth).
If there is a Wi-Fi address and Bluetooth address, then you're done with these steps. If there is no Wi-Fi address or Bluetooth address, then continue to step four.
Four If there is no Wi-Fi address or Bluetooth address listed after doing the above steps, then your iPhone or iPod touch may need to be repaired. See the iPhone Service FAQ or iPod Service FAQ for additional service information.
Note: If the device shows an address in the Wi-Fi Address field and you are still having issues using Wi-Fi, refer to article 305715 for additional Wi-Fi troubleshooting tips. If the device shows an address in the Bluetooth field and you are still having issues using Bluetooth, refer to articles HT1843 and HT1664 for additional Bluetooth troubleshooting tips.
hope it helps!
Jun 24, 2010 | Altec Lansing BackBeat 903 Consumer...
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
MAC Book Pro unable to connect the wi-fi. Connection timed out er
Reset your wireless password/key. Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Mar 12, 2010 | D-Link Xtreme N DIR-655 Wireless Router
My Iphone wifi button is grey out
Resolution First, sync your iPhone or iPod touch to iTunes to backup your user information, Contacts, Calendar, and other data. Then try the following steps in order.
If there's still no Wi-Fi dddress or Bluetooth address, then continue to step three.
Three
Nov 08, 2009 | Apple Computers & Internet
I cant connect to WiFi with my blackberry bold. it shows "Failed to obtain an IP address"
Hi, this issue is caused when message authentication code (MAC) address filtering is enabled on the Wi-Fi network, and the MAC address of the BlackBerry smartphone is not accepted.
To resolve this issue, add the MAC address of the BlackBerry smartphone to the accepted MAC address list for the Wi-Fi network.
I hope this information may help you to resolve the issue.
Oct 15, 2009 | RIM BlackBerry Bold 9000 Smartphone
Wi-fi Problems, Error Message Problems, Network SOS Problems
The most common "cure all" to all devices is the battery pull. Like chicken soup is to the soul, the battery pull can solve many of the problems users encounter, such as application errors, theme problems, data problems and more. Before you do anything else - always do a battery pull.
  • With the device powered on, remove the battery
  • Leave the battery out for about 30 seconds
  • Replace the battery and let the device reboot
This will solve a great deal of problems - always do a battery pull before you seek help elsewhere. You can also perform a soft reset on your device by holding down the ALT+Right SHIFT+DEL keys for about 2 seconds. There is also a double soft reset which some users believe is equivalent to a battery pull. To perform this, do the standard soft reset - the screen will go black. When the screen is no longer black, press the keys again (perform another soft reset). You should then see another
blank screen followed by an hour glass.
Jun 10, 2009 | RIM BlackBerry Bold 9000 Smartphone
Psp connection to internet
You probably have your wi-fi under secured network.
Oct 02, 2008 | Video Game Consoles & Games
Motorola Mobility ATRIX 4G (16 GB) Smartphone Logo
319 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
