Question about HP Compaq Presario CQ57-229WM Notebook PC
Compaq CQ57 410US screen won't power on.
The Laptop will power up just fine, However the screen it's self simply don't power up as it should. The computer is working fine other than the screen NOT powering on.This laptop is just a little over one year old and has been treated VERY well, Never been dropped nor beaten. Nor has it been wet in any way, So other than that I can tell you nothing more accept I really would like to have my laptop in full functionality once again.Im certain it has to be a simple fix...If there is such and animal...ANY help will be much appreciated, thank You R.Wade & Ginger K. Johnson II Eastman Georgia.
  • HP Master
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Feb 16, 2012
Compaq Presario F700 Won't Turn On
Assuming the unit is plugged in, this could be an issue with the power supply, or an issue where the cord connects to the laptop. If the power connector on the back of the laptop is secure / doesn't feel loose or damaged, you may want to simply get a replacement power supply from a local electronics store. Be sure to take the make and model information of the laptop and the power supply with you to the store.
Jun 08, 2013 | Compaq Presario Notebook
Laptop won't boot - Compaq
Do you see anything on the screen? Does the HDD LED blink? You can start by removing the HDD and testing it or have it tested.
Jun 06, 2013 | Compaq Computers & Internet
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
My LGL55C powers up and goes to the b lue screen n won't boot up or do anything won't turn off .
Dear Chris,
Seems like a bad RAM. Simply change your RAM and then give your laptop a go and it shall be all fine and smooth sailing on wards. You can test it by simply borrowing a RAM from your friend for a while. But do make sure that RAMS are of same type.
Oct 30, 2012 | Computers & Internet
Compaq Presario CQ60 won't turn on
If you already replaced the motherboard then try replacing the power cord. If you meant you replaced the cord already, the it might be your motherboard is bad.
May 15, 2012 | Compaq Presario CQ60-220US PC Laptop
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
White screen
First see if the power on self-test (Fn+ Power) or the LCD BIST (D+Power) will run. The Diags are normally on a blue screen with white test, the LCD BIST is simply 4 Solid Color Screen looking for defects in the LCD panel.
If you hear beeps/windows sounds when the system boots and the LCD BIST test does nothing then the LCD has likely failed and you will need a new one. You can try an external monitor and see if you get video on an external screen.
If you don't then try these steps:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jul 17, 2011 | Dell Inspiron 1545 Notebook
Pc comes on but screen wont come on
There are a few possibilities as to what's causing this problem.
First, there may be a problem with the screen's backlight, either with the bulb itself or with the power inversion board. This can be repaired fairly easily with a little time and care.
Second, and more catastrophic, there may be a problem with the graphics processing unit (GPU), which would render the laptop totally useless.
Third, if some other component came loose (RAM, wireless card, hard drive) and is no longer connected properly, most systems will refuse to boot. This is obviously the easiest problem to fix.
The easiest way to test whether your laptop is actually still running or if it's burnt out is to make sure it's completely shut down, connect an external monitor, and power up. If you see the computer's start-up splash screen or BIOS diagnostics, then the problem lies with the screen itself.
If you don't see anything on screen, don't hear any beeps or sounds from the computer, or can't toggle CAPS LOCK or NUM LOCK, then it's more likely that there's a hardware problem. If you've checked all the connections for the above mentioned components, then some component may have burnt out and would need replacement. In that case, your best bet would be to physically take the laptop to a repair center, such as Best Buy's Geek Squad, Staples' Easy Tech, or any of your local computer repair centers, and have them run detailed diagnostics on it. If your laptop is still under a service plan, send it in to HP and have them fix or replace it.
Jun 09, 2011 | Compaq Presario CQ56-115DX Laptop
HP Compaq Presario CQ57-229WM Notebook PC Logo
565 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
