Question about Brother Sewing Machines
I have a Husqvarna Huskystar E10 Embroidery machine. It has been working fine for the past 2 years. Just used it yesterday. Today however, I went to use it and when I send the design to 3d Into Navigator I get a message that the memory is full and I need to run the De-Frag application in the design screen. I click on the design screen link and it starts to open, but then I get a message from Windows that the program has stopped working. I have tried everything to fix it. I've uninstalled and reinstalled the software, been working on this for 10 hours non-stop and can't find a solution to get Windows to read the embroidery machine without crashing. Please help!
  • dmblasko
    dmblasko Feb 15, 2012
    I have been running the software/machine from my laptop. It is a Compaq Windows Vista
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Have you tried re-booting?
Posted on Apr 07, 2017
dupina
  • 110 Answers
SOURCE: Will a Husqvarna #1 Plus embroidery unit work on a Husqvarna Rose machine?
I am sorry to inform you that Husqvarna # 1 embroidery unit does not fit onto the Rose machine. The terminals on the Rose is upright, while on the H # 1 it is flat. If you want to do embroidery on the Rose, you will have to purchase the embroidery unit.
Sad but true
Posted on Jan 22, 2008
SOURCE: Husqvarna Diamond Embroidery unit problems
Make sure that the red disk (smaller than a floppy) on the underside of your embroidery unit has been removed. Remove and discard the red disk. It is used for shipping purposes only. Joyce
Posted on Jan 10, 2009
kent581
  • 87 Answers
SOURCE: Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Posted on Mar 18, 2009
  • 152 Answers
SOURCE: Can't get computer and embroidery machine to connect.
If your using Windows Vista, you have to have the multi user account in the off postioin. Also if you had 3D embroidery software and you upgraded to 4D software you have to be sure to uninstall the 32 bit drivers from the 3d for the 4d to work properly.
You do have to install the communication software that came with the diamond also. It won't communicate through the 3d or 4d only.
Posted on Oct 10, 2009
  • 152 Answers
SOURCE: husqvarna viking designer 2 embroidery machine. Wont work on my
Buy a PC, or get the program that mac has that supports pc programs. I've seen it work so I'm sure it's an optioin. Mac people don't like the program, but it will create an environment that supports PC programs.
Posted on Oct 24, 2009
What is the product code for the huskystar em10?
The machine is actually a brother PE series embroidery machine, no longer supported by Husqvarna Viking.
Jun 24, 2014 | Husqvarna Sewing Machines
Ineed a spool pin for my E10 huskystar HUSQVARNA VIKING sewing machine
I've looked different places & can't find one,, here what I suggest
you can go to the sites below & ask them or email the about the
spool pin or try getting a spool holder that stands behind your
sewing machine
sewvacdoctor.com
a1sewingmachines.com
Sep 29, 2012 | Husqvarna Sewing Machines
I need to know how to lower the feed dogs on my Huskystar Viking E10
There is a switch on machine to raise feed dogs up/down. Remove any extension table to locate it because many of these options are located in the back of machine & hidden by table! Jimmy :)
Apr 07, 2012 | Husqvarna Sewing Machines
Husqvarna Huskystar 207 Sewing Machine not stitching. It won't pull the bobin thread up to sew.
Be sure not to use Singer Needles. They are longer than standard needles. Don't know if this helps, but I did this once on my Huskystar 207 and that is what happened. It also damaged the bobbin thread.
Fairleigh
Sep 18, 2011 | Husqvarna Huskystar 207 Sewing Machine
I need a manual for my Huskystar model E10
call dealors, and look on ebay. call the company itself.
Sep 13, 2010 | Husqvarna Sewing Machines
So i have a Huskystar EM10 that isn´t working. After a Defrag Memory, the machine lights up the red errorlamp, but there is no ''E'' code in the display. the machine only shows ''LOO'', there is no...
I have an EM10 that I just bought 2 weeks ago and after doing a defrag it now says the main motor stalled and it is making this horrible sound. I am searching online for parts and I can't find any. I have found that the customer support really sucks for the husqvarna huskystar machine.
Dec 25, 2009 | Husqvarna Viking 1
I have a huskystar em10 embroidery machine which wont embroider it will run for so long then the needle will snap, its not the tension
I have the same machine and had the same problem. I was changing my needle about every 50 stitches until I realized that it was the timing. After I learned how to adjust the timing the machine has worked fine. The problem is I have to adjust the timing about every 3000 stitches. I leave the bottom off of my machine because I adjust it so often. If you contact a husqvarna dealer they will tell you that they have to send the machine off to get it adjusted and that you can't do it yourself. I didn't have time for this so I googled how to do it and figured it out.
Apr 06, 2009 | Husqvarna Sewing Machines
Sewing Machines Logo
63 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
