Question about Whirlpool AWG329 Front Load Washer/Dryer
Noise from washing machine
My washer/tumble dryer works ok, but the noise from it sounds as it there is something inside drum. When machine is full noise doesnt seem to be so loud, but half load noise is terrible. Anybody else with same problem
  • Anonymous Nov 24, 2008
    hi we have the same problem its the drum bearings good luck we are moving we have had our beast out over 25 times time for a new one sorry
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fddfs
Posted on Sep 29, 2010
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
Beko DRVS 62 W Tumble Dryer Squeakig
I had a problem similar to this on my Frigidaire dryer. I found that there is a felt ring that goes around the drum inside. This acts like a washer to prevent the drum from rubbing on the housing. On mine, the felt somehow got pushed in some and the drum was squeeking as it rotated. I had to order a whole new drum and replace it since on my model it was part of the drum.
Feb 11, 2014 | Dryers
Maytag Performa Washer niosy during wash-cycle. Spins OK and without any noise.
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jul 02, 2012 | Maytag Washing Machines
The dryer part started to make a noise as if a sneaker was inside tumbling around.. next thing I know the two screws that attached the drum fell off and it completely stopped working
heatman101
5665thg
Jan 27, 2010 | GE Spacemaker Washer and Dryer Electric...
Kenmore 98702 Stacked Washer/Dryer. Dryer making clicking noise
There may be coins stuck inside the tumbling vanes in the drum.
Mar 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Agitator very noisy while washing
There is a small roller that tightens the drive belt for the drum inside this unit. If it is loose it makes a squeaking noise. Tightening this may solve your problem. You will have to take off the back panel to do this repair
Jan 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Squeaking noise from Dryer when tumbling
IT IS USUALLY THE "BELT TENSION ADJUSTABLE PULLEY". MOST ARE CHEAPLY MADE ... TRY A BIT OF AXLE GREESE ON IT ... IT IS SEALED FROM THE INNER DRUM AND IS MOUNTED USUALLY ON THE BOTTOM FRAME RAILING.
Jun 25, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryer not working
If the drum is not moving: There is something stuck inside your furness blower( could be some pice of cloth). Open the furness and remove the piece and your dryer will be working fine afterwords. If the Drum is working fine; the coil valve, fuse or the gas ignitor could be the problem; usually repacing the coil valve will fix the problem
Oct 14, 2006 | Zanussi WJS1265W Front Load Washer/Dryer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Whirlpool AWG329 Front Load Washer/Dryer Logo
464 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
