Question about Whirlpool Dryers
The dryer is completely cleaned but it shows it should be cleaned and will not start
I hve cleaned it completely but it signals that i have to clean
    Problem Solver:
  • 5 Answers
Check ur vent hose that goes out side it could be almost stopped up causeing it to billed enough psi to make the senser think that the filter is not cleaned
Posted on Feb 15, 2012
3 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: dryer doesn't dry clothes thoroughly
Turn off your breakers, then back on to insure a good reset. Then check the wiring from the receptacle, to the plug and then to the back of the dryer. You are getting some heat which tells me that one leg of power is out. I don't think it is your element, because you get some heat. Let me know how you do.
Posted on Feb 10, 2009
hondo73162
  • 132 Answers
SOURCE: Dryer won't dry completely.
rinse the lint sreen with hot water as wax buildup from softener clogs the screen and wont allow air flow. water will bead up on screen if this is true.
Posted on Oct 17, 2009
LG Dryer will not heat. Shows d80 code. Replaced exaust piping and is now new and clean all the way outside. Ran for 4 cycles and still not heat.
Clean out fan housing completely. Must take front off to get to it. Check out videos on drive belt replacement to show you how. Repairclinic.com or appliancepartspros.com for videos
Mar 25, 2017 | LG Dryers
I have a T711 asko dryer. When I push the start button it makes the sound when the dryer has completed its cycle. There is a "signal" button that you can depress to let you know the dryer is finishe
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Nov 11, 2011 | Asko T711 Electric Dryer
Have an Amana dryer LE9207W2, when you push start nothing happens, the screen is on showing auto drying and clean filter is blinking, we have cleaned the filter tray and even have taken the mounted tray...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 19, 2011 | Dryers
The dryer completed it's cycle and the next day went to fluff the load and will not start on any cycle. The display is lit with run time showing but nothing else.
Clean out the condenser....and the drum filter. Ifm this does not fix it there is a resetable thermostat on the heater bank at the back behind the cover plate.
Jul 31, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Have AMANA dryer ALE230RAW. Hear buzz when start
I also have this problem, but it is after the dryer has been running. When the motor is hot, it buzzes and will not run. Sometimes it will run if I turn the drum or take some clothes out. I disassembled the dryer and cleaned the motor of lint. This helped but not completely solved the issue. I have completely removed the motor and will thoroughly clean the motor (stator and brushes) and will try again.
Nov 23, 2009 | Amana Dryers
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Car's power completely shut off when driving. 1998 Malibu
Problem is either the battery or the terminals that go on the battery. Remove and clean both terminals and if the problem persists replace the battery.
Sep 09, 2009 | 1998 Chevrolet Malibu
Dryer runs hot and will not shut down automatically
there is a thermostat or what we would say a high temp switch near the heating element to keep it from getting to hot , the internal parts of the vent must be cleaned as well, cleaning the vent and the screen is not always good enough. Ive had to completely take the dryer apart and pull all pipes apart all the way to the lint screen to fix this problem.
Jul 23, 2009 | Dryers
Need to initiate cleaning cycle
to enter the cleaning cycle:
Select the RINSE & SPIN button.
Select Low SPIN SPEED'
Select Warm/Cold WATER TEMPERATURE.
Select the 2ND RINSE Option.
Push the END of CYCLE SIGNAL button 4 times within 5 seconds to start cycle
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Backup problem
This means that the drive's head needs cleaning. So, load the cleaning tape into the drive to start the cleaning function.
Jun 23, 2008 | IBM (3582L23QC1HVD) Ultrium Tape Drive
Dryers Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
