Question about Peavey Audio Players & Recorders
Every time I turn my amp on - Peavey Audio Players & Recorders
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Peavey Expert
  • 232 Answers
It sings a song?
Posted on Sep 20, 2014
If timing belt is off by one tooth could it cause it not to crank? 98 neon 2.0 L single cam
The pulley on the crankshaft turns the timing belt
The top ends of the timing belt turn the cams
You need to go to You Tube Video & watch how things work
If your referring to the valves hitting the pistons & not turning,
no,not with a tooth or two off.
Still have to be sure the belt is good & timing correct,not
jumped, as your asking
Jul 22, 2013 | Cars & Trucks
Set screen date/time in kodak easy share
Hello There!,
I think I can help you :-)
Here is the link for the user manual
http://gdlp01.c-wss.com/gds/7/0300001857/01/PSA480_CUG_EN.pdf
On page 16 it explains two ways to set date & Time.
1st is when you turn on the power it will ask you to set the time & date, and you can enter it.
2nd way to set time & date, or change it is to press the MENU key, and select "Set Date & Time".
I hope this helps you.
Please also giving me a good rating for offering you help, :-)
Thanks,
Sep 17, 2011 | Canon PowerShot A480 Digital Camera
I have used the amp for a while running 4 speakers. the front are components, and 6x9 in the back. The amp worked great and was loud. The amp just stopped working one day when i turned it on. Turns on...
One of your speakers might have burned out, shorting the wires that connect it to the amp. Disconnect one speaker at a time from the amp, turn it on(try all four, turning the amp on and off each time you disconnect a speakers wires) and you can pinpoint which speaker might be causing the amp to go into protect mode. If you disconnect all the speakers and the amp still goes in protect mode, then the amp is shorted internally and will need to be replaced or repaired.
Sep 22, 2010 | Clarion APA450 Car Audio Amplifier
Looking for timing mark's for a 1997 camry with a 2.2 4cyl motor?
You find the timing marks on the picture below.
Removal
Remove auxiliary 1. drive belts.
2. Support engine.
Remove:
Engine mounting and bracket.
Timing belt upper cover [1].
3.
4. Turn crankshaft clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Remove:
Crankshaft pulley bolt [4].
Crankshaft pulley [5]. Use tool No.09213-60017.
5.
6. Ensure timing marks aligned [2] & [3].
7. Slacken tensioner bolt [6]. Move tensioner away from belt and lightly tighten bolt.
Remove:
Timing belt lower cover [7].
Crankshaft sprocket guide washer [9].
Timing belt.
Tensioner pulley.
Installation
Installation
1. Check tensioner pulley for smooth operation.
2. Check free length of tensioner spring is 46,0 mm [8]. Replace spring if necessary.
3. Fit tensioner and spring. Ensure spring is connected correctly.
4. tighten bolt [6].
5. Ensure timing marks aligned [2] & [3].
6. Fit timing belt. Ensure belt is taut between sprockets.
Install:
7.
8. Slacken tensioner bolt 1/2 turn [6].
9. Turn crankshaft two turns clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Turn crankshaft slowly 1 7/8 turns clockwise until crankshaft pulley timing mark [3] aligned with 45° BTDC mark [10] on
timing belt lower cover [7].
10.
11. Tighten tensioner bolt [6]. Tightening torque: 42 Nm.
12. Install components in reverse order of removal.
13. Tighten crankshaft pulley bolt [4]. Tightening torque: 108 Nm.
Manufacturer: Toyota
Jun 25, 2010 | 1997 Toyota Camry
My amp would turn on and off and one time it just stopped working its a powerful amp want to fix plz.help
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Contact Kicker to have them repair. .A thumbs up would be greatly appreciated if this answer is helpful to you.
May 20, 2010 | Kicker KX500.2 Car Audio Amplifier
How do i turn off the date on my kodak m863 camera. I turned it on a long time ago and it won't give me an option to turn off the date and time. HELP!?
HI there press the menu , then scroll down for setting option . From setting you can find the date & time on/off option. Select from there as per your choice & use that. Thanks & waiting for your feedback.
Apr 01, 2010 | Kodak EasyShare M863 Digital Camera
Sometimes my amp works sometimes it dont.
it could be your wiring or grounding to your amp, also check fuses on amp
Sep 16, 2009 | Car Audio & Video
The key wont turn the ignition. What is causing
Could be a few things.. But try to eliminate the easiest & least costly first..
Spray some wd40 into the key hole..
Push key in & out several times & do not try to turn it yet..
Repeat a few times - then try to turn it..
Sometimes the key tumblers get dirty & sticky..
If that dose not help - it could be the ignition switch needs to be replaced..
Hope this helps !!
rate me good ;o)
Jul 13, 2009 | 1991 Dodge Dynasty
Amp will not turn on
the transistor of your amp is damage you replace that
May 01, 2009 | Car Audio & Video
Turns on 1 out of 4 times?
The problem might not be with the amp. You will need to check the "remote" output from your head unit at the amp end using a voltmeter. It should be ~12.5 volts dc when the head unit is turned on. If there is no voltage when the head unit is turned on, then the problem is not the amp. The head unit may be bad or there may be an intermitant short somewhere in the remote wire.
You can test the amp by removing the remote wire and connecting the remote input directly to the +12v terminal. Use a short scrap of wire. This will (should) manually turn on the amp. Don't forget to return the remote wire to the remote input or the amp will never turn off.
A friend of mine had his remote wire shorted to ground once after he replaced his head unit. Turns out when he slid the new one into the dash opening he pinched the remote wire against the chassis. Frustrating but an easy fix.
Sep 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
54 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Steve
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
