My photocopier removing blank papers though toner new.
When I photocopy the paper comes out blank and i just replaced the toner.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Whats the make and model of the copier?
  • 25 Answers
You have a transfer problem.
what is the make and model please
Posted on Nov 04, 2008
Canon ir 1024 photocopier photocopy but the paper is blank what can be the problem
if print from computer ok than problem on scanner or both blank problem on high voltage
Jul 20, 2016 | Canon IR1024 COPIER FOR 220 VOLTS
How do i fix toner stain on printout and photocopies? please what might be the cause of the dot stains?
There are several reasons for stains on a Laser printer or photocopier
1. Clean all rollers. Fuser; transfer and pickup.
2. Ensure the toner is clean from outside.
3. Hope the Toner is not refilled and Is not leaking.
4. Clean paper path.
Mar 08, 2016 | Office Equipment & Supplies
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
I have a sharp2030 photocopier, how can i get find a solution if it prints out the blank papers .or what could be the problem. its says call for service F2? help
If you are getting no toner on the paper the charging unit which charges the paper to transer the image from the drum is faulty,Check all the removeable charging units which comprise a very fine wire stretched acos the paper path.Otherwise contact Sharp giving them service code
Apr 29, 2011 | Sharp SF 2020 Copier
HI there! Our Kyocera 180 does not photocopy documents. The paper that comes out is just blank. We recently replaced the tonner so we believe there's still enough ink. Should we checked if the photocopier...
if you are getting blank copies nothing on the page you need to check the drum main charge or the developer unit is locked into place correctly and if the developer unit is turning take out the developer unit and see if there is an even coating of dev and toner on the roller use a piece of paper rub of a small are on the developer roller put in the machine and do a copy after take out the developer unit and see if where you marked is visable if it is then the developer unit has a problem as it is not turning
Check the main charge roller it is connected to the side door
Feb 05, 2011 | Kyocera TASKalfa 180 Copier
Not printing.
trying to photocopy paper / buttons not working coming out blank
Mar 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
HPF300 will not copy paper comes out blank when printing from computer and also blank when photocopying
My printer shows is out pf paper and is not.. did everything I could do and even though the paper is still there the printer doesn't print and keeps showing its status as is out of paper.
Could you help, please.
Best wishes
Oivia
Dec 01, 2008 | HP Office Equipment & Supplies
A new sharp ar 5316e photocopy machine photocopy blank
change the main charger because based on my experienced it has an arching problem
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
64 people viewed this question
jasbo
jasbo
