Question about Dell 828FI 15" CRT Monitor
Dell 828FI (White) 15" CRT Monitor schematic diagram send
5 Suggested Answers
SOURCE: Lcd monitor goes white
The E151FPb's seem to have a problem of this sort. After doing some research online I've found that the most common problem is a few dry solder joints on the large circuit board inside the monitor. There was also some talk of a connector suffering from heat creep that sound be connected better on the inside, but usually that would make the screen turn black if it were to become disconnected. The monitor can be opened by unscrewing all the screws on the back, there should be 6 screws you need to pull out before being able to open the case. After those, insert a thin, but strong piece of metal into the side and sort of twist/slide it along the side and it should pop open some clips and just work your way around the perimeter. After that it's just some simple and obvious screws to get to the circuit boards.
Posted on Apr 20, 2007
SOURCE: dell monitor 828fI NEEDS A FUSE ON BOARD H 250V T3 15A
Go to the hardware store.. There are a lot of it.
Posted on Feb 27, 2009
babes_ganda0
  • 381 Answers
SOURCE: monitor control panel keeps popping up on screen
hi..if you soldering iron or do you have a electronic technician you need help him.the defective parts need to replace is Tack switch inside the CRT/Monitor..Thanks and Good Luck...^_^
Posted on May 10, 2009
budmrtn
  • 11361 Answers
SOURCE: NEED SCHEMATIC DIAGRAM
http://s807.photobucket.com/albums/yy352/budm/Dell%201704FPT/
No bad caps, blown fuses?
Posted on Apr 06, 2011
I switched it on and begins to flicker and even with noise
1)Restore Monitor to factory settings using Menu buttons.
2)Perform Monitor self test
Turn the monitor off and disconnect the video cable from the computer. Turn the monitor back on.
If self test is displayed on screen without any issues, Monitor works fine
OR
Monitor gone bad
Jan 10, 2010 | Dell 828FI 15" CRT Monitor
Need schematic diagram for AOC 5 En model (white 15 inches color monitor) - thank's
my AOC crt monitor 5En model has this problem. it has over width the compress button (<> ) is no longer functioning what particular component should i check or adjust inside the circuit? please i need ur help..
Nov 21, 2009 | AOC 5 En 15" CRT Monitor
Dell Monitor Not Working
well if the status of the LEd on the monitor is amber(orange) & the system is running on a on board video card & not a Add-on video card... it is a possibility the the integrated video card ot the mother board might have gone bad... either contact a local tech or the tech support for the computer...
also unplug the monitor cable from the system tower & then if you see that there are the bars moving which say monitor self test on... means tht the problem is with the video card or the mother board...
since the system is running on a integrated video card...
Jan 17, 2009 | Dell 828FI 15" CRT Monitor
Schematic diagram
plz send me philips lcd monitor diagram power supply model 150B
thanks
regards
asif mansouri
Oct 20, 2008 | Computers & Internet
Dell monitor 828fI NEEDS A FUSE ON BOARD H 250V T3 15A
Sep 28, 2008 | Dell 828FI 15" CRT Monitor
Monitor Display
it sounds like you have change the postionof the screen on the monitor. try changing the horizontal and the vertical setting to remove this
May 22, 2008 | Dell 828FI 15" CRT Monitor
518X Schematics
please go to web site www.serviceinfo.com for circuit diagram.
Sep 19, 2007 | Daewoo 518X 15" CRT Monitor
SHAKING IMAGE, STRETCHED IMAGE
Like I said last night cobra there is a vert shaper cap off the jungle/drive ic usually a smaller value and will check good but its bad. Or the b+ filter cap off the fly has caused sysmtoms like this as well. Good Luck
Apr 14, 2006 | Dell 828FI 15" CRT Monitor
Model no. 828fi (800f series)
there is a vert height control on the main board somewhere as sometimes look in the back of the back cover after you take off the back and see if they put a diagram of sorts in there . Good Luck
Apr 13, 2006 | Dell M570 15" CRT Monitor
Dell 828FI 15" CRT Monitor Logo
26 people viewed this question
Alun Cox
